Old August 4th, 2005, 08:26 PM   #1 (permalink)
Taming Champ volume!
Yes, that's right - my Champ on 10 is TOO LOUD.
I already posted on the "Stomp Box" thread, but I am down to a few options:
1. Danelectro D-2 Overdrive
2. BadMonkey OD
3. Weber MiniMASS attenuator
I don't like distortion or fuzz effects, I would prefer overdrive to push the front end (12AX7 preamp tube) of my amp than use an "effect".
As far as the MiniMASS I could use it on multiple amps/cabs... so could the pedals. So I'm looking for tone-friendly volume methods :)
Old August 4th, 2005, 08:46 PM   #2 (permalink)
its relatively simple to install a MV in a champ. I can't recall off the top of my head, but its in one of weber's books. Natch, you will have to find a place for the pot though. I had a VC that i converted to tweed specs, thus losing the tone controls. i was thinking of throwing in the MV in one of those pots for kicks but i dont have the amp anymore.
that still wont really give you the real champ tone at a low volume though.
its sad when you have to attenuate a 6W amp, but on 10 those things are loud enough to disturb many a neighbor, especially if you have a nice weber speaker innit.
the mini mass may be the only choice but the MV may be worth a try.
cugel is offline   Reply With Quote
Old August 4th, 2005, 08:55 PM   #3 (permalink)
hmm
Never thought of that. I don't want to mess with a semi-original '72.
I'm actually building my own "Tweed" Champ heads. Perhaps I'll drop a MV in one of them.
For now I'm using an EQ pedal redlined. I can get some dist at low levels but over 2 and the volume is SICK. It's gotta Weber 8", but I'm planning on putting in a Weber 8A125.
I'm looking for a budget "home" scenario, BUT for recording I'll just open up on the dial and let er rip :)
Old August 4th, 2005, 11:26 PM   #4 (permalink)
Try putting a 6K6 power tube in it. Those are normally used in the Fender reverb units.
Lower power by a couple of watts, sooner break-up, but still it's still pretty loud!
Doug T. is offline   Reply With Quote
Old August 5th, 2005, 06:35 AM   #5 (permalink)
Rob DiStefano's Avatar
A minimalist OD is yer best and easiest bet, IMO - the BM works well with a Champ, been there and done that.
Old August 5th, 2005, 08:12 AM   #6 (permalink)
Lance's Avatar
Mini Mass
Too darn simple and obvious....and cheap!
Just do it!
Lance
Old August 5th, 2005, 09:08 AM   #7 (permalink)
Daddy Elmis's Avatar
get the mini mass, now. It's way cheaper than any decent OD pedals, preserves very much intact the amp's tone (especially if you just knocking down a Champ -- shouldn't take too much attentuation), and is very flexible.
I have a Weber attenuator on every amp I own and would not be without them. Yes, at extreme attentuation it affects the higher frequencies of the amp -- but you can easily eq around this or have Ted put the bright switch on the Mass.
As I always say, an amp at its sweet spot attenuated sounds better than an unattentuated amp NOT at its sweet spot (using any pedal).
For me, I add pedals AFTER I've dialed in the amp's best tone -- I don't use pedals to create the amp's sound.
Elwood: Good evening ladies and gentlemen, we're sure glad to be here in Cocomo tonight. We're the Good Ole' Blues Brothers Boys Band from Chicago. I sure hope you like our show. I'm Elwood, this here's my brother Jake.
Daddy Elmis is offline   Reply With Quote
Old August 5th, 2005, 11:35 AM   #8 (permalink)
jhundt's Avatar
unplug the speaker
just joking!!!
jhundt is offline   Reply With Quote
Old August 5th, 2005, 12:15 PM   #9 (permalink)
Amp in a case...
If the Champ is too much, find a Silvertone 'amp in the case' or similar amp. You know the type....no power tranny, maybe they make a watt and 1/4. Make it safe with an isolation transformer so that the AC Voltage can't come through the chassis to your guitar. Turn it up and wail away. Or....build you an isolation box for the speaker and push that Champ as hard as you want. The microphone inside the isolation box will be the only connection that the speaker has to the outside world. IMO, to interfere in any way with the sound of a Champ would subtract from the essence of the sound of a Champ. My two bits...
8)
Old August 5th, 2005, 12:48 PM   #10 (permalink)
skepticult's Avatar
Re: Amp in a case...
Is there anything like this available commercially? This would solve several of the problems I have trying to record in my apartment. I'm not a handyman, though.
I've tried using a heavy blanket (obviously leaving space for the heat to vent) and while it did a great job of killing some of the volume, it also sounded like...
wait for it
...there was a blanket over the amp, even when miced from under the blanket.
Pedals will add distortion, but unless the speaker is pushing some air the miced sound is really flat and dull.
