Old February 10th, 2006, 09:49 PM   #1 (permalink)
Newbie "easy" question
Is there a danger in running a "line out" from one amp to the input jack of another amp?
How about the output from an effects loop on an amp to another amp's input jack?
Thanks in advance!
ChrisM is offline   Reply With Quote
Old February 11th, 2006, 10:59 AM   #2 (permalink)
Lance's Avatar
Kinda what....
it's for! Yes, there may be some line level issues but it should work.
Lance
Old February 12th, 2006, 04:22 PM   #3 (permalink)
You can use the regular input but I'd go to the pre-amp
input on the back of the 2nd amp. Peavey recommends this for 2 amp setups....... Pre-amp out of amp 1 to the power amp input of amp 2. Both jacks should be on the back of the amps. When you do it this way, the only control which works on the 2nd amp will be the master volume. All EQ will be from the 1st amp....JH in Va.
Ralph Mooney rules!!
J. Hayes is offline   Reply With Quote
