Old May 17th, 2005, 01:21 PM   #1 (permalink)
Cab Size for Bass
Thanks for reading this,
I want to build a small cab with 2x8".
I was wondering if I should make it sealed or ported.
I was wondering what the dimensions should be.
This is the speaker........
I want to use 2 in this cab !
http://editweb.iglou.com/eminence/em...kers/beta8.htm
Thanks, John
Tele's and tubes....an accident?......I don't think so...
http://www.tughillregion.com/
Jammin'John is offline   Reply With Quote
Old May 17th, 2005, 04:59 PM   #2 (permalink)
Bluesbob's Avatar
Try this...
Outside demensions: 20"H X 12"W X 11" D with a 2" diameter port in the back. Build it out of 1/2" or 3/4" plywood and make sure the baffle is glued in good and tight. Use 2" or 3" inch insulation for damping. Wire the speakers parallel for a 4-ohm load. Power it with a SF bassman 50 (or maybe an Acoustic 140?). Let me know how it sounds.
What, me worry?
Bluesbob is online now   Reply With Quote
Old May 18th, 2005, 12:38 AM   #3 (permalink)
2x8
How did you come up with such a big cab ?
The specs say a 1.1 cu.ft. box.
I want to set it on a 1x15".
No crossover.
JJ
Old May 18th, 2005, 07:38 PM   #4 (permalink)
Bluesbob's Avatar
I am a genius...
Not really. I just multiplied the estimated interior measurement of my daughter's LA 8 by 2. If you allow for the thickness of the wood it comes out to about 1.2 cubic feet. Not bad for a shot in the dark. I got the port size by taking half of the port diameter on my Basic Black. Don't forget, I said try it and get back to me.
What, me worry?
