Old June 7th, 2006, 02:21 AM   #1 (permalink)
OLAF MELCHER's Avatar
Biasing Silveface Deluxe Reverb
Hi,
can anybody tell me if my Silverface Deluxe Reverb from 1971 has an adjustable fixed bias (seems so) and where to locate the bias pot ?
Thanks
Olaf
jazzjoker
OLAF MELCHER is offline   Reply With Quote
Old June 7th, 2006, 03:22 AM   #2 (permalink)
Yes, bias pot.
You'll have to remove the amp chassis from the cabinet.
Inside it's the small flat-head screwdriver adjusted pot... it's a small 10k deal.
It'll be on the end of the amp/board that is closest to the big power transformer as opposed to the end where the preamp tubes/inputs are.
If you're not sure how to bias - I'd leave it alone and have an amp guy do it... if you've got a multimeter and know what you're doing - go for it. It's not hard if you know what you're doing.
Silverface Deluxe layouts are hard to find... at least for me :)
Schematics are everywhere though...
If that didn't help I should have another shot... too bad rum's all I've got left :(
Old June 7th, 2006, 06:08 AM   #3 (permalink)
Thanks Johnny - very helpful.
Best regards
Olaf
jazzjoker
Old June 7th, 2006, 09:52 AM   #4 (permalink)
Administrator
I got a "Bias King" just for this purpose and it makes biasing even easier.
Here's a link:
http://www.biasking.com/
Paul Green
TDPRI is offline   Reply With Quote
Old June 7th, 2006, 08:52 PM   #5 (permalink)
LK
There should be a adjustment hole ( it will look like a 1/4 guitar jack on the underside of the amp chassis) You can adjust the bias here with a flat blade screwdriver, if you have a bias rite. Very easy to find.
LK
LK is offline   Reply With Quote
Old June 8th, 2006, 11:50 AM   #6 (permalink)
shouldn't one be cautious when trying to bias an amp from the inside, due to possibility of electocution? 450+ volts and the amperage that these amps carry could be lethal. unless you are experienced, stay away!!!
jackleg is offline   Reply With Quote
Old June 9th, 2006, 08:05 PM   #7 (permalink)
LK
Be very cautious about doing anything inside the chassis of a amp. If you use the adjustment on the underside of the chassis you have nothing to worry about, as you are not touching anything inside the amp.
LK
Old June 9th, 2006, 08:11 PM   #8 (permalink)
You still have to be able to use the meter to check the voltage while adjusting...
Like I said though, "if you know what you are doing"...
Otherwise you could end up with dead power tubes, or worse yet, a dead guitar player!
-Danger High Voltage-
