Old December 3rd, 2006, 04:02 PM   #41 (permalink)
Originally Posted by Munga
Yeah. For sure. And I am glad that so far the mistake wasn't my **** up. Ok, I will stop being so arrogant.
That is really good news... I mean, except for having to wait for the shipping :)
When the amp doesn't fire up right and you're trying to figure out why, that part SUCKS worse than anything. So figuring out it was a bum part is actually a relief! You know, fear of the unknown and all of that stuff.
I've got my home-studio upgraded and back in gear, so I'll be recording more clips of my amps... I've yet to hear getbent's still (hint hint), and I'd love to hear yours when it's done Munga!
Old December 3rd, 2006, 04:27 PM   #42 (permalink)
Munga's Avatar
I will record some clips right as soon as I get tone from this thing! Hopefully it wont take too long to get the transformer. I might even opt to pay for overnight shipping cause I want to get 'er done.
As of right now, the PT-less chassis is sitting on the desk, taunting me, its gleaming chrome reflecting the woeful wait I have to endur. I should probably buy a variac, that would have been helpful.
Munga is offline   Reply With Quote
Old December 4th, 2006, 07:40 PM   #43 (permalink)
Munga's Avatar
Ok, I called Weber and told them the problem so they said they are gonna ship me a new PT tommorow. I hope to be up and running by the end of the week. :)
Old December 8th, 2006, 10:45 PM   #44 (permalink)
Munga's Avatar
Just got the new PT. However, I will be busy most of the weekend but I hope I can have it done Sunday night.
Old December 8th, 2006, 10:49 PM   #45 (permalink)
Doh!
I've been in suspense here for too long!
Can't wait to hear and see it... you will post clips and pics, won't you? Pleeeeaaaase...
Old December 8th, 2006, 11:36 PM   #46 (permalink)
Munga's Avatar
ASAP, of course. I am about as anxious as you, if not more. :)
Too bad I am busy this weekend. :(
Old December 10th, 2006, 11:24 PM   #47 (permalink)
Munga's Avatar
Ok, just fired it up. There IS sound, but not much. First of all, there is a loud buzz. And then, I turned the volume all the way up on my guitar and amp and barely hear crackly chords coming out of the speaker. The problem is, there is no voltage across the cathode biasing resistor :O
Any help?
Old December 10th, 2006, 11:32 PM   #48 (permalink)
Check your solder joints for bad ones.
Also check them for "cold solders". The solder will not be shiney, but it will be a dull gray.
Old December 10th, 2006, 11:34 PM   #49 (permalink)
Munga's Avatar
I have checked all the joints visually and can't find any suspects. Can you give me any other points to test? All the filter caps are getting high voltage DC, but there is nothing across the bias resistor. Hmmmmm...
Old December 10th, 2006, 11:50 PM   #50 (permalink)
zook's Avatar
Check the voltages on pins 3 and 4 of the 6V6s. They should be around 350Volts more or less.
Winnie
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser
zook is offline   Reply With Quote
Old December 10th, 2006, 11:58 PM   #51 (permalink)
Munga's Avatar
No voltage on pin 4.
Old December 11th, 2006, 12:12 AM   #52 (permalink)
Munga's Avatar
Ok, DERRRR DERRR DERRR. I am officially a retard. I soldered the lead from the 4.7k and 22k resistors to pin 3 instead of pin 4
So basically, pin 4 has a lead going to the other pin 4, isolated from everything else. Someone slap me.
Old December 11th, 2006, 12:33 AM   #53 (permalink)
Munga's Avatar
I have SOUND!!!!!
Hear is the dealio. There is some slight ground hum, and for some reason, both the volume pots are affecting each other and the tone pot isn't doing nothing. However, I just cranked, sounds pretty, so I am happy for tonight.
Yay!
Old December 11th, 2006, 12:33 AM   #54 (permalink)
Moderator
getbent's Avatar
Everybody misses stuff... no biggie.. fix it and test.
'never pet a burning dog'
Old December 11th, 2006, 04:04 AM   #55 (permalink)
I have SOUND!!!!!
