Old October 4th, 2006, 10:13 PM   #1 (permalink)
Deluxe Rev Vs Twin Rev
is there a major difference in tone between the DRRI and TRRI?
other than the twin being twice as loud. and a mid knob
aznxtasy341 is offline   Reply With Quote
Old October 4th, 2006, 10:23 PM   #2 (permalink)
Yes there is.
1. 6V6 versus 6L6 power tubes.
2. Headroom/breakup/overdrive/clean tones will all be different.
3. 1x12" versus 2x12".
4. The circuits are NOT similar enough to run down as a Mid knob being a simple difference (by the way, how Mid controls work on amps is interesting reading, Google "baxandall" tone controls and to see what I mean - if the article compares it to a normal guitar amp's tonestack).
Two very different amps... but with all guitarplayers, tone is very subjective.
You'd always see them old blues players just plug into anything on hand without batting an eyelash (and sometimes their tone just flat out sucked!!)... you may like both, or only one of them, or you may even think they sound similar enough to not bother with the details - afterall, some folks love SS amps, modeling amps, or tube amps differently.
Old October 4th, 2006, 11:29 PM   #3 (permalink)
tazzboy's Avatar
You also forgot to mention Johnny
Deluxe Reverb is about 22 watts and Twin Reverb are 85 to 100 watts.
tazzboy
Old October 4th, 2006, 11:30 PM   #4 (permalink)
tazzboy's Avatar
ALso there is difference in wattage too 22 to 30 for the Deluxe Reverb and 85 to 130 watts for the Twin Reverb
tazzboy
Old October 5th, 2006, 02:10 AM   #5 (permalink)
Tremo's Avatar
Deluxe Reverb is in the vicinity of 20 Watts. 30 Watts no way.
The tone stack and preamp design between a Deluxe and a Twin are nearly identical. Very similarly voiced, but radically different power supplies and output sections.
Old October 5th, 2006, 01:48 PM   #6 (permalink)
jdfoosh357's Avatar
A Twin will fill the room better, sound fuller, deeper. I like twins even at very low volumes for practicing. The limitations, if they pertain to your sound.....a twin will never overdrive like a deluxe (at reasonable volumes), twins are bigger/heavier to transport.
If you play clean and have a good back......get a twin.
jdfoosh357 is offline   Reply With Quote
Old October 5th, 2006, 02:17 PM   #7 (permalink)
The DR will do clean TR sounds at a low volume. The TR will not do the power tube heat that a DR will do at higher volumes.....or by the time the TR does start to yield power tube distortion, you would best be in a large space or outdoors.
Old October 5th, 2006, 03:27 PM   #8 (permalink)
tazzboy's Avatar
If you get the Current Professional Tube Pro Twin it has 100 watts and 1/4 power switch which will make it 25 watts for clubs and bedroom playing.
tazzboy
Old October 5th, 2006, 05:53 PM   #9 (permalink)
leewhit's Avatar
I always felt Deluxes were more "in your face". Anyone else hear it this way?
leewhit
leewhit is offline   Reply With Quote
Old October 5th, 2006, 07:37 PM   #10 (permalink)
beachkos's Avatar
Just my humble opinion.....
or not so humble opinion It seems to me, after playing for over 40 years, that the Twin is the amp by which all other amps are compared and judged. I believe the Twin sets the gold standard for an all around amp and welcomes all challengers to take their place in line behind it. Why are so many amps described as "having a Twin sound", or "resembles a small version of a Twin", or "sounds like a Twin at low volume" ? Why are so many amps advertised as being "almost like a Twin" ? Boutique amps. modeling amps, and DSP's all try to emulate the Twin. The bottom line is a Twin is a Twin is a Twin - anything else is just an impostor or wanna-be - Fender may not have always gotten everything "right" in all it's years, but the one thing they did get right remains the benchmark in the industry, be it Tweed, Black Face, Silver face, or re-issue.. Fender and other manufacturers have produced many fine amps throughout the years, but trust me, there ain't nothing like a Twin.
My 40th Anniversary Re-issue Twin
"The key to avoiding a shark attack isn't necessarily in being able to swim faster than the shark, rather the key lies in being able to swim faster than the person you're swimming with. "
Beachkos - circa 1972
beachkos is offline   Reply With Quote
Old October 5th, 2006, 08:30 PM   #11 (permalink)
so for a bout 300 dollars difference, the twin should be my path?
as a side thing: i mainly play piano, so it'd be good if i could use this as a keyboard amp too. fender makes a twin with a 15" speaker, if i want to put a keyboard through it as well, is this my tree?
Old October 5th, 2006, 10:07 PM   #12 (permalink)
Tremo's Avatar
Guitar amps and keyboard amps are voiced differently. Keyboard amps are more of a flat response. Fender guitar amps have a fair amount of mid scoop.
Old October 9th, 2006, 06:11 PM   #13 (permalink)
beackkos: Could not have said it better. I've also been playing over 40 years, but haven't been playing out since the 60s, when I had a Bandmaster. I could never rationalize a Twin for my basement so I've had Princeton Chorus, Deluxe, Cyber-Champ, and Hot Rod Deluxe, and several other Fender Amps I can't remember. Recently an opportunity came up to pick up a TRRI and I bought it and sold my HRDX (also a great amp). I laughed at my self, but it sounds great ... even at 2. I play through a Boss ME-50.
