NO INTERNAL SPEAKER JACK ON '57 TWIN?!?!?!
:x
Well... Just got an e-mail back from fender stating: "We’d advise against using an attenuator with one of our amps. We don’t test them for use with attenuators, so we don’t know what to expect when using one. The ’57 Twin is designed to operate at 4ohms, but it can drive a 4ohm extension speaker in addition to its internal 4ohm load, for a 2ohm total speaker impedance. There’s not a jack for disconnecting the internal speaker. Also, remember that it’s not safe to operate a tube amplifier without any speakers attached. Thanks again for choosing Fender." Man oh man...I hope they're kidding. |
| Sponsored Links |
#2 (permalink) | |
Are you talking about the tweed 57' Twin RI?
I'm running into a similar problem with my '59 Bassman RI. The speaker leads are hardwired directly into the chassis....so I can't use my Vibratone without some soldering work. Not that big a deal though....just make a break in the speaker wire (where it comes out of the chassis), and solder on a male 1/4" speaker jack onto one end, and a female 1/4" speaker jack onto the other end. Keep'em plugged together when you're not using the attenuator, then disconnect them when you are. If you're properly using the proper attenuator, you shouldn't damage the amp. I'm sure that's just something Fender Customer Service has to say. I can't imagine that they would openly endorse the use of an attenuator. That opens the door for all sorts of warranty claims.
Word to that...And yeah, it is a tweed 57 RI
I figured they didn't want me using something like that... And I do figure I'm going to have to make a solder connection like that you're talking about...I don't suspect it'll be too difficult, but, we'll just have to find out I'm afraid... Cross your fingers..and thanks SB |
Load Dump !
I have a Weber Load Dump on my Vic. LP Twin !
JJ
Tele's and tubes....an accident?......I don't think so... http://www.tughillregion.com/ |
jacks
Mono
JJ
I'd give that amp a run at standing and delivering on its own before slapping it around with an attenuator, slicing speaker cables, invalidating its warranty...
Fender is not kidding. Just a GUESS (haven't played or seen a '57 Twin-I'd love to): I don't think a 40 watt vintage style tweed amp is too much amp for playing rock and blues in a band. If it is too much, a lower power amp may be a better fit-tone and volume-than an attenuated/modded higher power amp. All JMHO. Mik
a "motor-bike with a touch of blood in it is better than all the riding animals on earth, because of its logical extension of our faculties, and the hint, the provocations, to excess."-T.E. Lawrence |
#10 (permalink) | |
Warrantee.
pjb p.s. I have found the Fender warrantee worth little to nothing anyways. Problem being that most certified Fender Repair men around here are actually more interested in washing machines and would happily swap out an Orange Drop for a ceramic disc. |
#12 (permalink) | |
On the other hand I use one of these, pricy but it sounds great in front of my Vibroverbs: http://www.badcatamps.com/images/twotone_big.jpg pjb |
#16 (permalink) | ||
#18 (permalink) | |
gil |
#20 (permalink) | |
http://www.fender.com/support/amp_sc...Schematics.pdf It shows only one speaker output (with a jack) and a plug at the end of the speaker wires. I guess the guy at Fender didn't know what he was talking about . Looks like you're in luck! gil |
#23 (permalink) |
Absorber panels from Clearsonics normally used for drum shields work great in front of a guitar amp. You can turn it up and put the panels in front and it will no tear the face off the people in the front. Slap your favorite mic on it and let the PA do the rest.
#24 (permalink) |
I like to use the removable lid from my small pedal board (13x28") as a baffle when needed. It has an foam egg crate lining. If my amp is mic'ed (and in the monitors), I have no problem placing the "baffle" right up to my combo. I can still feel the vibration behind me. Moving the baffle away from the amp allows me to vary my stage volume, but alway protects the audience. I wish I would have know this trick a long time ago. BTW, I also have a Hot Plate, but I only like to use it at minimal attenuation settings. Either way, I often use the Hot Plate with the baffle. The Hot Plate is mainly for stage volume. The baffle helps with the audience's sound mix and hearing protection, and my stage volume.
gil |
#25 (permalink) |
I have one of the 57 RI twins. Very loud amp. I play in a Chicago blues type of band so I needed less vol. I took the amp to local fender repair shop and the guy said I could convert to 6v6. I did and it sounds great
#27 (permalink) | |
Too Loud
I just gotta ask though ! Why did you buy a powerful,big sounding amp if most of the time you don't need the headroom.......... :? You would be much better off with a smaller one that you can turn up..... :P .....'cause that's where the mojo st |
