Tone stack/coupling cap mods?
Most of my amps seem to run .022 uF caps for the midrange stuff - a little too high in the mids for my tastes.
I guess I'm mainly a BF/SF Fender amp guy, but the .047's seem like they'd be a little too deep for the .022-based amps I have. How about .033 uF? A good compromise? I'd like to know before I gut anything...
| Sponsored Links |
My prefs
I tend to prefer .047uF for both the bass and mid caps. I also use a 100k pot for the bass control. That extra 150k in the stock bass pot is wasted as far as I'm concerned.
On my closest-to-BF amp I actually have .022uF caps and a 56k slope resistor -- very much like a 5F6A Bassman, except for the 100k bass pot. Bob Arbogast |
the other cap almost always tends to be another .022. and the slope resistor is almost always a 33K. maybe I'll start by knocking the slope resistor up to a 47K and take it from there. The Marshall I just got has a 1 meg bass pot! anything above 2 and it becomes a bass amp (with a .022 cap and 33K slope)!
thanks for the tips. I'll work incrementally to bring the mids down on a few of these projects...
![]() Blue (bottom) line is 0.100u (100n) Mid Cap Green above that is 0.047u (47n) Mid Cap Green above that is 0.033u (33n) Mid Cap Green on top is 0.022u (22n) Mid Cap It looks like, as you increase the value of the mid-cap, you are scooping out more of the lower requency mids while the amount of upper-mid scooping remains the same. My '71 SFDR uses .047 (47n) for the mid cap, although the mid "control" is set to "6.8" since it uses a resistor instead of a knob. Dowload the calculator. It is very cool.
JJman If it says "Vintage" on it -it isn't. |
#7 (permalink) | |
Thanx ! |
I use Macs, so I guess I'm missing the boat on this one...
I'll start by messing with the slope resistor and take it from there, 1st at 47K, next at 56K, then up to 68K. Hopefully I won't have to go any higher than that...
