Old May 11th, 2006, 09:38 PM   #1 (permalink)
mojohen's Avatar
Fender-channel jumpering?
on my 68 SR?
Any reason why I couldn't jump channel 1 first input with the vibe channels first input? If I cqan without damaging anything, what results could I expect?
I could only assume that V1 would then be used along with V2 and V4, so more gain? Maybe earlier breakup?
Just pondering...
Oh, and I just inserted a janGE5751 in V1 with great results. Nice wark and harmonically rich..Less volume, purring gain at lower volume...Nice..
mojohen 8)
mojohen is offline   Reply With Quote
Old May 12th, 2006, 10:01 AM   #2 (permalink)
If I remember right, left channel on the SR is no reverb. If that's the case, it won't work. won't hurt anything, but it will sound very odd, out-of-phase due to unequal number of gain stages on the linked channels.
As long as gain stages are equal, jumpering usually works, and is usually very much worth experimenting with. Certain amps (my old Gibson GA40) get way excited when you jump channels. I never play this amp w/o jumpering. One channel is much hotter than the other. I can blend that in, almost like an in-amp OD.
Jumpering gives you the ability to tailor sounds to the instrument. For example, I run a strat through my Clark Typer into normal, volume on that pretty high, then into the Brite channel, volume on that one maybe 1/3 up. Were I playing a HB guitar, I'd reverse it.
You lose a little signal in the second, jumpered channel. For full signal, use an A/B/both buffered switcher. Same principle, maximum strength.
mad dog is offline   Reply With Quote
Old May 12th, 2006, 10:25 AM   #3 (permalink)
tlpruitt's Avatar
Out Of Phase
Mad Dog is correct. Unless the amp has been modified to have reverb on both channels (a relatively simple mod) the 2 channels are out of phase. If you link or jumper both channels so you are playing through both at the same time then it will not sound good since the 2 channels are out of phase. No harm to the amp, just poor sound. Try it and see for yourself.
You can get around this by modifying the amp to have reverb on both channels (which puts both channels in phase with each other) or use something like the Barber Launch Pad pedal to put your signal into both channels.
BTW, the 2 channels are in parallel so playing in both channels at the same time isn't really "adding" a gain stage.
-Tim
Art is making something out of nothing and selling it.
FZ
tlpruitt is offline   Reply With Quote
Old May 12th, 2006, 04:34 PM   #4 (permalink)
You can do it, and it won't hurt anything. It can be useful.
Just don't run the volumes at the same level; that's where there is the strongest cancellation. Instead, offset them- one higher, the other lower. If Normal is higher, the Vibrato channel functions much like a tone control for the reverb and tremolo. There are also some interesting blues sounds.
It doesn't do anything to the gain, though.
There's a similar trick that involves connecting the reverb to the Normal via a patch cord.
5965 is offline   Reply With Quote
Old May 14th, 2006, 10:12 AM   #5 (permalink)
vic108's Avatar
From what I understand too....
Guitars will get you through times of no money better
than money will get you through times of no guitars
vic108 is offline   Reply With Quote
Old May 15th, 2006, 09:56 AM   #6 (permalink)
PhatTele's Avatar
The out of phase issue will cause things to sound "bad" or "odd' if you jumper the channels using just the input jacks. However, as someone mentioned above, you can run a patch cord (with some RCA to 1/4" adaptors) from the reverb recovery ("out") into the input of the Normal channel. I've seen it done live in a BF Pro Reverb. It works pretty well. You're basically taking the wet part of the reverb signal and running it back through the other channel of the amp.
vB code is On
Forums Directory
