Twins at low volume...
I'm pretty sure that the Twin is the amp for me. I play at home mostly, but I get called out on random gigs every once in a while. I've got a Champ now, but it doesn't cut it. My budget now either allows for a DRRI or a SFTR. My buddy has a Twin and it sounds fine at home on volume 1 or 2 for practice.
I play country music, so it's almost always clean, and I like a big deep sound. I figure I might as well get a Twin in case I ever need it (as opposed to a Deluxe or Bassman). My point is.......... If I don't mind lugging it around, will a Twin sound good at small gigs when I can't turn it up?? I can't have several amps. Thanks, Jon |
Sure!
I don't see why not...? If you leave it on 1 or 2 on the volume, you should have plenty of sweet, clear and strident tone for you to play any small gigs.
Since you said lugging one around isn't an issue (it is for most people), then I say go for it!! Play around with the mids, it will affect the overall volume as Twins have a particular tone stack, as you will soon find out. Good luck!
...a little less conversation, a little more action... |
#6 (permalink) | |
#7 (permalink) | ||
I'm actually building a really low watt version as a head unit. It's the old '54 Twin (5D8 circuit). That runs a pair of 6L6s at about 25 watts. |
#8 (permalink) | |||
You don't need an attenuator IMO. Good tones can be found with the volume on 1 to 2. If you need more juice, turn it up to 3-4 and just use the volume on your guitar to control the overall output. Don't buy gear that isn't necessary...like an attenuator.
If you don't mind lifting 65+ pounds of amp, and as long as you don't drive the worlds smallest car, I don't see why you couldn't put the amp in your back seat, or even the trunk. Driving the rest of your bandmates may be another story altogether!!
#10 (permalink) | |
#11 (permalink) | |
Anyways, as far as attenuators, they never sound exactly like the amp fully does fully cranked, BUT with amps, I prefer natural compression over the stompbox ones... That being said, if you're looking for that bit of warmth and compression an amp has when turned up a bit, go for an attenuator OR, get an amp with lower headroom. Otherwise a Twin still sounds cool at lower levels :) |
#12 (permalink) | ||
Twins are fabulous Amps period !!!
Get a Sparkle Drive from Voodoo Labs. Set it & forget it. You can get some serious bargains on Silverface Twins. Do not delay.
Somebody Loan Me A Dime |
#14 (permalink) |
Moderator
Jon, have you tried your Champ with that speaker cab yet?
Cheers, Tim
http://www.moodswingers.org |
I say go for it, if you're young, strong, and willing to lug it around. Twins were meant for clean. If you don't need the cranked amp sound (a fact most posters are missing), then you've saved yourself money from extra doo-dads. :)
#16 (permalink) |
I just want to add. A Twin Reverb has the best Clean tone, and although it does get thicker and more compressed at high volumes, the tone is still all there at lower volumes. Also, They are loud, but, the difference from 4-7 is more in tone than decibels IMHO.
In my band, I use a strat with 11-58 strings, and run into a Super Reverb (40watts) and have a TS9/808 set for a clean boost. My volume is at 7-9 depending on the room. (7 for practice, 9 for large-ish venues.) This is loud, but not face melting..I hang well in the mix.We are a loud-assed band for sure. I'm not suggesting a Super Reverb here,(big cab) just giving an example of volume for a 40 watt amp... Try out the amps at volumes you'd use, and see what fills the bill. I'm thinking Vibrolux for size and power.. mojohen |
#17 (permalink) | |
I've got the Champ head I built running a 6L6 right now, and my output transformer is multitapped for 4, 8, or 16 ohm operation. With the closed back 2x12" Vintage 30s and 6L6... holy crap, that Champ kicks like a mule in the low mids/bass. With an EL34 it's got a real Led Zeppelin 1 "Supro" type of midrange quality to it. Anyways, yeah a Champ in a 2x12" has a bit more volume, but probably not enough for gigs, for most folks. |
#18 (permalink) | |
Re: Twins at low volume...
