Old December 12th, 2005, 11:02 AM   #1 (permalink)
Sidney Vicious's Avatar
MMB test drive tips wanted - PASSED the TEST!
I have a MMB project which I think is finally ready for launch. New old stock transformers, new caps, - original pots, tube sockets and other chassis components.
I soldered everything into place last night and have double checked to make sure the wiring is correct as per the layout drawing and reference board I have. All solders appear to be solid.
Have been told that before I fire it up with tubes I should do so without tubes in it - what will that tell me if anything? What should I look for in the untubed but turned on state?
I do not want to burn the trannies or anything stupid.
Or should I simply put the tubes in hit the switch and smell?
What say you?
Edited to add:
My search tell me it is to check voltages therein?
Which pins/what voltages/any tips and tricks welcome.
Sidney Vicious is offline   Reply With Quote
Old December 12th, 2005, 04:40 PM   #2 (permalink)
Tremo's Avatar
I'd fire it up first without tubes, and check all the voltages to make sure they're at all the right places. Measure the tube socket voltages to make sure there are no mis-wires. and of course, look for smoke.
If you pass that test, plug in the preamp tube and do more measuring, make sure it's drawing the correct current, and inject a signal and make sure you have grid drive going to the outputs.
Lastly, plug in the outputs and do more measurements.
Old December 12th, 2005, 06:17 PM   #3 (permalink)
Ya gots to be more 'pecific!
Tremo:
Thanks for the input but I am very new at this and need more detailed info - any place you can direct me? Besides sending it to a tech? Isn't it something I can check with a multimeter?
Old December 12th, 2005, 08:28 PM   #4 (permalink)
Dacious's Avatar
If you get your DMM and set it on DC in a scale of up to 400 volts, you should be able to touch it to points in the wiring and read voltages.
On the MMB schematic off Ampwares, off the rectifier diode junction you should get 295 volts. On pin 3 of either power tube socket you should get 290 volts.
At the output of the second 20uf filter cap you should get 200v.
On the wire between pin 6 on the 12AX7 and the phase-inverter transformer you should get 246 volts. On pin 3 you should get 165 volts.
Now, these figures will be higher, by 20-50 volts because the tubes aren't in. Also, I think you indicated you were using a different transformer. If you get no voltage it indicates a bum connection
But if you get these figures +20-50 volts and no smoke, you can risk sticking the tubes in as Tremo says, preamp then power amp. No smoke - all is probably good.
Clip your negative lead to the chassis, and keep one had in your pocket, use the +ve lead to check the points carefully - don't earth on another component or the chassis.
MMB Schematic
Old December 12th, 2005, 09:12 PM   #5 (permalink)
My friends -
Thanks so much - will do - and will keep hand in pocket!!!!! - and will report.
Old December 13th, 2005, 12:04 AM   #6 (permalink)
Passed the test!
Did as suggested and carefully went through some preliminary testing of circuit without smoke, fire, shock, or melting.
Put it all back together, plugged in a guitar, and SWEET!!!
Thanks to all.
Sidney
Old December 14th, 2005, 11:49 AM   #7 (permalink)
Rizo's Avatar
Congrats, sounds like good one. Are you planning (or have you made) any mods?
"You say you want to play country, but you're in a punk rock band."
Rizo is offline   Reply With Quote
Old December 14th, 2005, 03:02 PM   #8 (permalink)
No mods planned.
I may install a fuse - it already has a non-original Weber Sig Alnico.
As it is, it sounds perfect to me so I will do nothing to change the signal path.
Old December 14th, 2005, 03:29 PM   #9 (permalink)
Rizo's Avatar
Yeah, I think a fuse should definately be added, just in case. For the life of me, I don't know why Fender never put 'em in.
Old December 14th, 2005, 03:35 PM   #10 (permalink)
Moderator
Tim Armstrong's Avatar
Maybe they were con-fused.
Thankyouthankyouverymuch, I'll be here through Thursday. Remember to tip your waitress!
Tim
http://www.moodswingers.org
Old January 8th, 2006, 09:18 PM   #11 (permalink)
jonkay1's Avatar
Re: MMB
Pardon me for asking, but what is an MMB?
jonkay1 is offline   Reply With Quote
Old January 8th, 2006, 09:30 PM   #12 (permalink)
Spidercaster's Avatar
MMB =
MMB = Fender Music Master Bass amp, which converts very nicely to a guitar amp.
Spidercaster is online now   Reply With Quote
Old January 8th, 2006, 09:57 PM   #13 (permalink)
And there was one modification done the amp - a .047 cap at the input was removed and the connection jumpered.
(Spidercaster - my little boy would love that axe of yours. :) )
Old January 8th, 2006, 10:08 PM   #14 (permalink)
My Axe
Thanks Sid ':D'
