Old January 3rd, 2005, 03:26 PM   #1 (permalink)
brad paisley and drz sound
ok i was wondering if i get the mazerti or the carman ghia will my tele sound like his i also have his pickups ... but zac says he mostly only uses a little dealy so i should be able to get that sound right
paisley_tele is offline   Reply With Quote
Old January 3rd, 2005, 04:23 PM   #2 (permalink)
Re: brad paisley and drz sound
To be honest, if I had Brad's own personal guitar(s), amps and effects, I'm not sure if I could recreate his sound because that boy can play. However, I'm sure you've much more talent than me.
Have a look at his website: www.bradpaisley.com. Under Tour / Brad's Gear, there is a full list of his guitars, amps and effects. That should give you some idea as to how he creates that fabulous tone.
Good luck and report back your progress.
:D Peter
PeterUK is offline   Reply With Quote
Old January 3rd, 2005, 07:19 PM   #3 (permalink)
Pepi's Avatar
I was surfing the net the other day and found a page that showed Brad's equipment. He has a lot of effect in his rack and pedals too. I finally nailed Brads tone with my V-amp2. I use the 15 watt Class A amp with compression and just a bit of delay. I'm really begining to dig these modelers
Pepi is offline   Reply With Quote
Old January 5th, 2005, 10:17 AM   #4 (permalink)
DR. Z Mazerati
I've got a DR. Z Mazerati and as soon as you plug a tele into it you can certainly hear the basis for Brads tone. After that his talent takes over.
Teleman is offline   Reply With Quote
Old January 5th, 2005, 11:16 AM   #5 (permalink)
Start with a Mazerati w/an "British" AlNiCo speaker or 2 and start from there. You might also want to push the front end a little but that's just my take on it. ;)
WrapAround is offline   Reply With Quote
Old January 6th, 2005, 10:56 AM   #6 (permalink)
charman ghia
the mazarti is pretty $$$$$$ so would a carman ghia work same just lower watts i think
