#41 (permalink) | ||
When I got home, I got on the computer and started listening to the Fender Mustang II demo's on YouTube, since you guys had mentioned that they were worth a listen. Wow! The Fender Mustang has some VERY nice sounds, and I like that you can add/subtract EFXs to/from your preset sound. I also like that it seems fairly easy to use. I gotta go back to GC tomorrow and PLAY one of those Mustangs!
Telecaster > Mustang Floor > FOH/BJr III/HRDx III/V1512T |
#42 (permalink) |
Vox DA-20 if you can find one. Like a pathfinder, but some modelling, effects and 2 speakers. A little more portable, as it has two low-wattage modes which are battery powered. They were marketed as a "busker amp".
Oh yeah, there's a microphone input too.
"Rumours of my sobriety have been greatly exaggerated" - Keef. |
#43 (permalink) |
The trouble with little amps is they sound good at home but when put into gig service, you are reminded that they are little amps.
I would try to find an amp with at least a 10" speaker, preferably a 12. And if you play clean, at least 30 watts. But if you don't need big sound, the Pathfinder 15r is great but has limitations (speaker and watts) as you start to push it. There are lots of good suggestions here so far but make sure you turn the amps up when you try them, everything sounds good at pratice volumes. Also check out Fender SS stuff, used princeton 65, deluxe 85, champion 110, all can be good.. Depends on what small and portable is to you. good luck. |
#44 (permalink) | |
#45 (permalink) | |
