RCA 6L6 tubes are toast?
I've seen some RCA 6L6GC Black Plates for sale that have circular burn(?) marks on the glass, and one of which has some white flakes in the tube. Are these tubes toast or worth trying at a reasonable price?
| Sponsored Links |
The sure way to know is to test them on a tube tester and listen to them in an amp. White flakes may only be mica from the insulators and the deposits on the glass may be manufacturing coatings. Can you post a picture?
Check your PM inbox. Gary
"I need to learn some new scales and stop obsessing about this stuff." http://www.myspace.com/slickshoes |
Here's what they look like:
http://imagehost.vendio.com/bin/view...ary, check PM. |
the silver / black is OK
I've used older NOS tubes with that type of circular black pattern ... the one pictured on the right with the bubbly brown stuff looks a little funky though.
but a tube tester should tell all. cheers, Mike |
#5 (permalink) | |
Re: RCA 6L6 tubes are toast?
The fact that one is a bit chard looking could mean that there is a tiny vacuum leak around the electrical connections. which has introduced oxygen into the envelope. The white stuff (which I do not see in the photo) is also evidence that contaminates have been burned off probably over time. I personally would not bother buying this tube. pjb |
#7 (permalink) | |
STUDIO USE
pjb |