Yay!
100% of my mistakes are really stupid ones... on my part.
Relocating some grounding will help with the low frequency hum.
Tidying up the lead dress on the input and preamp section (shortest possible wiring, routing away from noise) will reduce noise (especially when playing loud).
The volume/tone issues will be easy to track down... the amp will sound even better once this stuff's resolved.
This is the time where you do a Gene Wilder impression from Young Frankenstein and go "It's alive!!!".
Congrats! Every time a build is announced "done" it's exciting!
Old December 11th, 2006, 04:41 PM   #56 (permalink)
kludge's Avatar
That's because it's a TWEED DELUXE!! Really, the volume controls DO work that way. Can't say they're SUPPOSED to, but that's how the design works out. Dunno about the tone pot... it should be affecting the sound, so there might be a little problem there. But there's a great deal of interaction between all three knobs in a Tweed Deluxe. Twist 'em around and see what happens!
kludge is offline   Reply With Quote
Old December 11th, 2006, 08:12 PM   #57 (permalink)
Munga's Avatar
Ok, so actually, the 2 normal input aren't working. Maybe that is related to the tone pot not working. So far, the tone is great, a little skrieky, but maybe just cause I can only use the bright channel and am using a '52 AVRI Tele. LOL.
Old December 11th, 2006, 08:15 PM   #58 (permalink)
HAHAHA
Old December 11th, 2006, 08:17 PM   #59 (permalink)
Moderator
getbent's Avatar
check the wiring to the input jack.. frequently the layout is different than the actual jack... I speak from experience due to inexperience here...
Old December 11th, 2006, 09:10 PM   #60 (permalink)
Munga's Avatar
So, on the 500pF cap between the tone and volume, 1M ohm isn't a good a good reading between the leads of the cap, is it?
Old December 11th, 2006, 11:23 PM   #61 (permalink)
Moderator
getbent's Avatar
Check your grounds... are you grounding to the brass plate or a buss or star to a post?
since it is running and not blowing fuses.. do the chopstick test.. that should tell you a bunch... my advice... print a layout and wherever you get noises when you tap with the chopstick mark it... heat tha solder joint... and check and recheck in your jacks to make sure you are wiring them correctly.
Old December 12th, 2006, 09:15 PM   #62 (permalink)
Munga's Avatar
I may have found the problem. I forgot to solder one lead of the jumper from pin 3 to 8 on the first preamp tube.
Old December 12th, 2006, 09:19 PM   #63 (permalink)
Munga's Avatar
Ok, scratch that. It didn't solve the problem at all.
Old December 12th, 2006, 09:29 PM   #64 (permalink)
1. Double check the tone pot's lugs.
2. Also double check the solders from the middle lug of the Volume pot to the 1uF cap on the board, as well as the same connection to the Tone pot's #1 lug.
3a. Check to make sure the cap on the Tone pot's lug #3 is the proper value.
3b. Make sure the ground connection of this cap is solidly to ground. Those brass plates are often hard to solder onto very well.
Old December 12th, 2006, 09:36 PM   #65 (permalink)
Also the volumes shouldn't interact like you're describing. This leads me to believe the issue is with the Tone pot as well since both Volumes share the pot.
They interact without jumpering channels, right? How so?
The 12AX7 is actually two tubes in one envelope. Both halves are triode tubes (three component tubes) in one glass case...
I believe each Volume pot is driving each triode's plate (pins 1 and 6) individually.
Pins 3 and 8 are each triode within the 12AX7's cathode. They share the same cathode resistor and bypass cap.
Old December 12th, 2006, 10:03 PM   #66 (permalink)
Munga's Avatar
I checked all that, with continuity and ohmage tests, and have seen that they all pass. As far as I can tell, the problem lays inbetween the input jacks and the volume pots. The weird thing is, both pots work. :/
Old December 12th, 2006, 10:06 PM   #67 (permalink)
This is for the Tone pot not doing anything, right?
If not, what is the trouble? I'm sorry, I musta got confused :)
Old December 12th, 2006, 10:11 PM   #68 (permalink)
Munga's Avatar
