In general, the GZ34 tends to tighten the sound up and make it a bit more focused, while the 5U4GB is softer and more loose. The tone itself doesn't change much, just how it's presented and how the amp feels.
For most applications and usages, they're fairly interchangeable. However, I've heard disagreement on whether there may be problems with voltages and certain transformers in specific circumstances. I'm not really familiar with your amp and its parts, so I can't give you an opinion, let alone an answer. For home use, it probably wouldn't matter under any circumstances. If there were going to be issues, high volume gigging would be where they'd probably show up. Even there, however, disagreement would exist, and it'd be more over whether the imbalances actually caused harm than whether they conceivably might. Is that confusing enough? |
The PT is designed to use a 5U4, and no amount of BF modding is going to change the turns ratio of the PT, short of replacing the PT.
Here's what I'd do. First off, with a 5U4 in there and the amp properly biased and idling (no signal), measure the actual plate voltages on the 6L6s. If the actual voltage is 440 or higher, leave the 5U4 in there. If the voltage with the 5U4 is under 440, then swap in a 5AR4 and rebias. Measure the plate voltage again. Anything under 470 or so will be OK. The higher the 6L6 plate voltage, the more power and headroom the amp will have. |
#4 (permalink) | |
#5 (permalink) | |
#6 (permalink) | ||
I think the bottom line on this is that people seem to think that using the GZ34 in a 5U4 amp would seem to be a logical step towards blackface performance, and that is simply untrue. In the amps with the 5U4 transformers, your voltages will be closer to blackface specs with the 5U4 in place. I always leave the 5U4 in these amps. |
#9 (permalink) | |
The original poster has a 70s SFSR, that has been BF modded. His PT is set up for a 5U4, so no problems there. But with a real BFSR, I agree. 5AR4 or Weber copper cap. |