Edit: Are you talking about something like this?
http://www.amptone.com/demeterssc1.htm
skepticult is offline   Reply With Quote
Old August 5th, 2005, 01:40 PM   #11 (permalink)
The Demeter box is the one that I had read about. I suppose one could go to the extent of building a
muffling system that would allow open-back speaker movement with lower decibels. There are all sorts of thoughts to follow on this theme, but you found the unit that made me mention the isolation box.
Old August 5th, 2005, 01:54 PM   #12 (permalink)
skepticult's Avatar
I've been hunting around on Google a bit now that my curiousity has been prodded into action.
Here's a few other options I've found.
This one looks like you can cram your entire amp inside:
http://www.asc-studio-acoustics.com/iso-box.htm
Randall:
http://www.randallamplifiers.com/pro...tion/index.asp
None of them have multilayered cabinets, though, which seems kind of lame, especially when you're dropping a few hundred dollars on a plywood box.
From the reviews I've read it sounds like they have similar problems to the blanket as far as deadening certain frequencies.
Back to the drawing board...
Old August 5th, 2005, 01:59 PM   #13 (permalink)
maestrovert's Avatar
Once upon a time, i'd thought of trying a 4" 8 ohm speaker for my Champ...("Radio Shack" type...and before y'all say anything, i know, i know.... ;-) you'll notice i said i'd THOUGHT of it, but i didn't actually do it though)
i use my GNX4 for recording late at night when i can't/don't want to intrude on other's peace and quiet......
the isolation box and the attenuator will both "work" BUT.....
there's NOTHING like a Champ cookin' on the natch if'n ya ask me !
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old August 5th, 2005, 02:00 PM   #14 (permalink)
As with any closed box...closed-back cabs included...there will be an effect on the movement of the speaker and therefore on the freqs/harmonics. It may be time for a new idea.... 8)
With regard to putting the whole amp in the box, I would have reservations as to the heat build up. Again, a mffling approach would provide ventilation as well.
Old August 5th, 2005, 03:06 PM   #15 (permalink)
skepticult's Avatar
Okay, so I got curious
I'm on my lunch break so I got out the blankets again. It actually doesn't sound half bad (tone-wise, leave my playing out of this!)
This is my Tele bridge->Grail, spring, 1o'clock->SFVC with everything@6 and trem off.
http://kookportal.com/sounds/blanket.mp3
Quiet enough for the daytime/early evening for sure. No way I could go louder than this, though.
Old August 5th, 2005, 09:31 PM   #16 (permalink)
Dano DM10
If six watts is too loud, find a Dano DM10 or the Silvertone varient. Although it may look like a toy, you can get some very nice power tube distortion dimed at apartment living volumes. If your bank account is really flush, try a Carr Mercury.
I think what most people need around the house is about two watts max.
I bought a Gibson GA15 thinking it was going to be the ticket to low volume cranked tone. What was I thinking?
Brick is offline   Reply With Quote
Old August 6th, 2005, 01:56 AM   #17 (permalink)
CancerLeoCam's Avatar
Re: Dano DM10
I second the 6K6GT substitution. Idle plate dissipation for that one is 30% less so you should get pretty good breakup.
However, if you leave the cathode resistor value where it is at you may end frying the tube so a bias is necessary here if you do it. Fender sometimes sent out their Champs/VChamps/Broncos with super hot PT's that would push plate voltage up to over 400V in conjunction w/ a very very VERY hot bias.
Premature power tube death was synonymous with those PT's. An appropriate resistor (2W power rated) can serve as effective choke off the tube rectifier to the circuit if you have one of these PT's. I did on my VC and it works fine. GLuck
Everyone's your "buddy" or "friend" when they want you or something from you.
If you're not willing to work for free why should somebody else?
CancerLeoCam is offline   Reply With Quote
Old August 6th, 2005, 12:38 PM   #18 (permalink)
Deacon Blues's Avatar
Correct me if I'm wrong,
but isn't the speaker on a Champ hard wired? If that is the case, a mini mass, or any attentuator isn't going to work unless you wire in a speaker jack.
If it does have a speaker jack, I would recommend the Weber Load Dump. I actually like this device better than the Load Dump.
This is the age of the expanding man.
Deacon Blues is offline   Reply With Quote
Old August 6th, 2005, 02:53 PM   #19 (permalink)
Lance's Avatar
Nope...but
The champs speaker isn't hard wired but it has an RCA style connector. Weber sells the connector for that style also.
(although, I'd buy the RCA and a standard 1/4" connector anyway)
Lance
Old August 6th, 2005, 03:42 PM   #20 (permalink)
Wha...?!
1. I do NOT want to buy another amp. I like the Champs.
2. When recording, the Champ will be fully cranked - I'm fine with that volume. So this quieting down is for "everyday" non-recording use.
3. I'm looking for a cheap easy solution. Nothing fancy.
I am going to be wiring a standard 1/4" jack in the place of the RCA... so that makes any attenuator a non-issue.
Isolation boxes?! Are you kidding me?
I have been looking into the Guytronix Gilmore Jr 1/2 watt for other uses (although, wasn't too thrilled with the soundclips), BUT I love my Champs :)
