Old August 21st, 2003, 08:47 PM   #1 (permalink)
mudshark's Avatar
Silvertone Model No. 1392 question
Purchased a '50s Silvertone Model No. 1392 about six months ago, and what a fine little amp it is - 12-inch speaker, tremolo, nice fat clean tones and breaks up really nice for overdriven tones.
Anybody have any idea of the power output rating of these little jewels (I'm guessing about 15)?
mudshark
Klaatu barada nikto
mudshark is offline   Reply With Quote
Old August 22nd, 2003, 03:42 AM   #2 (permalink)
Dacious's Avatar
Having a tube compliment would be good, but it'd still be a guess. If it's a two 6V6 amp, likely 10-15watts.
Old August 22nd, 2003, 10:05 AM   #3 (permalink)
4mal's Avatar
sshhhh! let's not get inflation going on these yet Those old Silvertone tube amps are great. The other one to look for is the Twin Twelve. 2 6L6's it's pretty loud but a very nice sounding amp. Not exactly a looker though ...
4mal is offline   Reply With Quote
Old August 22nd, 2003, 06:16 PM   #4 (permalink)
mudshark's Avatar
Yup, 2 6V6's. Thanks for taking the time to post!
And you're right, 4mal, we surely don't want the word to get out on old Silvertones!
mudshark
Klaatu barada nikto
Old June 16th, 2009, 03:05 PM   #5 (permalink)
I scored one of these about 8 years ago and the speaker crapped out. Have any of you experimented with different speakers in the 1392? I might try a weber in it but there isn't alot of clearence for the magnet.
banjovi800 is offline   Reply With Quote
Old June 16th, 2009, 03:24 PM   #6 (permalink)
Closer to 10 watts than 15 would be my guess.
Old June 16th, 2009, 08:07 PM   #7 (permalink)
I had one of these I rescued. It was the dirtiest object I have ever bought.
Must have been in a barn 40 years. Mine was made in 1957. Had to replace nearly every resistor and cap in it as well as the rotten Rola speaker and the output transformer. BTW there is a schematic out there floating around that has a two values for one of the resistors. One makes too much gain, the other is correct. Once I fixed mine up it did sound great. Tremelo was great. Really about 10 watts, not 15..Oh chassis was so full of dirt I had to wash it out in the sink. It turned out beautiful once I cleaned it up and fixed it.
Robster is offline   Reply With Quote
Old June 16th, 2009, 09:01 PM   #8 (permalink)
How many watts is the jensen you put in it? Does it sound better than the stock?
Old June 16th, 2009, 10:03 PM   #9 (permalink)
The 1392 amp was the next model up, and it had almost everything you needed for serious sound customization: tone, tremolo strength/speed (and footswitch!), 3 inputs, and 10 watts into a nice 12" speaker. All that was missing was bass/treble controls... but tone would do for the price. Plug in and get your trem speed set to the tempo you're playin' that Bo Diddley beat and look out!
Introduced:
Fall/Winter 1957 at $67.95
as the 57D01391L
Through its career, it was :
57H01392L
57G01392L
Retired:
Spring/Summer 1959 at $67.95
as the 57Y01392L
jh45gun is offline   Reply With Quote
Old June 16th, 2009, 10:07 PM   #10 (permalink)
A good look at the Danelectro-engineered double decker design. Controls (and frequently a preamp) up top, and the amplifier section down bottom..
Old June 16th, 2009, 10:19 PM   #11 (permalink)
I never got to hear the stock speaker as it was damaged and the output tranny was toast. I replaced the speaker with a Jensen reissue C12 that can take at least 25watts. I think the speaker was a 4 ohm but when I replaced the tranny with an 8 ohms tranny and speaker.
Old June 16th, 2009, 10:45 PM   #12 (permalink)
Televised's Avatar
I have a 65' "1483". It's 22-23 watts with a single 1x15 Jensen, (which I then have plugged into a G&K 2x12 closed cab). We abused it with three guitars plugged into it at the same time when I was in high school. It sat down in the basement for about 30 years. I cleaned it up and took it in and all it needed was some capacitors and resistors. The original 2-RCA 6L6s and 2-12AX7s tubes were still going strong! It's made out of pressed fiberboard/plywood and cheap grey tolex but still sounds just great.
The 2x12 your speaking of is the "1484" and I believe is rated at about 60 watts. You'll still find these Silvertone amps on Ebay and Craigs List and the sound is real good as they are point to point wiring and I believe based on some of the old Fender amp schmatics. Can certainly highly recommend them
"In life......no matter where you go.....there you are...."
Adventures of Buckaroo Bonzai
Televised is offline   Reply With Quote
