Which amp and why?
I'm looking to order a new small tube amp in the next couple of days for home use. I've found several within my budget but no one has any in stock locally so I'm hoping that some of you can give me some guidance.
My guitars are a Gibson Reissue Melody Maker with 1 single coil and an '08 highway one Tele. I like to play the blues. anything from Bonnomassa to BB, classic rock, love nice cleans also. Not big into metal. So, below is what I've narrowed my search down to with what I think I would be the best option to the worst. What do you think? Ibanez TSA5 tube screamer combo - Not a lot of videos regarding this amp but by specs it seems like it has most everything I'm after. Just wish it had reverb. Fender Super Champ X2 - I love the idea that it has so many models and effects. I'd imagine the cleans on the first channel are second to none in its price range. This one definately has everything I'd ever need but somehow I think the Ibanez would sound better. Blackstar HT1R - This amp also has everything I require and 1 watt is probably all I'd need for home use but I can't help but think that the Fender and the Ibanez would sound better. Any advise? |
The new Fender 'Excelsior' 13watt amp with it's 15' speaker and Tremolo effect.. tube amp..very cool amp and certainly worth a ganter for home use and very easy portability with it's size and weight...$300. in stores
Also..It's worth comparing the 13watt Excelsior to it's kin, the 15watt Blues Jr. and the 15watt Princeton Reissue.. Specs: Excelsior $300. Controls Volume, Tremolo, Bright/Dark Switch Tubes 13 Watts of output power, Two 6V6 output tubes, Two 12AX7 preamp tubes Speaker 15" Special Design, 8 ohm Weight 33 lbs Dimensions 21" (53.34 cm) H x 19.5" (49.5 cm) W x 9" (22.9 cm) D Also 1/4’’ speaker plug may be disconnected to use Excelsior with an 8-ohm, 15W minimum, external speaker enclosure Inputs/Outputs Guitar, Mic, Accordion each with individually optimized circuitry Fender Blues Junior Amp Features: $500. Type: All tube (El84's) Output: 15 watts into 8 ohms Speakers: 1-12" Fender Special Design 8 ohm, 50 watt speaker Channels: 1 Channel "Fat" switch with footswitchable on/off Reverb Chrome panel Vintage chicken-head knobs Princeton Reissue:$850. Amp Type: Vintage Reissue Series Tube Amp Output: 15 watts into 8 ohms Tubes: 3 x 12AX7, 1 x 12AT7, 2 x Groove Tubes 6V6, 1 x 5AR4 rectifier tube Speaker: 1-10" Jensen Special Design C-10R Channel: 1 channel (2 inputs) Controls: Volume, Treble, Bass, Reverb, Speed, Intensity Effects: Reverb, Vibrato Covering: Black textured vinyl Excelsior Demo Video Last edited by musicmatty; July 28th, 2012 at 02:58 PM. |
I have heard nothing but good things about the super champ, I would say go for it
My Band Peregrine! http://www.youtube.com/watch?v=Jo5Voy5F1DE&feature=plcp http://www.facebook.com/#!/PeregrineOfficial http://peregrine1.bandcamp.com/ |
Thanks for the input and the info in that Excelsior. It looks like a Fender has come out with another great amp at a modest price! I went back and forth all day between the 3 amps I've been considering and in the end I chose the little Ibanez TSA5. I'd almost went for the Super Champ but my gut told me to go with the Ibby. If it sounds anything close to TSA15 big brother, I'm sure I'll be happy with it. I'll give a review after it delivers next week
#7 (permalink) | |
Marshall class 5. A plexi-ish sound that sounds great with teles, and apparently Gibsons too. Great interesting cleans too.
Another great little low volume amp is the fender champ 600. Twangs and rocks, and gets bluesy. And the Bugera Vintage 5, with an intermediate amount of gain, great reverb, and an attenuator built in. ![]() Quote:
So I made an attempt to reach out to the one and only Ibanez TSA5 owner that has posted a video of the amp on Youtube to see how he liked it. He's not American but did his best to reply in english. Anyone care to make an attempt at decoding his replies for me?
