Old May 22nd, 2012, 10:56 AM   #1 (permalink)
Justinvs's Avatar
Modern replacement for a Tweed sound
I made a bad mistake a couple months ago. I loaned a buddy my '59 Vibrolux so he could try his '55 Gibbie ES through it, and now he won't give it back!
What would be a good, relatively cheap modern equivalent to get the Tweed sound when he finally gives my amp back and goes shopping for his own? He mentioned he misses reverb, so I was thinking something along the lines of a Delta Blues or a Classic 30. Any other thoughts?
Justin
Mangling notes since 1979.
Justinvs is online now   Reply With Quote
Old May 22nd, 2012, 11:00 AM   #2 (permalink)
musicmatty's Avatar
I find the Blues Tweed Deluxe Reissue to be very nice..just my opinion of course
musicmatty is offline   Reply With Quote
Old May 22nd, 2012, 11:15 AM   #3 (permalink)
Singin' Dave's Avatar
Sounds like your buddy has good taste - expensive vintage amp taste. I'd recommend a Victoria or similar variant.
But it also sounds like he has a limited budget despite owning a '55 Gibson. A Delta Blues or C30 is a considerable knock down from a '59 Vlux but nice amps that might make him happy.
Singin' Dave is offline   Reply With Quote
Old May 22nd, 2012, 12:06 PM   #4 (permalink)
muchxs's Avatar
Tweed clone. Tastes just like the real thing, less calories.
muchxs is online now   Reply With Quote
Old May 22nd, 2012, 01:43 PM   #5 (permalink)
Peavey Classics/Delta Blues do not sound like a tweed amp to my ears. They look great but the sound is quite different.
D.
Dellis is offline   Reply With Quote
Old May 22nd, 2012, 01:59 PM   #6 (permalink)
vibrasonic's Avatar
It's not going to be an easy quest especially with an amp like that one.
Fender, Gibson, Rickenbacker Guitars.
Fender Amps
vibrasonic is offline   Reply With Quote
Old May 22nd, 2012, 02:09 PM   #7 (permalink)
D.
The Delta Blues will work better with a Gibson than your tweed....If my DB is anything to go by....but its all subjective...I had Marshalls worth a load a dosh...the Blues is as good in many respects ...NOT ALL....and at the price it can be abused without fear
tino7770 is offline   Reply With Quote
Old May 22nd, 2012, 02:43 PM   #8 (permalink)
Justinvs's Avatar
That's kind of what set me to thinking about a DB. I played an Ibanez semi-hollow through one last year and really liked the sound.
Old May 22nd, 2012, 02:49 PM   #9 (permalink)
D.
I don't believe there is any possible way to make an el84 amp sound like a 6v6
sacrificetravis is offline   Reply With Quote
Old May 22nd, 2012, 04:34 PM   #10 (permalink)
Silverface's Avatar
One of the old sleepers is the Fender Musicmaster Bass amp. Both the 6V6 and EL84 models (the way Fender ran them) get a sound close to a late wide-panel Deluxe (I have a 5D3 and A/B'd several Musicmaster Bass amps I worked on for others years ago) with a few little tweaks and a good speaker. They do not *look* the part, but are one of those "close your eyes and just play" amps.
Cheapest route to a tweed-like tone I know of, unless you can find a 5D3 or 5E3 Deluxe clone cheap - and some of those are hit or miss. I've not found an equal to the Treolux or Vibrolux tweed versions...and I've been looking!
“No Chops – Great Tone” ©
Old May 22nd, 2012, 05:11 PM   #11 (permalink)
I'm quite taken with a Victoria Trem de la trem, their take on one of the tweed tremolux variants. Not many around, and they're not cheap. One I'd look for is a 50s Gibson GA6. Relatively a sleeper, as it's squarely in tweed deluxe territory for generally way less bucks.
MD
mad dog is offline   Reply With Quote
Old May 22nd, 2012, 10:35 PM   #12 (permalink)
ojaverde's Avatar
What about a 4 knob brown or blackface 6G2 princeton? It's almost the same amp from what I can tell. You can find them for less than $1000 if you are lucky. There are five on ebay right now. That's vintage.
If you want a modern replacement take a look at the Allen Hot Fudge.
http://allenamps.com/hotfudge.php
"I feel more like I do now then like I did when I first got here". Frank Wakefield
ojaverde is offline   Reply With Quote
Old May 25th, 2012, 03:11 PM   #13 (permalink)
Check out a Valvetrain.
"You've left my heart a vacant lot...I'll fill it with another shot"
John Prine
BWNadeau is online now   Reply With Quote
Old May 26th, 2012, 01:21 AM   #14 (permalink)
I think your friend needs to lend you his '55 ES, it seems only fair ;)
mtshark is offline   Reply With Quote
Old May 26th, 2012, 11:26 AM   #15 (permalink)
Jakeboy's Avatar
Lil Dawg Amps. Great tone at great prices...lots of options. Fulfills the tweed-need.
Jakeboy is offline   Reply With Quote
