Help me choose an amp?
I'm looking to replace my trusty Sessionette 75 (1980s transistor amp).
I need a physically small amp with enough power for pub/club gigs (and possibly a line out to plug into a PA for bigger gigs), and built in reverb. I play mostly clean-ish, with the lightest touch of crunch. I don't play hi-fi clean. Sometimes I play with more drive. I need to be able to boost volume for solos, with a footswitch, and would need to be able to select different levels of overdrive the same way, rather than having to alter amp settings for different songs. My main guitar is a reasonably stock Tele. Any suggestions? |
Roland Cube 30 or 60
Hi there Chikenpicker,
I would give serious consideration to the Roland Cube amps. I have got the Cube 30 which is ideal for my requirements. There is the Cube 60 if you require a bit more volume. They certainly meet all of the requirments that you have listed. Like you, my main (only!) guitar is a stock '68 Tele.
Well it ain't the best Guitar i've ever heard, but it sounds just like it.... |
For an great low cost amp check out the carvin Vintage series Amps, The Vintage 16 which is a 5w or 16w EL84 tube amp that can be made with a hot set of tubes for blues or rock or a cool set for country and jazz and don't forget EL84 tube amps do not have to be biased to change the tubes , or Nomad are great amps at 50w two channels one clean one overdrive www.carvin.com I have two of there amps plus i live by two of there stores so I know there good!!!!!
Cubes and more
Well, along with your auditions of the cube 60, please do check out the Tech 21 Trademark 60. It does sound good. Many years ago, good sounding solid state amps were rare. Amp designers (engineers) have learned a lot about tone over the years. SS amps have gained *some* ground against the tube (valve) amps.
What a blessing sound can be. |
#9 (permalink) | |
#10 (permalink) | |
Since your used to SS amps, don't rule out the Roland Bluescube series. The single 12 BC-60 combo will do everything you require and do it with lightweight, reliability and best of all, great one. And, they love teles! |
SS amps
Have heard good things about these guys:
http://www.bluetoneamps.com/ Personally, I didn't like the Cube60 - too sharp. I preferred the microcube! Tube wise, I believe Laney, Sheldon and Matamp all make nice stuff, depending on your budget. |
#13 (permalink) | |
I have one of each, but the BC-60 doesn't feature footswitchable boost whereas the TM60 does, and the Tech 21 also has a built-in SansAmp so that it can be slaved directly into the PA via a normal XLR mike lead. Though fractionally larger in physical size, both of these will very easily eclipse an original Sessionette, which itself is a brilliant amp of which I'm a huge fan. Incidentally, I'm sure it's not appreciated how much all the more recent breed of solid-state amps owe to Stewart Ward's inspired Sessionette design of 1981.
Proud to be The Man From Uncool. I cried because I had no shoes - until I met a man who had no feet... |
#14 (permalink) |
I'd go for the TM60 too but then I've been using one since they first arrived here. It fills all your criteria and the line out is the best I've ever heard. There are two on ebay in the UK at the moment.
I've been out checking some new amps recently, I found the Cube 60 far too boxy to use. The Vox AD50 sounded great but I think I'd find the user interface too tricky to use live. In the end I decided to keep my TM60, with a couple of pedals to expand its range.
Helping to invent english country dance guitar since 1981. |
1. Fender Deluxe Reverb
2. OD pedal (any Tube Screamer clone/variant will work) 3. SM57 or some other cabinet mic if you need to use the PA Turn the amp WAY up, loud enough to crunch. Turn the volume down on your guitar to clean it up. Use the OD pedal for extra gain or solo boost.
Oz: Well, other bands know more than three chords. Your professional bands can play up to six, sometimes seven completely different chords. Devon: That's just, like, fruity jazz bands. -from Buffy the Vampire Slayer |
#16 (permalink) |
Had a Rivera Clubster 25 in the shop last month for a retube & checkup. Great sounding little amp & built like a tank. Has channel switching and good lead and crunch tones. Light weight amp also.
Took it home for a weekend of "extended quality control" and my wife got pissed off that I was playing it so loud, always a sign of a good amp!
"I feel that it is healthier to look out at the world through a window than through a mirror. Otherwise, all you see is yourself and whatever is behind you." - Bill Withers |