Last Friday I was at GC and did a ABC comparison between the HRDX, a DRRI, and a TRRI. The Twin was clearly the best and I actually preferred the HRDX to the DRRI. If you can handle the weight, look around for a good deal on a TRRI. If not, at least try a HRDX ... it might surprise you ... and the price is right.
wilerty is offline   Reply With Quote
Old October 9th, 2006, 07:04 PM   #14 (permalink)
tiktok's Avatar
That's probably why Jim Marshall, for one, cries himself to sleep every night--his inability to better the Twin Reverb.
It takes two people to paint a perfect painting: one to paint it, and the other to shoot him when it's done.
http://www.myspace.com/travishartnett
http://www.myspace.com/sugarcanemutiny
http://www.myspace.com/davidbavas
tiktok is offline   Reply With Quote
Old October 10th, 2006, 02:11 PM   #15 (permalink)
I love my DRRI, but if you play a Twin for more than 5 minutes at a reasonable volume, you will realize it is something special. It is clearly the muscle behiine the Fender sound. So cutting and clear, almost uphoric. (sp)
"Yeap, I like the American Standard Telecaster, I can even live with one a them PCB amps, and I even use one a them mul-tie-effects things too."
Darrell is online now   Reply With Quote
Old October 10th, 2006, 07:23 PM   #16 (permalink)
beachkos's Avatar
Victoria
As I stated, there are certainly some very good amps out there other than The Twin, and I'm sure Jim Marshall sleeps very well at night, sheds no tears, and is very content with the fact that he and his amps will always be Number 2 compared to Fender - however, his daughter Victoria, his successor, suffers from incurable insomnia, due to the fact that she knows Marshall will never better The Twin in her lifetime
Regards, Gary
Old October 10th, 2006, 07:28 PM   #17 (permalink)
63dot's Avatar
can't stand the twin unless i need to play it very loud when the character comes out
with a deluxe, you can get that character at a much lower volume and if you are in a club and the deluxe is not loud enough, mike it through the PA system
63dot is offline   Reply With Quote
Old October 11th, 2006, 12:16 AM   #18 (permalink)
Rich Rice's Avatar
I've certainly had my share of Fender amps, including the Professional Tube Series 100 watt Twin. (By the way, it was a fabulous amp) I currently have all bases covered, and although the amps differ electrically, the lineup is pure heaven, and each one picks up where the other leaves off.
1972 Deluxe Reverb - 22 watts through a JBL K-120
1974 Pro Reverb - 45 watts through a pair of 12" Jensen Neo's
1972 Vibrosonic Reverb - 100 watts through EVM 15L
Silver face Fenders are workhorses, and I LOVE the tone.
Having the Twin was redundant, but I loved that one, too.
Please visit my website!
If you are driven to play, you will find a way.
Old October 11th, 2006, 05:21 AM   #19 (permalink)
I have been playing county since the 70's and have used both the Deluxe and the Twin. To tell you the truth to me a Deluxe sounds just the same
as a Twin, it's just the Twin has enough power to work almost any venue
you can imagine, where a Deluxe is a bit more calmer, and more sutible to
smaller venues, and as listed earlier they tend to start to break up
a bit more earlier on the higher volume than a Twin. I now use a 70's Silver Face Twin and I love it. Yes it is heavy to carry, but the tone is just so good. Puts the Twang in your Tele for that nice Brent Mason tone.
Telewringer is offline   Reply With Quote
Old October 11th, 2006, 08:32 PM   #20 (permalink)
new question: has anyone ever tried the epiphone blues custom? is it any louder than the DRRI? hows the drive channel and break up
Old October 11th, 2006, 11:54 PM   #21 (permalink)
jdfoosh357's Avatar
I spent the last weekend trying out amps at my Guitar Center, here are my very generalized experiences....
The Deluxe and the Twin (both SF, non-master volumes) were very similar in the tone stack, as said above. Both are very sparkly and have a scooped midrange, what I think of when I hear classic Fender sounds. The Twin, however, moves a lot more air and fills the room a lot easier, even at low volumes. The Deluxe will start to break up at about half volume, and the Twin will sound clean and big all the way.
I also tried some SF Vibroluxes and they sounded great too. It's a punchier, more "in your face" sound. Less scooped, more mids, a very good tele sound. While the SFVR is punchier, which is a positive for me, it can't get as low as an amp with a 12" speaker. So there are obviously tradeoffs. The Vibrolux seemed to move more air than the Deluxe at comparable volumes. I can see a reason to have this amp as well as a Deluxe or a Twin.
Size and weight is another story...
Old October 14th, 2006, 09:11 AM   #22 (permalink)
jdfoosh357: If you were at a Guitar Center and trying a Twin at over half volume ... they must have loved you there ...
The Vibrolux is infamous for being noisy, does not have the low end of a Twin and costs almost as much. It does weigh 19 lbs less.
Old October 14th, 2006, 11:39 AM   #23 (permalink)
jdfoosh357's Avatar
Haaaaa, ya I can see how they might have been annoyed. I did give like an hour trial to each of 4 different amps. Hey, I try before I buy. But I came home with a '69 DR, so my sales guy was happy at least.
Jon
