Old April 6th, 2003, 11:43 PM   #1 (permalink)
timmc's Avatar
1x12 or 2x10 combo?
I am considering a Bad Cat Cub II 15 watt combo but must decide between a 1x12" and a 2x10". I've read what Bad Cat says about either configuration choice but I still have a couple of questions. What do you Tele players prefer? Would the choice of a combo with or without reverb affect your choice of speaker configuration? What if I went with a different Bad Cat amp that has a higher wattage--would your choice in speaker configuration change?
timmc is offline   Reply With Quote
Old April 7th, 2003, 03:12 AM   #2 (permalink)
Baard's Avatar
It depends on what you like
I like the sound of 10´s so I have a super reverb with 4 10". For miking it up, you would get a louder sound from one source(a 12") than from one of the 10´s in a 2x10 configuration. That might also be something to consider. Anyway that´s just a thought I´ve got, not something I know, so others might correct me if I´m wrong. Another thing is that I find the SR 10´s a bit easier to mike up, to get a good sound in the mix. They are a bit more focused than my old HRD´s 12" but that might be the different amp. Different makes and models would also sound different, even in the same dimentions.....It´s not that simple.....
Baard
Baard is offline   Reply With Quote
Old April 7th, 2003, 07:20 AM   #3 (permalink)
Smokey's Avatar
Not sure what speakers are in those, but the 10's might have a lower wattage and could tend to breakup earlier than a 12.
Generally speaking that is. ;)
Smokey's Forums
Smokey is offline   Reply With Quote
Old April 7th, 2003, 08:06 AM   #4 (permalink)
Poppatwang's Avatar
I like two 10s.Seems to work better in a band context.
Comes through the mix.
Poppatwang is online now   Reply With Quote
Old April 7th, 2003, 10:58 AM   #5 (permalink)
cowboy's Avatar
That is a good question....
I have amps with 1-12 (BFDR & JJ-30), 2-10's (Matchless Lightning w/reverb, and 4-10's (BFSR). I generally find the 10's to be a little more focused but it's hard to beat a good 12". Kinda a question of apples vs. oranges. I find the amount of wattage, type of tubes, etc. will also make a difference.
Having both a 1-12 & 2-10 Matchless is hard to compare because of the difference in wattage (40 vs. 15). I'd guess that the 12 will give you a little more punch but the 10's will provide a tighter bass. How many watts is the Bear Cat?
I'm sure that there are people in here that can give you a better answer but any of the Matchless/BearCat amps are killer. later.
wilbur
my dream is just a couple of notes with some passion and soul.........
cowboy is offline   Reply With Quote
Old April 7th, 2003, 12:46 PM   #6 (permalink)
RickC's Avatar
my general rule of thumb is that 2x10s sound better than 1x12s. You've got more total speaker surface area in the 2x10 configuration, plus I believe there's something about the interaction between more than one speaker that fills out the sound in a nice way.
/rick
RickC is offline   Reply With Quote
Old April 7th, 2003, 01:00 PM   #7 (permalink)
timmc's Avatar
Re: That is a good question....
The Cub II is 15 watts.
Old April 7th, 2003, 01:43 PM   #8 (permalink)
timmc's Avatar
Thanks, all of you for posting, or for just plain reading the post. This is a great place we have here--thank you, Paul
I think it will probably be a 2x10" when I take the plunge. I already have a 40 watt Blues Pearl Verbrasonic with two 10" Jensens in it . I plugged in my new Silver Sparkle Telecaster, that I bought from Music One Workshop, with the Texas Special pups, selected pup position 2 (of 4) and turned The Verbrasonic up to 9 last night. It was tone heaven--so much so that I asked myself if I really needed a Bad Cat Cub II, but I really need something to fill the bill between my Vibro Champ and Champ and the Blues Pearl.
Old April 8th, 2003, 06:13 PM   #9 (permalink)
tom grossheider's Avatar
I like 1x12 for portability, but 2x10 has the edge in tone. Better yet, 2x12 is the cat's meow......
tom grossheider is offline   Reply With Quote
Old April 8th, 2003, 06:31 PM   #10 (permalink)
Jay Jordan's Avatar
bad cat
i have the Cub II with reverb in 1 / 12......
it is unlike any other single 12 I have ever played
I'm sure it has to do with the speaker
2/10's are good too and I have played many but in the Bad Cat the 1/12 sounded best to me so that's what I went with.....
hate to say it, but your other amps are gonna become fixtures that need dusting....
those Bad Cats can't be beat.....
Jay Jordan is offline   Reply With Quote
Old April 9th, 2003, 02:44 AM   #11 (permalink)
Buckshot's Avatar
I like 'em both!
Leo Fender got it right the 1st time - its been downhill ever since!
Buckshot is offline   Reply With Quote
Old April 9th, 2003, 03:49 AM   #12 (permalink)
timmc's Avatar
Wow,
it sounds like I can't go wrong either way!
Old April 9th, 2003, 03:52 AM   #13 (permalink)
timmc's Avatar
I'll be in enough trouble buying the Cub, let alone if I would try to spring for the Black Cat.
Old April 9th, 2003, 05:30 AM   #14 (permalink)
Rob DiStefano's Avatar
IMO, a good 2x10 typically just sounds "larger" and smoother than a good 1x12. But, for portability, I'll take a good 1x12 combo any day.
Old April 9th, 2003, 12:58 PM   #15 (permalink)
sshan25's Avatar
2 X 10
I can't speak for the Bad Cat, but I have a Dr. Z Maz 18 Jr. 2 X 10 which is similar in concept (and a better value IMO). I checked out the 1 X 12, 2 X 10 & 2 X 12 versions. I found the 2 X 10 to have the best combination of overall tone, smoothness and bottom end of the 3. YMMV.
There's no such thing as too many guitars
sshan25 is offline   Reply With Quote
Old April 9th, 2003, 07:43 PM   #16 (permalink)
Bluesbob's Avatar
I'll be finding out
I'm having a 2X10 cab built for a '68 Bassman head. I already have a couple of 1X12 combos, a SFDR and a Mesa Son of Boogie. I'm hoping for a cross between a super and a vibrolux sans reverb. I'll post a review when it's done.
What, me worry?
Bluesbob is online now   Reply With Quote
Old April 9th, 2003, 08:18 PM   #17 (permalink)
Kingpin's Avatar
Bad Cat Cub II
Those Bad Cat Cub II's are great sounding amps, the overdrive is fantastic. I've played through the 2X10 version and loved it. I really like the high end response that 10's can give you. A 2X10 combo will move more air and sound bigger, it would be my preference if the choice were mine. Either way you go you'll be getting a great amp. Cheers.
Bring on da Twang
Kingpin is offline   Reply With Quote
vB code is On
Forums Directory
