got a Pro Jr. today ...
i like it ...but i got it home and noticed one of the power tubes isn't glowing so i guess it's a good enough reason for a retube ...i'm embarrased to say i don't remember checking the tubes out when i played through it , it sounded fine playing it
The fact that no one understands you doesn't mean you're an artist. |
#3 (permalink) | |
Are you sure the tube isn't glowing/working? I've had power tubes, including EL84's, that have had their glow obscured by the "paint" on the top of the tube.
Mik
a "motor-bike with a touch of blood in it is better than all the riding animals on earth, because of its logical extension of our faculties, and the hint, the provocations, to excess."-T.E. Lawrence |
#5 (permalink) | |
yep....
Ya could do a lot worse
I really like toting my PJ around and putting a mike in front of it when necessary. Guys on the sound board love me, and I like the tone.
Getchya some o' them JJ's that people brag about here. I got some NOS JAN Philips back when they were reasonable. |
#9 (permalink) | |
i went ahead and got some Peavey brand Sovteks today just so i could play it (10.00$s) , it's nice it brings out the tone of my strat better than any amp i've played, i like how you can crank it and roll of the volume to clean it up and it keeps the volume up ( i have it mic'd and listen to it through my headphones through an Alesis mixer) one word huge
#10 (permalink) | ||
I've got his retube set for my Blues Junior on route as we speak ... er, type. |
Another $0.02 from me
If you're looking for clean headroom, that's not really what the PJ does well, but you can tone down the preamp stage a little bit by replacing the preamp tube with a lower gain selection than the standard 12AX7.
Or just keep the pickups and/or volume knob down. |
#13 (permalink) | |
Re: Re-tube
and i don't really want to clean mine up just bump up th spot where it does overdrive but the new tubes actually did that ...i may have said this before but i cranked it to 12 and used the guit's vol knob and it did just what i wanted ...sweet lil amp it's fun, and i really dig th space it doesn't use
#14 (permalink) |
I found my Pro Jr. to be VERY sensitive to tubes. I played around with different tube combinations for days before settling on Tesla EL84's and a couple of RCA blackplate 12ax7's. Made a HUGE difference.
My blood type?? AB763 |
Tube changes
First time I changed tubes, I was nervous about messing something up, but (don't do this if you don't know how to do it safely) I referred to the schematic that came with the amp and checked out all the voltage reference points with a VOM, and everything, while different, was within tolerances stated on the specifications on the print.
Different tubes absolutely change the reference voltages, but in a relatively subtle way. How much of the difference is that subtle change and how much is the tube, I dunno. Biggest difference, to me, was speaker. I like the stock blue frame, but don't care for the stock brown frame. |
#16 (permalink) | |
Re: Re-tube
I think the PJ is very sensitive to its tubes because the tone stack and circuit are so simple -- there's not a lot of "stuff" affecting the tone of the tubes. This, to me, is the PJ's great strength. |
#17 (permalink) |
rehearsed last nite...
just put it on near the end with my pedals going thru it ...everybody seemed impressed (usually i get the "not another piece of gear routine...lol) just for the sake of backup i think it'll be a live addition, with a mic of course...beats toting a 212 and a 410
#18 (permalink) |
Thanks for the info
Daddy Elmis - Thanks for your reply. My wife bought me a Tweed PJ right when they came out, quite a few years ago, like '96? I'm not sure if I was on the TDP yet, but at the time I knew very little about rebiasing. I was aware of the benefits of retubing, though, and I switched out the stock ones for NOS. My tech at the time was sure that he had to change the resistor to correctly set up the amp, and he did. I'd always wondered about that. Seems like he knew something about what was going on, but not enough. That, or he was taking me for a ride.... What is the recommended bias current for that amp anyway?
#19 (permalink) |
I think Cliff's tech did the right thing, installing the correct resistor to properly bias the new power tubes. I've swapped out stock Sovtek EL84 tubes in 2 Pro Jrs for NOS 6BQ5's, installed NOS 12AX7s, and found no substantial differences in amp performance. (I admit I did not rebias). So the Sovteks went back in. I don't find the PJ "sensitive to tubes". :? My mileage varied!
Why would EL84 power tubes not need rebiasing, in a fixed bias circuit, as much as other tubes? Mik
#20 (permalink) |
Folks more knowledgable than me (and that's a hell of a lot of people) and several who, to me, are experts in the field of tubes and tube amps, have told me that EL84's are low powered and generally are not as sensitive to bias "mismatch." Not saying that a proper bias is not smart, won't improve performance, etc., just that (according to my info) you are generally ok to plug and play EL84s (more so than higher powered tube -- 6L6, EL34, etc.).
Now, if I had a bias pot I would rebias with EL84's myself. But to have a tech pull the chassis, cut and replace/resolder a resistor on the PCB, seems like a lot of trouble (and introduces the potential for damage) that, to me, isn't worth it. Off topic, but one thing that strikes me as a really "nice to have" feature on Tone King amps -- they put the bias point and built in meters on the back of their amps so you can easily check and change bias. As I always remind people, however, checking/adjusting bias is a relatively recent phenomenon. Back in "the day" everybody just plugged and played (except maybe touring pros that had amp techs traveling with them). Interestingly, this was also the "golden age" of tube amp tone from today's perspective (Hendrix, Cream, Butterfield, Who). |
