I have one and think it's a great amp - I'm probably going to sell it because I just am completely in love with the blackface fender sound, but the Maz 18 Jr is a top notch amp all around.
Tone wise it reminds me alot of a saturated AC30, with a little Marshal oomph mixed it. It's loud for 18 watts, but it also breaks up early with a nice grainy overdrive that is typical of the DRZ sound. Very flexible tone controls and I really like the Cut and Master Volume. Hard to go wrong with it really.
It's not a lie if you believe it..... |
Very versatile amp. Can twang, clang, and growl. Takes pedals well. Tends to be a little on the bright side but easily controlled with the tone stack. Master volume is very useable.
I have a 1x12 with verb and I love it. If I had it to do over again I'd buy a non-reverb head and either a 2x10 or 2x12 to go with it. For a lot more opinions, check out the Dr. Z forum: http://drzamplifiers.proboards41.com |
I've got a 1-12 Maz Jr and love it. In fact I love it so much I've got a second one coming a MAZ jr NR head.
For me its the ultimate tele amp. Just loves any pedal I've ever put into it and at 18 watts is plenty load enough. Highly recommended! |
Easily the best amp I've ever owned.
I do find them very versatile, although there is a definite jangly quality that I like specifically. I don't know how else to describe other than a complex chime type of thing. It's got lots of low end grunt. The key to this amp is how it cuts through perfectly in a band situation. You'll know what I mean when you try it. Probably the most important thing I've found with this amp is to keep those EL84 finals up to snuff - they run hot and as a result tend to go through those finals pretty quickly. If you're a metal player, perhaps I'd steer away, but for pretty much anything else, it's a solid winner in my books, especially for country pickin'. That's my .02. Cheers, Shawn
best amp i ever owned.
i got the 2x12" NR version with Weber Blue Alnicos and it is hard to describe - it shimmers . as already said, itīs really loud for 18 watt, though itīs rumoured, that it is more around 25 watts. superb feature is the cut pot, allows you to dial in the amount of "cut" through the mix. i personally think this amp is best when played clean with a grit in the end. metal lovers will not like it. it takes good pedals very easy and is well build. i can only recommend it. take care zoppotrump :O)
may the twang be with you ! |
2x10 w/verb owner here. Excellent amp with a blackface heart and marshall/vox spirit. It's a difficult amp to sonically quantify but overall characteristics are a chimey and throaty combo with lots of EQ options. Loud sum*****, too. Speakers do need to be broken in and the reverb won't satisfy die-hard blackface fans. Just a dab will do ya fine; beyond that it robs tone and clutters the sound. I think the brightness of the amp is often overstated and misunderstood. It's has a sinewy but focused projection and the brights will be harsh if not tamed accordingly. Approaching the tone stack and adjusting knobs old school Leo settings may disappoint - unless your high end hearing appreciates a cutting tone. Little dollops of treble, mids, bass, etc can totally deliver a big, phat tone. The best attribute of the Maz 18 is has big it can sound but still have a chimey and thumping projection without being farty or muddy. Perfect arrangement for single coils. I really like the Maz 18 but if I had a *do over* I'd bag the reverb. I was thinking blackface sparkle but it's not even close. Just enough to add some ambiance to a flat room but totally negotiable at proper volume levels.
