Old October 8th, 2006, 02:25 PM   #1 (permalink)
installing wheels on a deville
i desperately want to do this. fender sells some casters, but i don't know how to put them in; are these replacements for amps that already have casters? or are they meant to be installed into amps that never had them?
http://www.fender.com/products/searc...tno=0994000000
if anyone can give me a rundown of how to install casters, it would help me out a lot, seeing as i'm mechanically incompetent
jivetrain is offline   Reply With Quote
Old October 8th, 2006, 02:33 PM   #2 (permalink)
I've usedthe Ernie Ball casters quite a bit. They're pretty much the same as the Fender "pop-ins".
You have to drill a hole for the pop-in shaft, then screw in four screws on the baseplate.
I'm not sure how large the shaft is, but it's something like 1/2" or so... so you may need a larger paddle bit for your drill than a "normal" type of bit.
Be sure to use a tiny drill bit to drill pilot holes for the screws, simply driving them in may cause chipping in the cab without the pilot holes. If the pilot holes are the same diameter as the screws there'll be nothing for them to grip, so a super tiny drill bit is plenty good.
Old October 12th, 2006, 08:28 AM   #3 (permalink)
Nvr2Many's Avatar
I went to Home Depot and just bought some heavy duty casters there. Took off the stock rubber feet and screwed them in. Johnny's idea about the pilot holes is a good one.
It don't mean a thang if it ain't got that twang!
Nvr2Many is offline   Reply With Quote
Old October 12th, 2006, 12:51 PM   #4 (permalink)
i got some ernie ball pop outs, and will try them pretty soon. the only thing i'm concerned about is the stuff in the bottom of my amp.... there's sort of a vinyl covering, which doesn't reach to the edges of the amp, so i have room between it and the sides of the cabinet to drill a hole... but i'm clumsy.
Old October 12th, 2006, 12:56 PM   #5 (permalink)
e-merlin's Avatar
And I though this was a thread about pimping your ride!
'tone is in the underpants'
Old October 12th, 2006, 02:39 PM   #6 (permalink)
ray
ray's Avatar
I installed a set of the Ernie Ball pop out casters on my Hotrod Deville, and I removed the reverb tank while I was drilling the holes so I didn't have an accident. Two wood screws hold in the bag that the tank is in. You may also want to cover the speakers with a towel to keep the wood chips out.
Ray
ray is offline   Reply With Quote
Old October 12th, 2006, 03:16 PM   #7 (permalink)
so that bag thing in the bottom is a reverb tank? good thing you told me that...
do i have to disconnect the reverb tank from the amp in any other way?
Old October 12th, 2006, 03:27 PM   #8 (permalink)
oh, it is. i'm thinking about installing a V8 engine to go along with the wheels, so i can tear ass to the grocery store.
Old October 12th, 2006, 03:46 PM   #9 (permalink)
Twangbanger's Avatar
I need to do this to my Vox AC30CC2, boy it's heavy!
On my 4-10 deville, I also used the ernie ball casters. It's easy and quick. Just take your time and lay it out so everything lives up and fits.
Play'n tele till I drop!
Bryan Hibler
Twangbanger is offline   Reply With Quote
Old October 12th, 2006, 04:10 PM   #10 (permalink)
Glen W's Avatar
How's these?
Go big... or stay home.
Glen W is offline   Reply With Quote
Old October 12th, 2006, 04:11 PM   #11 (permalink)
That's awesome, do they make a version for a vox or twin?
Bryan Hibler
