Old February 21st, 2006, 01:51 AM   #1 (permalink)
dean's Avatar
One cab - Two head - Different ohms
OK, so I picked up an old Fender blackface era 2x12 cab for cheap. It has a couple holes in the grill cloth and a 3"x8" port cut out for the back. I figured $75 wasn't bad for the cab in this condition. It will house a couple 8 ohm speakers for now.
I have two amps that I want to run through the cab (not at the same time), but one is rated at 4 ohms (Bandmaster Reverb) and the other is rated at 16 ohms (Galien-Krueger 250ML). Can I wire the cab up with some sort of switch that will give me the option of making the 8 ohm speakers work with both amps? Or can I wire the speakers to two separate 1/4" jacks - one 4 ohm and one 16 ohm? I can make a control/jack/switch panel that will fit over the hacked "port" already in the back panel.
Is this possible? Are there any sites that might have a diagram and instructions for wiring something like this? I need pictures or diagrams if possible - I'm sorta technically "needy" when it comes to this.
Thanks for any help!
Dean
"I used to be clueless, but I've turned that situation around 360 degrees."
dean is offline   Reply With Quote
Old February 21st, 2006, 02:06 AM   #2 (permalink)
Ben Harmless's Avatar
Aw, heck yeah. You need a series/parallel switch. You're lucky in that you don't need an 8ohm impedance anywhere.
I'm not finding a good diagram of the switch anywhere though. I'll keep looking a bit, but now so can you. 8)
- B. Simpson
Old February 21st, 2006, 02:14 PM   #3 (permalink)
dean's Avatar
Here's a diagram - will this work?
This is a diagram from this site. This is the Mono, Switchable Impedance diagram. Is this what I want to do? And do I use the two jacks for the different ohm ratings? (I'm not sure I understand the "IN" - "OUT" jacks unless that deals with linking other cabs to this one.)
Again, any help is appreciated.
Dean
Old February 21st, 2006, 02:49 PM   #4 (permalink)
CancerLeoCam's Avatar
You can always.....
...get a Weber Z-Matcher and not mess with the cab.
Everyone's your "buddy" or "friend" when they want you or something from you.
If you're not willing to work for free why should somebody else?
CancerLeoCam is offline   Reply With Quote
Old February 21st, 2006, 04:26 PM   #5 (permalink)
Bluesbob's Avatar
You got it...
Your diagram is just what you need. As you figured out, the jacks are "parallel" so you can piggyback. I wish I could help you with parts numbers and such, maybe someone else? Radio Shack? Anybody know?
What, me worry?
Bluesbob is offline   Reply With Quote
