Princeton Chorus as TRII ext. Cab - Stupid?
I apologize in advance for asking stupid questions. Seems to be a talent of mine.
I've got an old Princeton Chorus amp that is having volume variation issues, and I don't really think is economically repairable. I'm wondering if I can use the cabinet for the PC as is, as an extension speaker cabinet for a Twin Reverb II (The 2x12 combo version). The manual on the PC is here: http://support.fender.com/manuals/gu...rus_manual.pdf Shows the cabinet with 2 8 ohm speakers. I'm not where the amp is right now, but I believe each speaker is wired separately to the amp (the double amp 2 channel feature of the PC). I also believe the TR II's extension cab output jack is labeled "4 ohms or greater" but again, I'm not looking at it right now. Would use the PC "cabinet" as an additional cab, along with the 2x12's of the TRII. Really more of a "what would that sound like?" project. Is this possible to do without damaging anything? Other than eardrums? |
Wing,, you need to wire those two 8 ohm speakers in parallel for a 4 ohm impedance. Then, when you plug into the TR's Ext Spkr jack, which is in parallel with the Main spkr jack, the amp will see a 2 ohm load. FEnder provided for this mismatch, and the amp will have no problem with it.
I don't know if those speakers are up to everything a TR can throw at them, but used 'sensibly', they should be alright. Max the volume on the TR and those speakers won't be alive long. |
A kinda related question: Any advice on how to fabricate or build a "close up" piece to go in the PC cab to replace where the faceplate of the amp was? And, as a bit of useful background, I suck at carpentry/fabrication skills.
I've tried some Deoxit in both volume pots. The volume drop occurs after the amp has warmed up (10-15 minutes), and affects both channels equally. I'm probably gonna try a few more little things like that before giving up, but they haven't worked so far.
Mike, the best way to resolve all of the sonic problems with that amp is to do what you are proposing....pull the chassis out and make good use of the cab.
Imho, it is not worht hte expense of working on it. That said, it is a heat realated problem. Some 'cold spray'...I forget the name of the products... that will chill components while they are exhibiting the problem might help locate the problem...might not. I would guess that there is a problem with electrolytics, transistors, resistor, other caps.....long list, right? |
#14 (permalink) |
I've been looking at getting one of these amps in a trade, and was thinking about wiring it for a couple of 8 ohm outs (keeping the stereo) and then rewiring a 4x12 as an 8 ohm stereo cab. Anyway, in doing so, I came across this, which might be worth looking at before/while/after you tear things up:
http://music-electronics-forum.com/t17705/ |
