Champ voltage question
I just checked the voltages in my 1966 Champ and compared them to the schematic. They are all high. Pins 3 and 4 on the 6V6GT are supposed to be 350v and they are 400v. Pin 8 is supposed to be 19v and it's 25v. and so on for all the other voltages. Is this because when this amp was designed, you were lucky if you got 110 volts from your wall outlet, and now you get 124 volts, or is there something wrong with my amp? I'm supposed to be getting 330v from my filter caps and it's 380v. If there is something I can do to bring down the voltages, could someone let me in on it?
#2 (permalink) | |
Re: Champ voltage question
"German is the language God uses when He really means business." --FZ |
There's nothing you can do, live with the voltage ya got. Use a JJ 6V6, it will handle the higher voltage and plate dissipation. Use only a NOS 5Y3. It will be fine.
Since the cathode voltage is 25 Volts, make sure the cathode bypass cap is a 50 volt unit. |
The 6V6GT is an RCA, the 5Y3GT is an RCA and I just gave it a cap job with Sprague Atoms @50v, so I guess I'm fine. I was checking the voltage because a couple of days ago I got 2 RCA 6V6GTs and I put one of them in the Champ. After two days the tube died. I have the other one in there now and it's been ok so far.
try a 6L6 in there and see how you like it.
There's enough voltage to handle it, it will also draw more voltage so the readings will drop.
Winnie
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser |
#8 (permalink) | |
Re: try a 6L6 in there and see how you like it.
#9 (permalink) | ||
It didn't make that smell when it was new, PULL THE PLUG! |
Power transformer
I believe the power transformer was changed from the AA764 to the (hypothetical) AB764 Champ schematic. (Don't go by code on tube chart.) I cannot prove this on the "normal" champ since I cannot find a AB764 schematic for the Champ. I can only find one for the Vibro Champ and Bronco.
The change was to a higher voltage power tranny that puts out "365vac" on each leg to the rectifier plates instead of the "315vac" under the AA764. This creates higher DC voltages especially on the 6v6. The higher voltage setup uses a 40-20-20 cap can instead of the 20-20-20 on the AA764. Watch out for bogus 6v6 plate & screen voltages on AB764 (VC/Bronco) schemes. Someone wrote in the AA764's 6v6 plate voltages on a AB764 scheme since they were not listed from the factory scheme. This doctored scheme is published in some popular books and web sites. It shows 340VDC and 410VDC on the exact same wire at the same time (6v6's screen.)
JJman If it says "Vintage" on it -it isn't. |
PT info needed
JB1911, could you give the tranny codes off of that power transformer. JJmantele's post has me wanting to add that number to my reference list of transformer codes. The AA764 Champ used a 125P1B/022772 PT. I would like to know the code for the AB764 if it is different. JJmantele, if you have that code for the AB764 PT, could you post it back? Thanks to all... 8)
Wally |
Just play it !
It's from 1966, and it hasn't blown up yet. Voltage measurements - what do they actually mean? If it works, and has been working for 38 years, the voltages are probably OK. And apparently the transformers and tubes don't mind either.
#13 (permalink) | |
Re: Just play it !
That is the reason I started this thead. It's burned out a power tube and a preamp tube since I got it. |
#14 (permalink) |
Modern voltage/older amps
Since HC is down for the day, here's the link I posted there to make a great little voltage adapter to deal with the modern voltage/older amp problems.
http://www.geofex.com/Article_Folder...t/vintvolt.htm I built one myself for use with an old Champ and would highly recommend it 8)
Voltage
Remember the voltage on the heaters matters. You don't want to lower all the voltages if that puts the heaters below the intended 6.3 or so.
The power transformer codes I show on the AB764 VC/Bronco: Dual primary: 010020 (has 4 input wires for 117/234) I have this one since there are 2 wires going to each main line for 117v Single primary:022772 My '74 VC had ~400v on the plate and ~25v on the cathode also. This ends up being about 22 watts idle. The AB764 scheme implies almost 19watts. "Official" max DC for class A is 14 (I think.) The AA Scheme implies 13.5watts idle. I increased the cathode resistor to 516 from 449 ohms and now it idles at 17watts. I'm using an NOS RCA. I may go with a 740 ohm. The plate is not red at all so it's "ok." Cooling down the idle of the 6v6 raises the plate voltage BTW. It probably came with a 25v cathode cap. It should be upgraded to a 50v if not done already.
