Old March 14th, 2006, 12:15 PM   #1 (permalink)
popthree's Avatar
speaker ?? pathfinder 15R
do you think it would be possible to shoehorn a 12" into a pathfinder?
"chips are falling....."
-Dr. Johnny Fever
popthree is offline   Reply With Quote
Old March 14th, 2006, 12:34 PM   #2 (permalink)
kerc's Avatar
Re: speaker ?? pathfinder 15R
I have a Pathfinder...Maybe not a 12", but I think a 10" would fit relatively easy. I would put a Weber 10A150 in there...
By the way, once I asked Ted Weber about a speaker for my Pathfinder, and he recommended the Alnico Sig 8...Only $35:
For all Champs with 8" speaker, to replace Oxford 8EV, Chicago Jensen P8R, C8R. 8", 7oz AlNiCo plug magnet, 15 watt, 1" voice coil, straight cone. Warm, crunchy, early breakup, compressed/fattened at high volume. Will fit in tweed and early BF Champs.
I keep spending the money on other stuff.
Hey, try to play your guitar daily!
kerc is offline   Reply With Quote
Old March 14th, 2006, 02:15 PM   #3 (permalink)
popthree's Avatar
thanks for the recommendation Kerc. i'm thinking of picking one fo these amps up on the cheap. i was really hoping i could cram a 12" in there. it looks like there's alot of room. but your probably right about it being a bit too tight. a 10" will probably suffice.
-Dr. Johnny Fever
Old August 14th, 2006, 06:59 PM   #4 (permalink)
tdu
I was just about to post a thread about this, but I am hoping someone might update this one.
Can anyone confirm if a 10" speaker will fit?
tdu is offline   Reply With Quote
Old August 15th, 2006, 03:34 AM   #5 (permalink)
tonfarbe's Avatar
A 10" should fit easily, but not a 12".
I just measured my PF15 roughly. The inner height of the combo is
32 cm but there's a strip of wood at the bottom and the top, each with
a thickness of 2 cm.
This leaves a total of 28 cm for the speaker.
A 10" spaeker has a diameter of 25,6 cm, a 12" speaker has a diameter of 30,5 cm.
Oh, and btw, before you hunt for a 10" give the original speaker some time
to break-in. I pretty much like the sound of the stock VOX speaker in my PF15.
tonfarbe is offline   Reply With Quote
Old August 15th, 2006, 07:30 AM   #6 (permalink)
Pathfinder speaker swap...
I have removed the stock baffle board, and replaced it with a new one loaded with a 10". I THINK a 12" might go, there's enough real estate on the baffle, but "dry fit" it first to be sure the magnet clears the chassis. HTH...
stratavox is offline   Reply With Quote
Old August 15th, 2006, 05:12 PM   #7 (permalink)
tdu
Thanks for the info. I am the second owner, and the speaker is well broken in.
I guess I am hoping for a bit 'bigger' sound with a slightly larger speaker. I don't think I would attempt a 12", but I am considering a 10".
