Old March 25th, 2005, 10:59 PM   #1 (permalink)
Mik
Mik's Avatar
Vox AC30: swap out the GZ34 for a ???
Requesting SAGacious advice: is it possible (safe, "not a waste of time" etc) to replace the AC30's GZ34 with a rectifier tube that delivers some sag? Which tube(s)...would a 5U4GB work?(I just want to plug in the existing socket with no modification). What are the likely results in a recent '03 or '04 AC30 "Korg era" reissue?
Thanks,
Mik
a "motor-bike with a touch of blood in it is better than all the riding animals on earth, because of its logical extension of our faculties, and the hint, the provocations, to excess."-T.E. Lawrence
Mik is offline   Reply With Quote
Old March 26th, 2005, 12:25 AM   #2 (permalink)
Tremo's Avatar
Go with a Weber copper cap rectifier. It's a ss rectifier with sag. Tell Ted you want a saggy one, he'll fix you right up. It plugs right into the socket.
You do realize that with the additional sag in the B+, when you are in heavy overdrive, this will increase your crossover distortion?
Old March 26th, 2005, 12:59 AM   #3 (permalink)
The GZ34 sags a lot in that amp. You can get the same basic amount in a copper cap, as mentioned above.
Old March 30th, 2005, 08:02 AM   #4 (permalink)
I have found the the GZ34 sags much more than the 5U4GB. In my Matchless clone I the GZ sounds smooth and compressed and the 5U4 sounds stiffer (crisp and clean) great for country picking and that clean matchless sound.
New62 is offline   Reply With Quote
Old April 1st, 2005, 12:38 PM   #5 (permalink)
Mik
Mik's Avatar
Surprised to hear about GZ34 sag
Thanks for the responses.
Tremo, I didn't think of the Weber copper cap option. Thanks for the warning about c/o distortion.
I don't find the GZ34 all that "saggy" in the AC30. I'll reassess. I've found the 5U4GB quite saggy in another application.
Mik
Old April 1st, 2005, 03:28 PM   #6 (permalink)
Bill Ashton's Avatar
Am I correct that...
the AC30 does not have a standby switch? I was of the impression that the GZ34 was a "slow warmup" tube that did not slam the circuit with voltage.
So ifs thats the case, perhaps you would not want to make a change. Am I off base here?
Bill Ashton is offline   Reply With Quote
Old April 1st, 2005, 03:35 PM   #7 (permalink)
Mik
Mik's Avatar
Re: Am I correct that...
The Korg reissue has a standby switch, fwiw.
My understanding that generally any tube rectifier warms up "slow" enough not to slam and cause cathode stripping or other unwanted results.
I'm in no hurry to mess with the rectifier tube but I did want to ask about increasing sag with a swap, again thanks for the answers guys.
Do the copper caps require a standby switch? I thought copper caps behave just like tubes they replace.
Mik
