Old March 23rd, 2003, 12:18 PM   #1 (permalink)
markophonic's Avatar
Tube Amp Troubleshooting Question...
I have an old Kalamazoo Bass 50 tube amp. I used it for a guitar amp for years. About 15 years ago i kicked it while playing and knocked it over..POOF! no more anything...no noise...nothing?
Any idea what may have given out...considering the jolt it took?
Where should I start?
I've had it packed away but have been considering trying to get it up a running again...perhaps build me a nice little custom cabinet for it.
http://www.brianvanderark.com/
markophonic is offline   Reply With Quote
Old March 23rd, 2003, 01:51 PM   #2 (permalink)
Smokey's Avatar
Totally dead? Does it light up? Maybe some wires came loose when it fell over. Do you have a DMM? If so you can test around when it's on to see if you are getting B+ voltage to the tubes, but be carefull, voltages in some amps can get up to 450v or so. First check the output transformer wiring to the jack though.
Maybe the best thing would be to take it to an amp tech for troubleshooting.
Smokey is offline   Reply With Quote
Old March 23rd, 2003, 04:52 PM   #3 (permalink)
Dacious's Avatar
Element in tubes
The heater elements in tubes glow red hot. If you move an amp suddenly, you can cause them to break. Let alone kick it over. The amp would by now need the attention of a tech to replace the capacitors, as they would have dried out. Turn it on and you risk one shorting out and causing a fire or taking out a transformer. The good news is, it's probably a simple fix - caps and maybe tubes and a general service.
Old March 23rd, 2003, 05:30 PM   #4 (permalink)
jazzguitar's Avatar
If you have no idea at all, best take it to a tech.
At least he will tell you what's broken.
If you're brave and think you can open it yourself, do it, but you may or may not see the problem.
jazzguitar is offline   Reply With Quote
Old March 24th, 2003, 03:24 PM   #5 (permalink)
tom grossheider's Avatar
Tim Swartz hangs around here, he's in Michigan too. He can fix it up for you.
tom grossheider is offline   Reply With Quote
vB code is On
Forums Directory
