Requesting amp suggestions for small restaurant gig
Hey folks,
I want a small amp for a restaurant gig I'm currently doing. We play jazz, blues, funk, rock. I'm currently using a DRRI, but I can't get it to break up without getting way to loud for the room. I would like to get another Fender, and something with tubes. What do you folks suggest? Thanks! Dana
www.good-ear.com www.miles.be Study music and not the musicians who play it. - Lincoln Goines |
Do you want power tube break up at coffee room volumes? I have a 1 6v6 with a 12 in it and it would be too loud for that I would say. So if that is what you want you will need an attenuator.
If you can deal with a pedal or preamp tone there is another option. I like the Silver Dragon for a tweedy-plexi vibe in pedals (others have their favorites). The Blues Jr. preamp will get you a decent sounding lover volume preamp distortion. There are other options as well and I am sure someone will mention them soon. Dale
Guitars: Teles, LP, others. Amps: El Diablo, Richter 5E3, 5E3 Head, Traynor Bass Master II, Epi Jr Head, Gretsch/Supro, 60's Univox and others. Current Board-Guitar>Tuner>Java Boost> Huckleberry>Fuzz Head>Top Fuel>SFX-03> Keeley Comp>Clone Chorus>FL3> Amp |
Low Volume Breakup
Well, the Blue's Jr. might be an option or (if you have money to burn) the Carr Mercury would be incredible.
If it were me I'd stick with the DRRI and use a Boss Blues Driver with either the Analogman or Keely mods. |
Two words:
Champ, and external speaker cabinet (well a few more than two) See the thread about amp comparisons in the barn for my comments about running my Champ into two Celestion G12H0-80's. We're talkin' GLORIOUS output tube tone at a very managable volume.
Timothy Jon Lamb |
Yeah, I'd also say Blues Jr... but at 15w through 1x12, it will get pretty loud by the time it breaks up. Maybe a Pro Jr? They don't get very loud, certainly not enough to bother a drummer. Hee. ;-)
Of course, I'd use the Crate V-Series equivalent (V1512) rather than a Blues Jr. – but that's just me. ;-) Best of luck, CS |
#6 (permalink) | |
With the Junior you can raise the volume and lower the master to get breakup at low volumes. And they said breakin up was hard to do! Fret
See, I didn't reconize ya when ya first drove up till ya stuck yer hand out and wove then I seen right off who ya was and knowd ya. Epiphany: The Ignore List can make the TDPRI and even BETTER place to be! |
Attenuate It !
I have a weber MASS attenuator on my Deluxe and it works great. 8)
If you only want to drop a little headroom the Load Dump is the ticket ! JJ
Tele's and tubes....an accident?......I don't think so... http://www.tughillregion.com/ |
I would try to find a used Fender Princeton Chorus DSP. About 40 pounds, 50 watts, 2 10s, stereo digital effects, clean and drive channels, 3 button footswitch. This is a great amp for a wide diversity like you described. The effects are great, with a wide variety of choices, very useable distortion, with a limiter, and also clean enough for jazz. With the footswitch, you can set several different sounds, and leave your pedals at home. Also, but not least, this amp even sounds good with an acoustic electric. It's a shame they don't still make them.
"German is the language God uses when He really means business." --FZ |
Pro Jr!
I have two Pro Junior's, and I think they're a perfect fit if you're not looking for lots of clean headroom.
I wouldn't play 'em with a big jazz band, but it's great when you want some real tube break-up, and it's such a neat, simple circuit. Work that volume knob on your guitar and you can do wonders with it. |
Champ
Yeah, I've used a Champ for those sort of gigs and it worked just fine. 'course I only had to get over a standup bass and acoustic guitar.
I also have a little Kustom Tube 12 for those occasions. 2 channels and tone boost, and it's the size of a lunchbox.
Just 'cause that's the way things are, that never did make it right. |
#13 (permalink) | ||
#14 (permalink) |
Personally, I think anything over 6 watts is gonna be too loud.
The Reverend Goblin would be a perfect fit for this gig. Switchable 5/15 watts, lots of tones (including the DRRI), small and light amp. Built like the best of boutique and mass production. With this amp, you've always got the option to switch to 15 watts at the flip of a switch to get more volume. |
#16 (permalink) |
Something a bit older?
http://www.jacksonsrareguitars.com/d....html?id=20081
http://www.jacksonsrareguitars.com/d....html?id=17975 I'm sure you can get a better price over your way though.
RN |
#17 (permalink) |
small amp
http://www.sombrabella.com/bumbox/
http://www.songworks.com/pages/1/index.htm Try these....personally, the songworks 1/4 watt is the best sounding (for MY ears), but the Hamster might be the most versatile.... 'course, a custom 2 X 8" cab doesn't hurt either |
#18 (permalink) |
Relying solely on natural tube distortion will cause lotsa fiddling problems and experimentation - been there, done that - it's a big pain in the pitoot, and I avoid it like the plague.
The absolute answer is to just take any ol' amp yer happy with and use a good OD pedal (NOT a distorto pedal), and you'll be a very happy camper as tweaking both the volume and overdrive will be quite easy. If you use a decent wattage amp, you'll have both bases covered: natural clean headroom and bluez/rock overdrive. These dayze, I never leave for a jam/rehearsal/gig without a Barber LTD. YMMV. |
#19 (permalink) |
weber minimass
Go here:
https://weberspeakerscom.secure.poww...eber/atten.htm and order a mass. Just email them and tell them what amp you want it for and they will hook you up. This has been the best piece of equipment I have bought in several years. Just as simple as a pedal, you just plug it between the speaker and the amp. No soldering required for your dr. My champ has been jeleous since I started using one with my princetion reverb. You can spend a lot of money and time finding low watt tube amps and different pedals. In my opinion this is the best solution. For your situation it sounds like a mass would be better than a load dump. The MASS is much more versitile in any case. But to be sure, just email them, they will know. |
