Old June 26th, 2012, 01:09 AM   #1 (permalink)
Southpaw Tele's Avatar
I accidentally left my amp on for 3 hours...
It's an Ampeg Jet J-12t reissue. It still plays fine, but the chassis was hotter than my wife. Have I damaged anything? I was afraid to look at the tubes.
Southpaw Tele is offline   Reply With Quote
Old June 26th, 2012, 01:11 AM   #2 (permalink)
fezz parka's Avatar
I do that all the time. Just pretend you were playing though it.
Old June 26th, 2012, 01:13 AM   #3 (permalink)
Whew, thanks Fezz. The PCBs in these things are paper thin and I was praying traces didn't lift or something. I think it was my family's fault for rushing me out the door while I was playing in my usual mediocre fashion.
Old June 26th, 2012, 01:25 AM   #4 (permalink)
marc13's Avatar
I once left rehearsal and came back a week later to find my amp still on. (1995 Fender Deluxe 112 Plus) it was hot as hell, but we had to practice, so I plugged in and it played just dandy! Still using it, too. (when I bought it in 1998 I'd had a post-power external speaker out added, now I disconnect the built-in speaker and plug an 80s Peavey 2x15 bass cab into it at 8ohms, and it sounds good.) I'm guessing it's cause it's a solid state and not tubes.....
Now I'm looking forward to saving enough for an AC30...
marc13 is offline   Reply With Quote
Old June 26th, 2012, 01:31 AM   #5 (permalink)
trev333's Avatar
hey! it's winter down here... and it cold and rainy...
the super 210 stays on from morning until night to help warm the house....;)
nothing more annoying than switching an amp on an off .... getting off the chair,,, up and down,,heeerrruummpphh... ha ha ,,
"by degrees the flood of music drove all speculations out of his mind. It was as though it were a kind of liquid stuff that poured all over him and got mixed up with the sunlight that filtered through the leaves."
trev333 is online now   Reply With Quote
Old June 26th, 2012, 02:13 AM   #6 (permalink)
formerly "Big" Mike Simpson
Mike Simpson's Avatar
I played an 8 hour outdoor gig in Phoenix on 06-17 and left the amp on for 8 hours in the AZ heat from noon to 8pm... my left hand was real tired about 7:30pm...
Mike Simpson is offline   Reply With Quote
Old June 26th, 2012, 02:22 AM   #7 (permalink)
SamClemons's Avatar
Left tube amps on for 12-24 plus a number of times with no problem. 3 hours should be nothing. That is a pretty short gig or practice for a lot of folks. Some do that every day.
SamClemons is offline   Reply With Quote
Old June 26th, 2012, 02:28 AM   #8 (permalink)
I know they are different beasts but once upon a time everyone had valves in televisions and radios. You can imagine how long they got left on for.
DeepSouth is offline   Reply With Quote
Old June 26th, 2012, 02:29 AM   #9 (permalink)
trev333's Avatar
much better than accidentley leaving the car lights on over night and having a flat battery in the morning,,,;)
Old June 26th, 2012, 02:32 AM   #10 (permalink)
6stringelectric's Avatar
3 hours? It's just getting properly warmed up at that point.
Most gigs are longer than that, and decent guitar amps can take much more than that.
Nothing to worry about.
Curt
The Lone Ranger and Tonto were ridin' down the line
Fixin' everybody's troubles - Everybody's 'cept mine
Someone must have told them I was doin' fine...
6stringelectric is offline   Reply With Quote
Old June 26th, 2012, 04:40 AM   #11 (permalink)
Forget the amp. Forget the guitar. You've got time for that later.
Warren Pederson is offline   Reply With Quote
Old June 26th, 2012, 06:54 AM   #12 (permalink)
printer2's Avatar
What makes you think it was not later? How do you think he forgot it for 3 hours?
printer2 is online now   Reply With Quote
Old June 26th, 2012, 07:00 AM   #13 (permalink)
I read when Eddie Van Halen was co-developing the EVH III w/Fender...one of his "torture" tests was to crank it full blast and set his guitar in front of it closeby so it would feedback, for a full month! The amp survived, although the engineers didn't really see the point. There's video of them explaining it, etc. There's short mention of it here in this article:
http://www.guitarplayer.com/article/...h-brand/147685
so don't worry at ALL over 3 hours, my friend....
BoogieManSC is offline   Reply With Quote
Old June 26th, 2012, 08:02 AM   #14 (permalink)
Scotty 2's Avatar
Not to worry,,most guys don't practice long enough to
allow tubes to reach their potential heat range.Yes,,they
get hot,,,they're supposed to.But never,never go away
and leave your wife turned on for 3 hours MELTDOWN
And the Tele said; Why is everybody always pickin on me
Scotty 2 is offline   Reply With Quote
Old June 26th, 2012, 10:07 AM   #15 (permalink)
My amps are rarely ever on for anything less than 3 hours.
ehren is offline   Reply With Quote
Old June 26th, 2012, 10:16 AM   #16 (permalink)
It's made for that.
Dim lights, thick smoke, and loud, loud music.
It's the only kind of life you'll ever understand.
You'll never make a wife to a home lovin' man.
Ricky D. is offline   Reply With Quote
Old June 26th, 2012, 12:54 PM   #17 (permalink)
My basement is primarily heated with a fireplace/blower connected to a thermostat on the other end of the room. The main room is 25' x 18' with a couple of halls and perimeter rooms. When I turn my stereo on (8 6SN7's and 16 6AS7's) the fireplace does not turn on.
I don't know what that has to do with anything, but I smile whenever I think about it. The only thing to worry about might be your pocket book if you do it all the time (with tubes). Class A amps pull max current at idle, so your tube life will suffer more.
FenderLover is offline   Reply With Quote
Old June 26th, 2012, 01:00 PM   #18 (permalink)
This quote made my day!
Old June 26th, 2012, 01:03 PM   #19 (permalink)
I think what alarmed me was how hot that chassis got. I had a homebrew 18 watt Lite IIb and it used to heat up quite a bit, but I've been playing a Pathfinder for a couple of years. I could have a cooked an egg on the Jet's faceplate last night.
Old June 26th, 2012, 01:08 PM   #20 (permalink)
gwjensen's Avatar
I've left my tube amps on all day and over night several times. What makes me nervous, though, is not what that might do to the amps, but the risk of a fire. I'm much more careful now.
gwjensen is offline   Reply With Quote