#16 (permalink) |
jhundt wrote: "It's from 1966, and it hasn't blown up yet. Voltage measurements - what do they actually mean? If it works, and has been working for 38 years, the voltages are probably OK. And apparently the transformers and tubes don't mind either."
Good advice until weak components take out a tranny or one's ears want to hear the amp as it should sound, imho. Old amps may work, but they don't function up to original specs and sonic quality with weak electrolytics. At least, that is my experience. Caps provide the basis upon everything else functions. I recently bought a SFDR for ridiculously low bucks. Someone had been scavenging parts from it at a music store because it didn't work. The only real reason why it had been set aside was someone's inability to realize that it needed a new electrolytic bias cap that retails for $3.00 or less. I replaced all electrolytics, put in soem old US tubes, and the thing is a great amp. IF I sold it for 100% profit someone would get a steal. IMHO, replace the caps and then start analyzing the status of everything else. |
#17 (permalink) | |
Re: Just play it !
#18 (permalink) |
LPBlue, aint' it the truth? I've heard that sadly expressed too many times....."but it was workin' fine, and then it stopped working."
I have also heard people say their amp sounded just fine, when in actuality the bottom end was loose with out-of-tune subharmonics and the highs had no sparkle to them. The sonics go long before the caps quit working totally. One rough analogy would be the electric/acoustic that I heard 'fizzing' today. The battery was getting low, and the sound showed it. Caps act like batteries in that they provide the voltage. If the voltages aren't not good, steady and ready at the call, things don't work or sound very good. |
#19 (permalink) |
Hey Wally, thank's for the advice. I stated earlier that I gave it a cap job with Sprague Atoms at 50v. I also replaced the cap can. Everything else is original on the circuit board. I have these 2 brown lump caps ( .047 and .1 ) on the right side of the circuit board. Are these the chocolate drop caps that I have heard about? If I replace them with orange drops or Mallory 150s will it improve the tone?
#21 (permalink) |
#22 (permalink) |
jb 1911 and Wally - you're right
I was a little too quick when I said "just play it!". I didn't realize you were having problems, I thought you were just worrying about the voltage readings.
No one has commented much on your question about the differences in AC voltage available in 1966 vs. today (110 - 127). I think that is quite possibly a cause for the higher readings at every point in the amp, but I'm no electrical engineer. My old Fender schematics all have this note: voltages read to ground with electronic voltmeter, values shown + or - 20% So you're still in range. Doesn't the type of meter affect readings, too? I thought that DMM's load the circuit way less than those older volt meters. Anyone here know about that? |
#23 (permalink) |
I have an RCA 5Y3GT, an RCA 6V6GT, and a Mullard 12ax7 in this amp. The cap can is a month old and I changed the 3 other electrolytics to Sprague Atoms @ 50v. I am thinking of doing the screen grid resistor and changing my bias resistor to 1K ( it is now reading 510 ohms ). What type of resistors do I need in these 2 spots and what brand do you all suggest?
I also have these 2 brown lump caps ( .047 and .1 ) on the right side of the circuit board. Are these the chocolate drop caps that I have heard about? If I replace them with orange drops or Mallory 150s will it improve the tone? |
#24 (permalink) | |
The 6v6 cathode resistor dissipates about 1watt. The AA764 says use a 1wt and the AB764 says use a 2wt. I used a 5 watt but would recommend either a 2 or 3 or 5wt. My added screen resistor is dissipating about 0.01 watts. I would suggest a 1wt since I think this location could be subject to a wide range of possible current under different surroundings. I changed out the chocolate drops for orange drops in my SFDR. I didn't notice a change. I didn't have my recording setup on my PC at the time so I couldn’t' do an objective "before and after." Some say it can be a night and day difference. I think there are too many variables to be able to predict the result. It's worth a try since they're cheap enough. Your results will vary.
#25 (permalink) |
The can I replaced was a 20 20 20 Mallory. I don't know if it was the original one. It was in pretty good shape and there was no hum at all before I changed it. I still have it because I suspect it was fairly new. Good point about caps being so cheap. I'm thinking of trying the orange drops and the Mallory 150s. If there is no difference, I'm out 5 bucks and a half hour of my time. I like fiddling around anyway.
