Old May 8th, 2005, 02:19 PM   #1 (permalink)
ye olde fretmonkey's Avatar
bad input jack on Classic 30?
It happened again last night.
This amp was making noises before that would go away for a little while when you'd plug and unplug the cord into the jack, then it stopped that behavior.
Then last night at a gig it would only work intermittently...jiggle the cord and it'd work again for awhile (no, not a bad cord). And of course it would invariably quit in the middle of a solo. Any of you guys used one of those jack-reamer things that's like a pipe cleaner?? Do they work?
I wound up playing the gig plugged in through 'effects receive', which of course bypasses the volume and tone controls of the amp and all you hear is compressor/pedal tone...it sounded like ASS. Needless to say it was a long 4 hrs.
Now I need to get it to a tech, and I'm not looking forward to it. I know techs hate working on Classic 30s, and even the jacks are not easy to get to. And I'm hoping that's all it is.
Just 'cause that's the way things are, that never did make it right.
ye olde fretmonkey is online now   Reply With Quote
Old May 8th, 2005, 05:07 PM   #2 (permalink)
alotas123's Avatar
Who are you taking it to?
Looking for good amp techs. Thanks.
Play that thing, make it sing!
alotas123 is offline   Reply With Quote
Old May 8th, 2005, 05:09 PM   #3 (permalink)
I used to go to Bill Webb at Austin Vintage Guitars, but he's expensive and slow. I think this time I'm heading to John at Musical Exchange on North Loop...he's got a good rep around town.
Old May 8th, 2005, 05:12 PM   #4 (permalink)
alotas123's Avatar
Billy is as good as they get, but he has a whole lot of work (no surprise). That's why I was looking around...
Thanks.
Old May 8th, 2005, 10:09 PM   #5 (permalink)
reverbbb's Avatar
I had the same problem on a Crate VC2110. I called Crate and they were able to sell me the exact jack for like $3.50 plus $3.00 shipping. I got it and installed it into the circuitboard myself. No more cutting out or noises. This was about three weeks ago.
"I come here to reflect a little."
Buffalo Blues Band
reverbbb is offline   Reply With Quote
Old May 9th, 2005, 10:35 PM   #6 (permalink)
e-merlin's Avatar
That is the only problem I've heard gigging musicians report on the Classic 30. The jack is soldered right to the board, so it's not the most robust connection if the nut on the jack gets loose. If that's what happened, you have to take the chassis out and remove the main board to re-solder it. Big pain in the butt, but not overly difficult for anyone who can use a soldering iron. I've heard of a couple of guys removing the factory jack and soldering wires to the board, then mounting a metal jack to the chassis. But you have to make sure you insulate the jack from the chassis so it doesn't ground out.
'tone is in the underpants'
Old May 11th, 2005, 09:32 AM   #7 (permalink)
That's sho' nuff what wound up being wrong.
It's gonna cost me a shocking $31.
