So I want to put some 12ay7s in my '57 Twin RI
....but I'm not sure which slots they would go in...
Fender says that 3 of the 4 12ax7s can be substitued with 12ay7s, but which 3... the first 3, or last 3? I've included a picture Thanks for your help SB
| Sponsored Links |
tubes
Looking at the back, like your pic shows-
You would change the two tubes to the right of the power tubes. The Driver, and the Tone ckt. Then select one of the other tubes to replace. These amplify the guitar from the input jacks. I haven't seen the reissue, but you should have two channels, 4 inputs, if it is true to the original 5D8 circuit. |
The one closest to the power tubes is your Phase Inverter. Leave that one as a 12AX7.
On the originals that was the ONLY 12AX7. Right now, I'm building the little brother of that amp... the 5D8 "tweed Twin" circuit. It's only SLIGHTLY different: It's cathode biased so it's got less headroom, but the tube compliment is supposed to be the same (too bad reissues don't use the tube types the originals were supposed to use). Mine's the famed "low watt" version of yours. The 12AY7 is what is historically and schematically accurate. I don't understand Fender's weird Reissue tweaks except to say it MUST be for financial reasons. Nice amp! Let us know how the tube swap sounds!! |
#5 (permalink) | |
But, thanks a lot! =) I'll let ya'll know how she goes. SB |
#6 (permalink) | |
Re: tubes
#7 (permalink) | ||
At least Fender isn't trying to cover up which tubes would sound better in it: http://www.fender.com/products/searc...tno=8140500000 |
#8 (permalink) | |||
I love Fender stuff, but I build my own amps now... which is WAY cheaper, but I completely understand them having to make money to stay afloat in this Korean Strat copy world we live in. |
I'd stick a 12ay7 in only one of the 2 channels. My heartland 5e3 has a 12ax7 PI, with a bright channel(more gain)12ax7 and a low gain (12ay7)channel. I love the low gain for all indoor mellow work and the 12ax7 channel for rock and blues.
After seeing these pics of the tweed twin and it's construction, I'm buying one!!!!!! Or building one!
Play'n tele till I drop! *************** Bryan Hibler |
So at volume seven, how much less gain would I have? Would it just be louder, clearer?
Never actually heard one of these with the 12ay7s in it... Also, I read that... "the #1 inputs are configured to route the signal to both amplifying stages (or grids) of the first two 12AX7s" Does that mean I can swap one of the first two for a high gain/low gain channel type setup? SB |
I'd need to see the schematic before I'd say which tube does what.
I have a fender and Traynor amp that doesn't follow the right to left tube layout that fender started back in the day, plus some amps use tubes for dual purposes. Say a driver circuit and a tone circuit.
You'll probably find the amp goes a notch or two higher on the volume before breaking up. My 5E3 clone also produced a nicer clean going to RCA 6072s (12AY7s).
Fender probably went there as the only current production 12AY7 AFAIK is the EH.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
#14 (permalink) | |
It definitely aint gonna be like adding a good amount of dirt or anything like that. Have I confused you yet :) |
Yeah, it looks as if V1 or the tube to the far right is for the normal channel and then v2 is the bright channel.
Stick a 12ay7 in the V1 position to see how you like it. They are great for blues and smooth sounding stuff. My 52' Pro wass made for 6sc7's and it's hard to find good ones. After my amp revision, they just swapped out the sockets and put in 12ay7's. I bought the substitubes and stuck in a 12ax7 for the PI and a Mullard 12ax7 for one set of inputs and a Sylvania 12ay7 for the other set. I spend allot of my playing in the 12ax7 side, I love it's sound. I like playing through the 12ay7 side some. When I play(country) I want that tight, bright sound. Inside our house gig, I use the 12ay7 in my deluxe copy. It's smoother and gain isn't quit as high.
#16 (permalink) |
I find the old schematics more pleasing to the eye. YMMV... http://www.ampwares.com/ffg/schem/twin_5e8-a_schem.gif
