Help fitting a new Weber speaker in my SFDR!!
Hi,
Some of you may remember me buying a SFDR off ebay last year and how my Uncle was going to look at it..... ....well.....it was (as many of you suggested) a bit of a stretch for him, which to be fair, he admitted. He took it to Barry Vyse (importer of the dreaded Torres amps....) and while he's a friendly guy, I was less than impressed with his service unfortunately. I ended up taking it to a local guy here (the founder of Maughan amps: http://www.maughanamps.com/)...his amps are the biz but they're HUGELY expensive Anyway, he's pretty much got the amp back working although it's still not 100%. I guess I bought a bit of a dud. :( The sound is SO sweet but it's crackly and the tremolo is still a bit "clicky".....I was also advised to upgrade the speaker so....I took some advice from this place :8 I've now finally received a new 12F150 but I need a hand to fit it..... ![]() How do I break through the black fibre blocking the holes? Is it a tricky job or can I just prod it with something sharp? Thanks in advance....sorry for the ramble! |
1.) just punch the holes....no biggie
2.) find another amp tech. With all due respect, you don't have a dud amp....you have a dud tech. ticking trem? a properly-placed .01uF cap will kill it dead. crackley? Plate load resistors, PS caps....even a rec tube can cause that. bad / dirty sockets can do that, too. Sounds like your tech....to be honest....doesn't have a clue.
"Progress is not possible without deviation from the norm." Frank Zappa |
#3 (permalink) | |
*contemplates emigrating* |
In a single-speaker amp, it doesn't matter.
There are those who say that polarity {incorrectly referred to as "phase"} matters & that you can hear a difference. I sure can't & contend that it doesn't matter, but I can't "tell battery manufacturers apart" in my pedals either. No hope for me, huh? :) In any case, you won't hurt anything.
#6 (permalink) | |
Fitting a new speaker...
I know That my routine is a bit overkill, but I like to remove both back panels, the chassis and the reverb tank when installing a new speaker, 1. you get to vacuum/clean out the inside of the cab, 2. If the old speaker sticks to the baffle, it will be much easier to get it out. 3. Installing is made easier as well by having a straight and clear shot at putting the speaker on the mounting studs...it's real easy to slip and punch a hole through the new cone if you're struggling to get around the backpanels, tubes, reverb, etc. 4. you can evenly torque down the speaker retainer screws. I use two fingers on an 11/32" nut driver. Best of luck! |
Be careful torquing down speaker bolts. I used to be one of the 'eh....eh...eh.....eh....' and one more 'eh' school of speaker bolt tighteners (que Cartman voice effects). You know, that sucker's not coming loose anytime soon.
Then I read an interview with James B Lansing (yes, he of Altec and JBL fame) about speaker design and application. He stated that speaker bolts should be no more than snugged down evenly - basically just past finger tight and retensioned on a regular if infrequent basis. Tightening them down too hard causes poorer sound reproduction and potentially issues when the frame and/or baffle distorts. I can't claim any vast sonic improvements but it seems to work pretty good on my Vibrolux. Just one to think about.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
#10 (permalink) | |
But I haven't noticed a difference in sound in a single speaker setup when I've connected a single speaker opposite of that and I can't imagine how it would damage a speaker. |
Having installed a weber ceramic in my BFDR, I can add:
It's a tight fit, can be done w/o pulling the chassis, but do so carefully. That speaker feels heavy after a while, but you have to carefully fit it over the studs. Took a little wiggling. I was really careful not to drop a tool through the speaker paper. It would be real easy to do so. Also, made sure to cover the frame when I soldered the leads on. Don't think hot solder would do that speaker cone any good either. |
#12 (permalink) | |
