#21 (permalink) |
Orange tiny terror 1x12. awesome sounding quiet i.e dorm room and can easily blast it at a gig.
Sing unto him a new song; play skillfully with a loud noise. Psalm 33:3 |
#24 (permalink) |
Eganter Tweaker - either the head and 1x12 cab or the combo. I'll admit - I'm biased. :)
Tube amp with a large variety of tones to choose from and the ability to change out the tubes easily for even more variety.
Jind Guitars/Amp: Gibson Les Paul GoldTop 50's Tribute w/ Humbuckers, Squire CV 50's Tele & CV 60's Strat, Xaviere XV-560 w/ P90s, Ibanez RGR420EX/ART300, Luna Acoustic, Egnater Tweaker Head & Cab, Fender Super Champ XD |
#25 (permalink) |
This. You are just beginning a lifetime journey of "what kind of amp", and you already have a versatile head, so just get the 1x12 and now you have expanded your range of capability. I like head / cab because you can mix things up.
#30 (permalink) |
Spend $299 and get a great 13Watt Tube amp from Fender. The Excelsior amp has a 15" speaker that delivers LOUD clean tones that can only be enhanced by your favorite OD/Distortion pedal, or turn it down for use in the dorm...
#32 (permalink) |
I'm gonna go different than everyone else here, I like my Crate Blue Voodoo BV6212 the BV60 is the same but with 1 12" speaker. You should be able to pick one up for $100-300 and with a couple tweeks mine sounds great (finally) I'm using JJ tubes and replaced a couple 12AX7s with 12AT7s for a little less gain, also the factory pots are cheap junk, but if they work I wouldn't replace them.
I use the overdrive channel for clean with the gain turned about 1/4 of the way up and the master volume clear up. It has a little breakup when played hard without getting too dirty, I also keep the tone controls under 1/2 way up.
-Brandon |
#33 (permalink) | |
#34 (permalink) |
You can do it with 20 watts and a Deluxe Reverb depending on the style of music.
If it's harder stuff in rock with distortion or a band with many pieces, go for at least 40 watts. |
#35 (permalink) |
Check out the Hughes and Kettner Tubemesiter 18, that would probably get the job done, it's loud enough for most club gigs, and it has a direct out on the back for late night practicing. A new one will run around $600, but i've seen a couple used around $400. I also have a peavey classic 30 head that i'm in love with, but by far the biggest factor with heads is the speaker cab you get. I run through a vox AD212 with neodymium speakers in it, It sounds AWESOME. My room mate has a classic 30 combo, and the blue marvel speaker in it definitely doesn't get the right high-end imo.
#38 (permalink) |
If it did, we would all been happy campers, and this amp central page, a thing of the past....keep on dreaming.....and no, the pro junior and blues junior aren't good sounding amps. Not THAT good, anyways
#40 (permalink) |
If you really like your Jet City amp head (and it's a pretty good one), I'll echo the 'add a 1x12 cab' suggestions made earlier. Check out Avatar cabs (they're great, with your choice of speakers, pretty affordable, and they're well-made here in the States & no, I am not affiliated, just a happy customer of theirs)
If you absolutely must have a combo, the Blues Jr's and the Peavey Classic 30's do sound good.
_______________ MIM Strat / Agile AL-2000 > Korg Pitchblack > Boss CS3 > Fulltone Fulldrive 2 Mosfet > Fulltone OCD > Morley Volume Pedal > Line6 DL4 > MXR Micro Amp> TC Hall of Fame > Frenzel FM-5E3 Deluxe Plus |
