Old June 25th, 2012, 10:31 AM   #1 (permalink)
New Free Tubes Day: GZ34 & other goodies. Help ID'ing the GZ34
OK, so I was at my Dad's house and he said some guy that he knows gave him a box of tubes. The guy he got them from use to work for HP. Makes sense since some of the 12AT7's that were in the box were have HP silk screens and are made in Japan. These came in HP-labeled cardboard tubes.
A few of the tubes are US-made 6201's (industrial grade & low noise 12AT7's). There was also some US-made 12AU7's and other big tubes like 6080's and other radio tubes (4 digit types). Most are in white JAN-labeled boxes. A few are in GE boxes. I really have no use for the other tubes and will try to narrow down what they are for. More than likely radios and test equip.
Here is the prize:
While looking through the box, I also found a RCA-labeled, made in Gt. Britian 5AR4/GZ34 rect. tube.
I don't have a pict at this time, but how do I know if this is a re-labeled Mullard?
It doesn't have the "tell tale" small hole in the locating pin and the top glass has a ridge/seam in it.
I'll try to get a pict. posted. In the meantime, what codes should I look for and what type of plate structure would help we narrow the manufacture down?
Thanks,
CD
Custom Deluxe is online now   Reply With Quote
Old June 25th, 2012, 11:32 AM   #2 (permalink)
vibrasonic's Avatar
The seam usually means its made in Japan. If you look really close it looks like an x on the top.
They are good quality 5ar4's , much better than whats being made today by far.
They will usually have a smaller bottle than the british or euro GZ34's.
Fender, Gibson, Rickenbacker Guitars.
Fender Amps
vibrasonic is offline   Reply With Quote
Old June 25th, 2012, 11:43 AM   #3 (permalink)
Really? Even with it saying made in Gt. Britian? The seem is only one way.
I also have a known to be real Amprex Buggle Boy that has a the seem in the top.
The plot thickens...
Thanks for the reply.
Old June 25th, 2012, 12:06 PM   #4 (permalink)
bdgregory's Avatar
Post your question on Tubes Asylum. You will get multiple responses from authorities on tubes.
It doesn't seem likely that an RCA tube would be made in Japan, and be labeled made in Gr Britain, but I'm far from an authority on the matter.
bdgregory is offline   Reply With Quote
Old June 25th, 2012, 12:06 PM   #5 (permalink)
Look for etched codes near the base; I61, I63, I65
slider313 is offline   Reply With Quote
Old June 25th, 2012, 12:47 PM   #6 (permalink)
-Not sure if it is nonsense, but, someone once told me to look for pin hole in bottom
of main plastic cyclinder extrusion. Only Mullard did this.
A person who won't read has no advantage over one who can't read.....
Mark Twain
uriah1 is offline   Reply With Quote
Old June 25th, 2012, 01:33 PM   #7 (permalink)
Pictures???
Wally is online now   Reply With Quote
Old June 25th, 2012, 01:52 PM   #8 (permalink)
I'll get some and post them later.
Old June 25th, 2012, 07:44 PM   #9 (permalink)
+1.
BiggerJohn is offline   Reply With Quote
Old June 26th, 2012, 10:23 AM   #10 (permalink)
Here are some pictures of the GZ-34. See what you think.
Name:	RCA GZ34 001.jpg
ID:	132315   Click image for larger version
Name:	RCA GZ34 002.jpg
ID:	132316   Click image for larger version
Name:	RCA GZ34 004.jpg
Name:	RCA GZ34 005.jpg
Old June 26th, 2012, 11:00 AM   #11 (permalink)
I was looking for some numbers near the bottom of the glass envelope, but that tube doesn't look like a Mullard to me.
Old June 26th, 2012, 11:51 AM   #12 (permalink)
Wally:
I'd have to agree. Just doesn't seem like a top notch tube, if that makes sense. I think it is a Japenese made tube.
Old June 26th, 2012, 12:09 PM   #13 (permalink)
It might be a fine tube. If it doesn't rattle and if it provides correct voltages, it is good to go, imho. Someone won't give you 'stupid money' for it like they would if it were a Mullard.
Old June 26th, 2012, 01:27 PM   #14 (permalink)
Yeah, I had not intent to sell, just would like a good GZ34 for a spare for later on down the road.
Thanks again for the input...
Old June 26th, 2012, 01:41 PM   #15 (permalink)
IF a person had an amp on the bench that used GZ34/5AR4 rectiifer tubes, it would be interesting to install that tube and compare it against a known GZ34 and to test it for microphonics/rattling.
