Let's talk about that blue gas...........
I have Jan Philips 6V6's in both my amps and both have been properly biased. Both sets of tubes are emitting a blue column of gas. One set is about a year old and the other set is new. I own a Hickok 6000A tester so I ran the battery of tests on the tubes and they passed. Filament continuity is good, gas test is good and tube life expectancy is good. Is this blue glow common to most tubes? Is gas necessarily a bad thing or what?
Blues Tubes
(might be a good name for an American tube company..)
Hi Caper- I have JAN Phillips NOS 6L6's in my SFSR. They have the blue glow and they sound great; I'm told it's OK. Here's one link to this electrical phenom- I know there are others, I just can't find 'em now. http://www.jacmusic.com/html/article...w/blueglow.htm Hope this helps- I'm sure others will chime in. I think maybe Lord Valve has something on his site about this also. Brian
"..and I've got some tricks up my sleeve...oh yes indeed! It might come back to haunt 'cha..don't you throw that Mojo on me!" |
Here's Another Link
http://www.kcanostubes.com/faq/blue_glow.html
Brian "I gots 'da blue tubes baby sittin' by the San Francisco Ba-ay.."
Jan Phillips 6v6
I've used 2 sets of those and they both have the blue glow. I'm running an RCA now in my '74 Vibro Champ and it's blue too 8)
Blue is cool. Especially in the dark. Usually no problem.
JJman If it says "Vintage" on it -it isn't. |
Maybe I NEED blue gas
My late 70's sfdr.has electro harmonix 6v6's and I ain't got no blue gas.Will it sound better if I add some gas?
I know that electricity works on blue smoke.'cause when you let the blue smoke out,it don't work no more.Maybe the same hold true for tone. No,realy.I'm serious .The quest for the magic tube is an almost holy one.Is there soething going on with tubes that DO show the blue that is desirable? The local amp dude set up my amp with a vintage 30 speaker(which I'm still not convinced was the best choice)and those electo-harmonix 6v6's.What do think?I hardly ever hear them mentioned here.The amp seems real strong.No,real compaints.But it seems like an unusual setup from what I read here. Maybe something different is happening with the blue stuff that is BETTER? |
My amp sounds great too, so I guess it really doesn't matter a whole lot. I have a Hickok 6000A tester and I just found out it can perform a test called a life test which can be used to determine how long the tube will perform satisfactorily. I am getting good readings from 4 power tubes that exhibit this glow.
BG,
when Ceasar Diaz came to The Hub he was totin' a Blackface Deluxe Reverb with a 12" Celestion V-30
and it sounded frikkin' amazing, he was also playing a reverse Firebird w/ mini-hums. I know his tubes were 6V6's and he told us that the ONLY MOD to the Deluxe was the Vintage 30. If my Jensen ever cooks that's probably what I'll get for a replacement - it sounded so good with that Firebird that any adjectives wouldn't do it justice.
Somebody Loan Me A Dime |
comfort from stan
thanks for the story about ceasar's deluxe.Very comforting.
My apologies to all for hi-jacking the post. But the blue gas question thing has me curious. You just never know when you stumble onto some weird thing like "tubes that so show the blue sound better.I still would like to hear more from the tube guru's on that subject.Not the technical explanation of WHY the gas is present ,but if it actually affects the tone. |
#10 (permalink) | |
#11 (permalink) | ||
This all has nothing to do with tube age - Dual Showmans & Twin Reverbs with original RCA or Sylvania 6L6GC's did the blue glow dance back in the 60s - Turn off the lights, turn up the amp, and watch the tubes while you play ;)
Keep on Twangin' |
Last Sunday night, my friend was letting me play his Marshall JCM 2000. All of a sudden, the was a BIG blue flash on the wall behind the amp. Then no more sound.
It sort of reminded me of the time I ran the speaker output of a 50W Marshall into the guitar input of a 100W Marshall. Recomendation: DON'T TRY THAT ON YOUR AMP! What can I say? I was very young and just as crazy then as I am now. |
