fundraiser
Old February 18th, 2006, 06:56 PM   #1 (permalink)
Oops - So I fired up a 6G2 Princeton with no tubes in it...
I made a mistake.
I powered up a 6G2 Princeton and fumbled around for a few minutes wondering why it wasn't working before realizing that I had pulled all of the tubes out of it at some point. Something I had forgotten. I turned it off, re-installed tubes, and powered it back on. Now it's not working. Just a low hum. Fuse never blew.
Haven't pulled the chassis for a look yet, but what am I likely to have damaged? :(
slack is offline   Reply With Quote
Old February 18th, 2006, 07:40 PM   #2 (permalink)
Dacious's Avatar
Oh no, Slack! It'll be unrepairable! You better send it straight 'round to me, and I'll make sure diddums amp is never mistreated by nasty ol' Slack never no more!
Just kiddin'
Commonest trick in the world is fire up a chassis, no tubes or speakers. That way you can check the various voltages in the tube sockets and make sure you haven't got hundred of volts on pins where you should have nothing or very little.
No damage should have occurred. Without the tubes there, there is no circuit and precious little current drawn. Just don't make a habit of it, and we'll let you off - just this once, mind!
Sure you got all the tubes in the right slots? Speaker lead in the right hole?
The only thing that may have happened, is it may have popped an old cap. If so, it was about to let go anyhow - better with no load than when you're doing your best EVH impressions.
Why did it have tubes out - maybe it wasn't working then, either?
Old February 18th, 2006, 07:52 PM   #3 (permalink)
I knew that would be in the first response! Logical question.
No, nothing was wrong with it. I have several 62-64 Princetons. I had pulled it's tubes to try in another amp, knowing these tubes were good. I just forgot about it.
Thanks for replying. :D
Old February 18th, 2006, 08:26 PM   #4 (permalink)
David Barnett's Avatar
With no tubes, there should be no voltage anywhere except the bias supply, so if you actually did blow something, that's where I'd look first.
David Barnett is offline   Reply With Quote
Old February 18th, 2006, 09:12 PM   #5 (permalink)
This is pretty obvious so don't get mad that I brought it up, but the rectifier tube and the 6V6s will interchange. Check that first.
Old February 18th, 2006, 09:16 PM   #6 (permalink)
I haven't yet pulled the chassis, but I did go through the tubes again. Nothing in wrong sockets. Thanks though, good point.
Old February 18th, 2006, 09:37 PM   #7 (permalink)
Just pulled the chassis. Everything looks fine. No blown caps, no broken joints, etc. In fact, it all remains 1964 original and untouched. The tubes I put in it came right out of a working Princeton. This one was the best sounding of my Princetons, last time it was working (based on original amps AND speakers).
Old February 18th, 2006, 11:36 PM   #8 (permalink)
tazzboy's Avatar
well then put the tubes back in re adjust the bias to the proper settings and plug your guitar (and effects if you are using any) and give it a go.
The worset is you aren't going to get any sound out of it at all.
tazzboy
Old February 19th, 2006, 12:49 AM   #9 (permalink)
Bias a 6G2 Princeton?
Old February 19th, 2006, 01:16 AM   #10 (permalink)
tazzboy's Avatar
Well that's what I read on the Fender Amp Field Guide. Guess that is wrong
tazzboy
Old February 19th, 2006, 01:36 AM   #11 (permalink)
fezz parka's Avatar
Yep. It's a fixed bias amp.
Old February 19th, 2006, 03:32 PM   #12 (permalink)
So, today it is working again. Apparently it's toying with me, making me look silly.
I'm thinking it's a flakey tube.
Old February 19th, 2006, 06:28 PM   #13 (permalink)
Got an octal tube with the guide pin broken off?
Old February 19th, 2006, 06:54 PM   #14 (permalink)
Tremo's Avatar
Look, Slack, no offense intended, but it is pretty clear that you have no idea what you're doing. I'd suggest that you take the amp to a tech before you blow something up.
Old February 19th, 2006, 08:17 PM   #15 (permalink)
Dacious's Avatar
What it may have been, Slack, is just a little corrosion - invisible to the eye - built up on your input jack. Couple with a bit of dust, and bingo - no contact, just hum. Work the jackplug in and out a few times and all of a sudden it works again.
I think Brother Tremo is lookin' after your best interests in suggesting a tech-check. If it is all original, those filter caps will be straining, and the little electros on the board will also be a bit sad.
I've seen a 60's radio chassis which popped a cap - the stuff is like corrosive Space Invader - fills ever nook and cranny, and takes hours to pick out. If you have bad luck and the elements short inside, say goodbye to your power tranny and maybe tubes.
Old February 20th, 2006, 04:57 AM   #16 (permalink)
Well, I'm certainly no amp tech. This is true. And, like I said, this thread made me look silly and I knew that then and now. I'm fine with that. But, with dozens of vintage Fender amps, and having been pulling them apart when buying/selling/trading/documenting them for decades, I've yet to blow anything up. And I've even been known to solder in a few. 8)
No offense taken. Just your, um, point.
I'll ask it as I always do - feel free to recommend a fair priced, timely turnover, quality amp tech in LA. I've yet to find him/her.
Btw, turned out to be a bad power tube. It's now running fine on a pair of Sylvania/JAN 6V6GTY brown bases that silverface gave me a while back.
Old February 21st, 2006, 12:38 AM   #17 (permalink)
I could take a look at her.
I'm in Orange County.
It's kinda hard to mess up an old Princeton like you're saying.
I'd unplug her and check the solder joints first... then dried out caps would be the next suspect. They will look like working caps, so you can't really "eyeball" it for bad ones.
If it craps out again, or starts killing tubes/fuses, checking voltages would give you a good place to start - THAT COULD ZAP YOU GOOD, so perhaps learn more about amps, or take her to someone.
Old February 21st, 2006, 01:13 AM   #18 (permalink)
Thanks... Do you have a shop? Bad drive for me, though.
I checked all the solder joints. Caps look good, but as you said...
It's been running good since swapping tubes. Playing through it right now.
Btw, while not an amp tech for sure, I know how to safely work in amps. I work professionally with 20,000 watt lights and 100 amp Bates connectors and 600 amp Edison breakout boxes - usually in the pouring rain, it seems.
