the DR can do surf at some low volume level. To really do the thing, get a TR. Or, if money is no problem, get a Blonde Showman with a Fender reverb unit. This is the rig that Dick Dale had Leo build for him. If you have ever seen Dale perform, you will understand what he is going for... big volume, clean sounds, good reverb...and a lot of hard work and sweat. You need an amp that can do clean at whatever volume you want, but with a drummer, imo a DR is about 60-100 watts short. The minimum imo would be a Super Reverb. You could get away with that at moderate volumes with a controlled drummer and bass player, maybe.
Ideally, you want high watts (for clean headroom), big speakers, built in reverb and tremolo.
In other words, a Twin or Showman Reverb.
http://www.myspace.com/jameswilsey |
Thanks for the info
Unfortunately money is always an issue. I should have been more specific. Amp for livingroom run into mix board with a REV 7 rack reverb. Price range $500 - $800. Thanks again for your help.
employee discount? |
I would suggest an early 70's Twin Reverb. Used prices are nearly exactly in that price range. Fender reverb is classic surf. And a Twin doesn't need mic'd, so you can save that P.A. for vocals and such.
For the classic surf tones an outboard reverb unit is a must have.
Some of the current surf bands are doing well going a little less wet on the verb and a touch of overdrive. Los Straitjackets for example, using SF Vibrolux reverbs. Surf Coasters are really hot on the circuit now, and their guitarist has really good tone (not to mention chops). I think I heard he usually uses Vibroverbs+reverb unit. When discussing best surf rigs, my cohorts and I came to the consensus of Tremolux+reverb unit+Jaguar as the ultimate surf rig. |
#9 (permalink) | |
Re: Thanks for the info
Silverface twin's are around $600 and so are Bandmaster Reverb's. You can find a Dual Showman with a two 15 cab for around $500-$600 and then get a RI reverb unit for $200 and still be in your price range of $800. If you want an old Deluxe then your looking at $1200 to $2500, unless you go with a used reissue one.
Alvin http://www.myspace.com/alvinblaine http://www.oldbluesound.com/about.htm _________________________ Originality is just undetected Plagiarism! |
Any Twin Reverb with Altecs, EV's, or JBL's and You've got it OR any Fender with an Outboard Reverb Tank.
I really LOVE the "Surf Tones" that Magic Sam gets on both "West Side Soul" and especially "Black Magic" and if I'm not mistaken Sam's going through either an Epiphone Rivera or a Strat with an Ampeg. Frankly I believe that Magic Sam had the greatest Surf Tone of all of 'em. Listen to "What Have I Done Wrong" and you'll get the picture.
Somebody Loan Me A Dime |
Thanks all for the great information
Couple other questions. Could a Fender Princeton with a different speaker and a Holy grail peddle be convincing? With your information it's clear I need a speaker that will not break up easily. Remember this is for my home and 15 watts can be pretty loud. Also when you all mention JBL or other speakers could I ask the model number? Thanks again.
#14 (permalink) |
From what I have heard, seen and listened to...
..nothing beats a Twin or a Showman with a reverb tank. The TR is gonna be the best value here as a Showman, speaker cab and reverb tank are really pricey as a package-like ~3K compared to $600 for a used TR (and it has everything you need).
If you need convincing ask WickedGtr to demo his amp and you'll never think twice. When it came time for me to buy an amp I remember seeing him play one at a gig in '97 with The Mysteries and said.."If I'm buying an amp that's the amp I gotta buy." You CAN use smaller Fender amps for just about anything ...it all depends on what volume you need. The tweed amps will not be what you need so stick with the blonde, brown or blackface amps. Gluck. |
#15 (permalink) | |
Re: Thanks all for the great information
#16 (permalink) |
Among other stuff, I play surf and use a BFDR along with a Fender Reverb Unit and it's plenty for 80% of the gigs I do. I've opened for Dick Dale a couple of times and his tone ain't as clean as you think - he's got those Dual Showmans running wide open and there's a lot of delicious power tube distortion. Of course, the soundman rarely needs (or wants) to put his guitar through the PA at that volume ... :)
#17 (permalink) |
Another great surf amp on a budget is the Traynor YGM-3 (made in 60's and 70's). I own one, and that's mainly what I use it for. It's similar to a Fender DR, but IMO has much better tremolo. They can be found for pretty cheap. Their only shortcoming is they do have some dirt at very high volumes. I seem to be able to keep that under control running it into an extension speaker at the same time though.
#18 (permalink) |
I would not settle for anything other than vintage Fender or Ampeg reverb. Amp reverb should do just fine unless you're getting into gradations of reverb perfection.
Even if you are playing at relatively modest volumes, I'd get a big surfy speaker, especially for a single speaker amp. The Weber California series works well with just about everything, and also sounds good for more distorted styles. Some of the new Eminence line may be cheaper and would work for that style. EVs and JBLs are the standard for that kind of sound. Even if it's not going to be loud, you need it sounding big. Really, whatever volume you'll be playing at, I'd recommend a Twin. Contrary to received wisdom, they sound good at all volume levels and they are priced really well compared to the smaller models.
www.myspace.com/feierman |
#19 (permalink) |
Thank you all
Really appreciate your imput. Twin it is. If any of you have suggestions as to where to pick one up please e-mail me. I've been Ebaying, Googling and Asking without much success. Think I'll pick up a copy of Vintage Guitar and poke around their ad's. Again thanks for the help. I'm on my quest...
#21 (permalink) |
If you have trouble finding a good Twin, the '70's SF Vibrosonic Reverb is another often overlooked amp that would do it for you, and they sound fantastic. I have both Twin and Vibro, most times I prefer the Vibro. It has 100 watts, reverb, tremolo, and a single 15" speaker. My JBL D130F was in need of repair, so I installed a EVM15L. Killer amp, lots of everything... I like the 15" better than two 12's- personal preference. My son got a Vibro with a Gauss 15" speaker in it, again it needs repair... but I remember vividly just how great those big orange Gauss speakers sound.. amazing. These are usually a bit less expensive than Twins, too. Good luck!
Please visit my website! If you are driven to play, you will find a way. |
#22 (permalink) |
Moderator
some good sf cl
http://www.craigslist.org/sfc/msg/157128571.html
http://www.craigslist.org/nby/msg/155998255.html http://www.craigslist.org/sfc/msg/156518978.html Probably all worth the drive from Ventura! the quad twin would be a beast, but really cool... I toyed with buying that one just for playing really, really loud about twice a year... (which coincides with when one of my buddies visits and much makers is imbibed)
'never pet a burning dog' |
#23 (permalink) |
Actually unles you need blistering loud a 45 watt Pro Reverb combo or a Band Master head would do fine. We do some surf. My guitarist has an SF Twin and a Blues Deluxe - the Blues Deluxe had the speaker replaced and was re-tubed. It rocks for surf. Actually it rocks period. Those amps are sort of over-looked.
He just snagged a 22 watt 4x10 Dr Z and is now looking for the outboard rev unit. |
#26 (permalink) |
Any Fender amp with plenty of headroom and spring reverb will be good.
For Surf I'd really recommend the standalone Reverb unit though. For blues, Rockabilly... or ANYTHING the standard amp reverb is more than plenty good, BUT the standalone unit is almost required for the Surf sound... almost more important than the amp. |
