Old August 15th, 2006, 09:27 AM   #1 (permalink)
44deluxe's Avatar
Best place to find output transformers for SFDR?
Any recommendations for replacing the non-original output transformer on my '73 Deluxe Reverb?
I'm not fussed if it's original or a replica as long as the specs/sound are similar.
Thanks in advance.
44deluxe is offline   Reply With Quote
Old August 15th, 2006, 09:52 AM   #2 (permalink)
joe c's Avatar
Allen sells a fine ot
joe c is offline   Reply With Quote
Old August 15th, 2006, 10:01 AM   #3 (permalink)
44deluxe's Avatar
Thanks mate, I'll check out their site
BTW, do I have to watch for voltages being in the UK?
Sorry if I'm being stoopid, but I don't want to order the wrong one!....
Old August 15th, 2006, 10:29 AM   #4 (permalink)
joe c's Avatar
Opps ! Wow UK . Not sure about the OT then. Allen would be a good place to start.
Old August 15th, 2006, 10:53 AM   #5 (permalink)
Dacious's Avatar
Do you want the ouput or power transformer? The output transformer is wired to the tube sockets on one side, and the speaker wire on the other.
The power transformer is wired to the cable and plug to the wall socket, almost always through a fuse and the mains switch.
If you want the power tranny, you will need an export 240 volt unit to match your wall voltage. Apart from the Fender DRRI or an old stock version, it's hard to think who makes one. I would find a transformer winder and get one made - you can spec better double-insulated hi-temp wire which many current production versions don't have.
If you want the output transformer, there is no difference as the tubes operate at 400+ volts regardless of the AC version. There are good current production versions still being made by the original company. Triode Electrics and others sell a version quite cheaply and Triode now has it's own version on a paper bobbin, with extra impedance taps and even ultralinear taps if you want to try that.
Triode Deluxe Reverb Output Tranny
Old August 15th, 2006, 11:00 AM   #6 (permalink)
44deluxe's Avatar
Someone has to live here!
The only problem with the Allen site is that it's getting me gassing for an Accomplice Still, they look like they have what I need
Old August 15th, 2006, 11:03 AM   #7 (permalink)
44deluxe's Avatar
Yep, it's definitely the output transformer, I just don't know much about how tube amps work yet and didn't want to buy the wrong one
Better to ask a dumb question than make an expensive mistake.
Appreciate the link dude , I'll take a look....so these guys made the originals?
Old August 15th, 2006, 11:29 AM   #8 (permalink)
Mitch Roberts's Avatar
It's pretty widely accepted by many, many techs and players that Mercury Magnetics makes the best trannys, but they also cost more. If you treasure your amp and intend to keep it a long time, I wouldn't think twice about it - spend the extra few bucks. The OP tranny is especially important to your amp's tone. There are many other sources not already mentioned: Mojotone, Hoffman, Ampwares, Angela, TubeToneAmps, and I'm sure there are more.
I think, therefore I jam.
Mitch Roberts is offline   Reply With Quote
Old August 15th, 2006, 11:54 AM   #9 (permalink)
44deluxe's Avatar
Cool, I'll check them out too..
I've pretty much brought this amp back from the dead so a few pounds extra now don't bother me, I'm going to be keeping it a loooooooooooong time
Thanks for the tip
Old August 15th, 2006, 02:16 PM   #10 (permalink)
joe c's Avatar
[quote=44deluxe]Someone has to live here!
Old August 15th, 2006, 04:37 PM   #11 (permalink)
JoePops22's Avatar
Another vote for Mercury Magnetics. I changed the OT and choke in my DRRI. Made a huge difference. I didn't compare prices with some of the manufacturers already mentioned (Allen, Hoffman, Mojotone) so you might get one of those for less money than a MM but I have no regrets.
The OT, the "old timer"
JoePops22 is offline   Reply With Quote
Old August 15th, 2006, 07:39 PM   #12 (permalink)
CancerLeoCam's Avatar
Antique Electronics www.tubesandmore.com
CancerLeoCam is offline   Reply With Quote
Old August 15th, 2006, 08:03 PM   #13 (permalink)
Tremo's Avatar
MM if you want top shelf. Allen as #2. Otherwise. Mojo, Magic Parts, Antique, etc...
Old August 15th, 2006, 08:12 PM   #14 (permalink)
Dacious's Avatar
If you want originality the originals are available pretty much how they were made from a variety of vendors. Angela Instruments has them, as does Hoffman and others. Of course the datestamp will identify that it is not original to the amp.
Old August 15th, 2006, 11:12 PM   #15 (permalink)
zook's Avatar
best bang for the buck
I highly recommend the transformers from Ted Weber. They are reasonably priced but are well made and sound great. I used the DR OTs in a couple amps and am very please with the results.
W041318 125A1A
$20.00 25 Output Transformer for Deluxe, Deluxe Reverb, Tweed Tremolux
Winnie
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser
zook is offline   Reply With Quote
Old August 15th, 2006, 11:41 PM   #16 (permalink)
lostpick's Avatar
How do Output Transformers effect tone??
Is a chintzy OT like using too small a gauge spkr wire?
Starves the low end??
One TDPRIer said the small OT on his Pro Reverb
gave his amp a singing quality??
lostpick is offline   Reply With Quote
Old August 16th, 2006, 12:55 PM   #17 (permalink)
I would agree with Zook that Weber has good transformers there. I've used them and they work great.