I've done every kind of gig with my twin (coffee house,weddings,outdoor fests etc) and I've never had a problem. Make sure to fatten things up that you run your mids all the way up,low bass 2-3.5 (just enough for umph, but not mud) and treble not too high 5-7. Keep the bright switch off. I only use 2 pedals,Maxon AD80 and an AnalogMan modified Tube Screamer(set for light grit) and get a very warm punchy sound at low volumes. This is my country rig and works for Bakersfield twang, western swing or anything else. |
#19 (permalink) |
Thanks for all your advice. I'm going to be looking out for a Twin, so it's time to start selling off a bunch of gear.
Edit: Now I have to decide whether I should splurge on a pre-1972 Twin or whether I'll go for the cheaper master-volume models. I've gotten mixed reviews about one being better than the other. Tim, The Champ definately has more punch with a 2x12 open backed cab, but at comparable volumes a Twin just has so much more fullness. I've been playing a buddies Twin lately at his house just for practice, and it blows everything else away for hot tele playing, etc. |
#20 (permalink) |
Twins are great at any volume. I really like the SFTRs with master volumes, as the MV works quite well and lets you dial in a little grit at manageable volumes. If you can carry it, why not. You'll never get surpised by a loud gig that overpowers your amp. If I was willing to carry the weight, it would be a SR. Different flavor of clean. That's a personal preference, not a judgement. I always look forward to plugging into twins, as long as i don't have to walk them in.
#21 (permalink) |
They sound great at low volume, and the tilt-back legs are useful. I've played some Master Volume models that were great- clean and distorted- with humbuckers. Dunno about s/c's; didn't have the opportunity.
The weight on them varies a lot depending on the speakers/magnets. Some of them aren't much more than Pro-Reverbs, and the backseat should be fine. If possible, being able to lay them down in a trunk would be a bit more stable and secure (for you and them). No recommendations on era, that's subjective, but good luck. |
#22 (permalink) |
Regarding which ones you should get I have been told to stay away from the 135W UL ones.
I also read about a neat mod that I am contemplating myself which amounts to disconnecting one of the speakers and adding a separate cord and plug so you can connect it to the external speaker jack. Then you have the option of removing two output tubes (inner or outer pair) and one speaker. Removing two tubes gives you the right impedance for one speaker (8 ohms). I have also enjoyed some success with Ruby Tone Bones although they change the tone a bit, not for the worse though, just different.... Harald One thing you could do is to |
#23 (permalink) |
I have a '76 MV Twin and love it. I don't like the sound of the 135W Twins though, they somehow sound sterile and if you are playing at vol. 1-2 then it's not the Twin for you.
I get great sound from the twin at any volume but find the "tone" really comes alive at volume 3 and over.
All those who believe in psycho-kinesis, raise my hand ! |
#24 (permalink) |
I got me a 1971 Twin (non MV) a few months ago and I´m so pleased with it. I have done some mods to it - I took it to a tech who replaced the filter caps and blackfaced it and I changed the speakers from the stock JBL D120Fs (didnt like them with my pedals) to a pair of Eminence Texas Heats. I believe the amp is slightly ligher after the speaker swap. I also got me a complete set of new tubes from Eurotubes.com. I´ve also done som minor tinkering inside (changing a cap here and there). The Twin suits me perfectly. I does sound good at low volume, but I use a THD Hotplate with it just to be able to drive it a little bit harder. You will not be drowned at the end of the gig when using a Twin - thers always some more volume on spare. It loves my pedalboard (but I have a A/B-switch so that I run my fuzz into thr normal channel with the treble on the amp down on 2-3).
#25 (permalink) |
Low volume with a Twin...
A couple of times using rented Twins in smaller venues, I much prefer the sound and feel with the amp volume on 8 or higher, and the guitar vol knob on 3 or 4. Treble and mids on the amp needs to be bumped up doing this. Less "narrow" sounding than a Twin on 1-2 with the guitar vol on full.
Hope this helps... Trev |
#26 (permalink) |
Question from Tjalla's post above ???
I agree having the volume up and guitar down sounds fatter. I like and use that for clean all the time. My question, how do you use an overdrive pedal with the amp volume up and guitar volume down? I use a TS9 or OD-3 and it seem both of those like the guitar volume to be hitting them pretty hard. Anybody have a trick to get around this situation? Thanks.
