The Blackface/Silverface transition
Are there any hard-and-fast parameters for this?
Did, for instance, the Deluxe retain the blackface circuit for a couple years? Did others? I seem to remember some silver amps ('70-'71) having the same circuit as blackface. I could always be wrong! When the circuits changed, did the whole line change? |
I believe it's commonly accepted that 1968 SF "blackline" models are usually BF circuits, but not always guaranteed. "Blackline" refers to thin vertical black lines dividing control sections/knobs on the Silver face plates. The degree and timing of changes varied by models, however, with the lower powered models (Champ, Princeton, Deluxe Reverb) being less affected than the larger models.
A few years back I got a book about the history of Fender amps ...... " Fender Amps - the first 50 years" written by Sprung and Teagle IIRC that has lots of good info and lots of great pix. Great reference if you're interested.
Reflection upon my playing is a reminder to keep my regular job..........pays better but not nearly as enjoyable!! |
Charlie, as JD notes, the small amps...Deluxe and smaller....chagned mush less than did the larger amps. The first SF amps came out in April of '67 and are identical to the BF amps of the same model that came before. The schematic changes started in May of '68....and the date of the changes vary from model to model.
There are changes in the type of wire used and in the lead dress that have nothing to do with schemtaic changes. There are also changes in the cabinet construction that some of us take note of. I prefer SF amps that were built prior to the change to the glued-in baffle board with a separate Velcro-attached grille board. Even with the changes to the circuit, to the wire type and dress, and to the cab; there are some great amps in the SF era. I would take a SF model Fender to the same model of REissue anyday of the week for my purposes. Here are some articles that line out soem of the changes to FEnder through the years....and give us some great info on what to look for in a vitnage FEnder. http://www.superchamp.dk/papers/dati..._tube_amps.htm http://www.superchamp.dk/papers/dati..._tube_amps.htm |
- cabs do differ (pre/post '71)
- caps do differ (pre/post '68) - certain resistors do differ (0,5 vs. 1 Watt) - material of eyeletboards seems to differ - various circuit-values do differ - B+ voltage/nodes do differ - wire does differ - acthodebypass-caps do differ etc., etc. |
A good rule of thumb to help one quickly tell (if you don't have production codes memorized) is to look at the wiring. If cloth, chances are it's still the BF circuit. If it still has a the GZ-34 & cloth wiring, more than likely it is the BF circuit. If the rect. is different, all bets are off and you need someone familuar with this circuit to verify.
Here is mine June of '67 Deluxe Reverb. |
it's common knowledge that there are early silver examples of all models with blackface innards.
i've always wondered if, during that transition period, any blackface amps came out of the factory with any silver-face changes. . .
My band: The Pointed Firs |
#8 (permalink) | |
Open it up, if it has blue caps and cloth wiring it's BF. Dog turds and plastic, it's SF. I saw a transitional Bandmaster the other day. Mixed cloth and plastic, dog turds. So they ran outta Ajax caps before they ran outta cloth wire... Some amps got dog turds all the way through. I guess Champs weren't good enough for blue caps. Yup, they got big ugly matte brown caps that look like dog poo. |
A simple rule of thumb, first glance check, most from that era have a date stamp right by the PT. If the stamp is post May '68 you're virtually assured it the early SF circuit, which is the runt of the SF litter. DR's & PR's never saw much in the way of changes, but the DRs will have the suppression caps, alrered PI resistance values, higher B+ and changes to the dropping resistor values in the doghouse. Most sound great and don't need much "blackfacing".
#12 (permalink) | |
It now has a PT that I bought from Michael Clark back around '97, and a GZ34 recto. I don't know what rectifier the amp came with originally, though... |
There are exceptions to the BF/SF circuit rule stated above I had a 68 Bandmaster Reverb (which I know never was issued in a BF version -- only SF) which had the BF-era blue molded caps, cloth wiring and a GZ 34 rectifier, but which also had the SF-era supressor caps and the dreaded bias-balance circuit. I understand that in general, the larger amps received the SF changes first and the smaller amps (Champ, Princeton, and Deluxe Reverb) retained their BF circuits into the 1970s (although with tweaks such as plastic wiring and brown or red coupling/tone caps).
#14 (permalink) |
I have encountered a 1969 silverface super reverb that had the paper tag saying it's a BF circuit, but when my tech checked it he told me it actually was the SF circuit (can't recall the exact markings eg. AB763 or smtn, if anyone wants I can check). The 69 dating was deduced from the transformer and speaker markings.
#15 (permalink) | |
#16 (permalink) | |
The only time a tube chart is really of much importance is when it agrees with the soem or all of the particulars of the amp into which it was glued. Ex: that 1957 5E3 with the 5F6A model designation was correctly date stamped. That is, the date codes in the amp all matched. |
