Question regarding Marshall EQ (1972 NMV 1986)
Hi,
A short question for those in the know: I have been using a Marshall Non Master Volume head (1986) from -72. Even with a 1936 2x12 cabinet I find bass and lower midrange content rather overwhelming. Bass control is always on 0, Mid is on 50% and treble is maxed, presence is on 70-80%. I like the sound it makes but it feels slightly weird to have to use the extreme settings. Is this normal? Could it be that the tubes I use generate a lot of low end (JJ:s)? Could it mean that it is time for a cap job? Harald |
It is normal
If you had a lead amp you'd have to do just the opposite. I prefer the bass/PA amps as you can actually turn up treble and presence without getting every dog on the block howling. I have a '68 SuperBass and set it very similarly. I also have a '71 Lead, and I can only turn the presence and treble up to about 3.
Which input do you use? 4-input non-master Marshalls typically have a dull channel and a shrill channel. Lotta guys bridge both channels and blend the two volumes to find their tonal balance.
#6 (permalink) | |
You may want to try to locate some Mullard 12ax7's for the preamp, this brightened up my 50 watt lead model even more, and also made it louder. But I cut the bright cap on my bright channel and replaced it with a much more sane 100pf value cap, instead of the stock 5000pf, which will shear the nuts off a dog at 40 paces. |
Thanks to all of you for the input. They way it sounds makes more sense now that I realise it is the bass model.
I like it a lot but still feel I could use a bit more brightness. Today I played it with Tone Bones (triode) through the speaker of my Princeton 2 and it is a lovely sound... sparkle and grind, dirt and definition. I will definitely try to find a Mullard 12ax7. Should I get one for the first position or should I try to switch out all of them? Harald |
