Old December 21st, 2004, 03:00 PM   #1 (permalink)
nasonm's Avatar
Reverb Tank Mounting & Speaker Phase Questions
the amp I just got (fender london Reverb) has the reverb tanks in a bag (like most) but it's not screwed down too well. What the best way to screw down a reverb bag?
Should I use rubber washers to keep it off the cab?
Does it even matter?
Also, the speaker connection for this amp is a 1/4 phone jack. I have to make the cable myself using an unbalanced 1/4 male plug(not a problem). My question is this: Does the tip of the plug (blue wire) go to the + terminal of the speaker (the white wire woud run from the sleeve of the plug to the - terminal)?
Does this sound right?
"i have learned to just grit my teeth, change the subject, consider their deep total ignorance, fondle the thumb picks in my pocket and go on my way" - bender-freak
It's been lonely in the saddle since my horse died
nasonm is offline   Reply With Quote
Old December 21st, 2004, 10:40 PM   #2 (permalink)
Pierce's Avatar
tip is hot
the reverb bag is held down by two screws/finish washers like the back panel screws..did you buy the london reverb on HC for 90$ ish dollars?
they are good sounding amps for solid state
tom
Pierce is offline   Reply With Quote
Old December 22nd, 2004, 08:59 AM   #3 (permalink)
nasonm's Avatar
Re: tip is hot
tom
Yup....$110 Shipped. It doesn't look too shabby either. I have a Carvin 12" 100 Watt that'll be going in there soon.
At the very least, if I don't like it, I'm sure I can get my money back in re-sale.
