very strange amp noise-Tremo,Wally et al
I've owned tube amps forever and this one's a puzzler.
I have a mid 60's BF Twin. The other day I had it warming up for a while and when I took it off standby, there was a noise that sounded like air being squeezed out of a balloon. I put it back on standby, waited a few minutes and turned it back on. The sound was gone. Great an intermittent problem. Anyway this happened one more time. Is this a tube or component problem? Is it a gasey/leaky vacuum on the power tubes? |
| Sponsored Links |
Could be a tube on it's way south. Could be a plate load resistor.
Intermittent problems are a nightmare to track down. Next time it does it, start tweaking knobs to see if any of them have any effect on the noise, that will give you an idea where in the amp the noise is coming from. |
Ditto what Tremo says. I would have both channels set up to play...volumes and tones up to a normal setting. When the problem occurs, shut down one channel at a time....maybe you can at least get an idea where to start looking.