Me: "sounds great! How do you like that TSA5 amp? I took a shot and ordered one tonight." Him: "Amplifier is a grade which it is not made to be distorted by heaviness and can make a CRUNCH sound. I will think that I become a glossy sound, if the level of a TUBESCREAMER function is raised." Me: "So no heavy distortion but good crunch with tubescreamer engaged. Good deal! Can you get crunch at low volume or does the amp have to really be pushed?" Him: "I also regard volume with low TSA5 as saving the level and distortion of TUBESCREAMER in the state as it is." Now I'm pretty sure I got his first reply but the second one has me baffled. No idea what he is trying to say. |
#9 (permalink) | |
In the short..don't expect much from a 5watt amp..in your own words "Bonnomassa to BB, classic rock, love nice cleans" ...Save up a little more and get something that has a little more ass-end to it...just my opinion and experience of what you have stated that you are looking for ..some great options for $300. |
I use my tsa15h on the 5 watt setting and I like the sustain and growl it will produce. It isn't a marshall jubilee but you will enjoy the blues/rock tones... Well at least I do, not that I don't like all the other amps listed...
So my new Ibanez TSA5 came in yesterday. I spent some time playing with it last night and I'm kind of on the fence about whether I really like it or not. First of, it is not very loud at all. Seriously, my old Marshall MG15DFX is louder. I'd once had a Epi Valve Jr and I remember that 5 watter being much louder. I'm ok with the volume. I really didn't want a tube amp that would rattle the windows and had been considering getting a 1 watt. Sound wise I would rate it a 6.5 out of 10. I haven't had it long enough to really dial in the amp and my guitars so my rating might be a little harsh. I've read that speakers need to be broken in. Should I expect that the 10" Celestion will sound a little better within a week or two of playing?
Specs on the amp are 5watt all tube, 1-12AX7 pre and 1-6V6 power, Celestion Tube 10" speaker and Tube Screamer circuit built in. |
#16 (permalink) | |
Not surprised at all..considering what you stated in your first post with regards to what you were looking for |
#17 (permalink) |
I raised the pickups in the Tele and it made a pretty good difference. The cleans are still pretty low volume but engaging the tube steamer even turned all the way down boosts the volume pretty well.
#19 (permalink) |
I have the Ibanez TSA15H and the cabinet.
I don't think that you can go wrong with the 5 watt Ibanez or the Super Champ X2. I would not buy a one watt amp unless if your goal is to crank it and play with a lot of gain all the time. You're not going to get any clean spanky volume from 1 watt. I would have this be the determining question...... Do you want a simple true tube amp or do you want a modeling hybrid with many bells whistles? Simple tube amp - Ibanez Bells and Whistles - Super Champ I think the Ibanez looks like a great no-nonsense tool and I like Tubescreamers but that's just me. You can't loose either way. Enjoy.
John "The rock and roll business is pretty absurd, but the world of serious music is much worse." - Frank Zappa |
#20 (permalink) |
You want a 5 watt "does everything" amp ???
Simple is not the way to go for that. Simple amps are one-trick ponies. The Laney Lionheart L5T-115 does go from Fender cleans through Vox chime and crunch to Marshall roar - which is to say, that with its two channels and its trick Drive control, it will go from very clean to very thick overdrive. It doesn't quite do metal, but that's what pedals are for. Not sure about the Keeley Mod+TS9, nice but the L5T does that type of drive by itself, so maybe something thicker. Goes from mousefart to actually rather loud, which is unusual for any valve amp. Quiet enough for late night whilst watching the box, loud enough to compete with a BJ ;) Basically a SE 5 watt take on the rather nice Laney VC30 stage amp. Around £500 new but often seen second-hand. If you do want everything in the box then modelling - Vox Valvetronix AD30VT or Roland Cube20X here. Both discontinued, the AD30VT does turn up s/h but problem with many cheap amps is they just get slung in the trash when kiddies loose interest.
