Doubting Amp purchase
So I'm starting to doubt my amp purchase. I got a used fender supersonic 112 for a great price recently. It's a really loud booger. So I got an attenuator and took it down -12db. Decent house level now.
But I still fear that I got too big, too loud of an amp with the supersonic. Even though I got it for a great price and always loved the look and sound when I played one at GC but didn't take into account the house volume levels I'd have to be at. It doesn't like to be attenuated very much tho! Also, I'm not happy with the JJ/Tesla re-tube the previous owner did and think it's biased too hot as well. I'm also not sure about the Celestion V30 speaker. So, I plugged my jensen C10R 10" from my super champ xd into my supersonic last night and really enjoyed the "fendery" tone I got. Just a little thin due to the 10" size I'm sure. I have the opportunity to buy a Jensen Jet Electric Lightning 12" speaker for a good deal. What kind of tone do you think the Lightning will provide? Is it really a more "heavy metal" sound? I'm really wanting to get a more vintage sound out of my supersonic. I've also thought about a re-tube to TAD 6L6 WGC, TungSol 12AX7, JAN Phillips 5751 for Input, PI, Drive, Reverb & and Mullards for the effects loop plus rebias to factory 32mv. So all this led me to playing a Fender blues junior [EDIT: wrong about "with an upgraded jensen speaker", it's stock fender "special design"]. It really was the sound I was looking for. Bluesy, Jimi/SRV sound when cranked but touch sensitive. But I'm having trouble making the decision to pull the trigger on another amp until I'm sure about my current one. I found a LE Blonde/Oxblood version with an upgraded Jensen C10R speaker like the princeton has. Great sound without attenuation, clean and clear fender tone at reasonable levels, lots of nice gain too when pushed. Although, I like to use pedals, tubescreamer for blues overdrive, delay, chorus, phase90, etc. and they are very sensitive to guitar volume, so I can't just crank the amp and then adjust with my onboard volume as if I was just going guitar to amp.*Plus I love the effects loop with the supersonic. I do not have the opportunity to test both amps side by side, unfortunately. What should I do? Is the SuperSonic an amp that will do it all (i use the vibrolux setting exclusively) and am I'm driving myself crazy thinking I need a smaller lower wattage amp when it is doing just fine? How do you make these decisions when you can't play them all for extended period with your own equipment? I guess the question(s) is: Would I be any happier with a blues junior as opposed to my supersonic with attenuator at house level? Will it all be/sound same and I should leave well enough alone!? Will a speaker change and re-tube to tungsol/mullard/JAN phillips/TAD 6L6, plus rebias to factory allow my Supersonic to sound the best it can and be the better deal in the long run?
Rutters 'La Cab' tele • '69 Thinline • Dlx Powerhouse Strat • DG Tribute Strat • Danelectro 56 Pro • Taylor GC5e, GSMini • Kala Uke • Korg SV-1 • Mustang III • Fender SCXD Project Blog Last edited by pontmercy; August 18th, 2010 at 04:37 PM. |
Tubes are like one notch up or down on the tone controls. I doubt that they will make all that much difference. I will say, however, that the JJ 12AX7s have a harder, crisper sound than the reissue Mullards and such. A lower-gain tube like the 5751 in V1 will soften the punch somewhat, too. So will a 12AT7 in the phase inverter. I rather like the JJ output tubes.
For a classic Fender sound, you need a classic Fender speaker. The Jet is for metal, right? I'd go for one of the cleaner Eminence speakers if it were mine, or a Weber 12F150 to get a better Jensen than Jensen tone. I'm not a fan of attenuators on the output, although it's one way to get the job done. You could put a volume box in the effects loop as an alternative. |
Sure.Tweak the Supersonic to its optimum,and if you can get to where a big Fender amp is in its true element-the stage,then you can have some fun with all that horsepower.
For home applications IMO something like a Pod with headphone capability and no speaker(s) will probably liberate your inner rock star without annoying your loved ones.Or the neighbors. |
Thanks all. I've asked the shop owner some questions about the speaker. He is a custom amp builder and installed it in an amp that sold but the buyer requested speaker change. The deal is 1/3rd the price of new but if it's not the right speaker for me, it's not! I may cancel the deal.
I'll check out the webers, never been a big fan of eminence tho. Tried the ragin cajun before in my superchamp and didn't like it. May keep the V30 and try a tube change/rebias... of course, all this is crazy if just leaving it alone, selling it and buying the blues jr. will get me more of what I need. ugh. I just don't know how to make this decision, which direction to go. I love the supersonic, it actually as it is, sounds great, but the chances of me doing stage volume is probably slim...but who knows what will happen and then i'll need the power.
Rutters 'La Cab' tele • '69 Thinline • Dlx Powerhouse Strat • DG Tribute Strat • Danelectro 56 Pro • Taylor GC5e, GSMini • Kala Uke • Korg SV-1 • Mustang III • Fender SCXD Project Blog |
Eminence makes a huge range of speakers that basically give you limitless options. Go to their website and listen to the sound samples, they did a good job and are fairly accurate IMO.
G&L ASAT Classic, G&L ASAT Deluxe, G&L ASAT Special, Gibson Les Paul Classic & Epiphone Riviera |
The V30 is a great speaker that can't deliver the sound you hear in your head-so-
+1 on the Jensen/J clone speaker because it appears you really like this amp. Less efficient old school alnicos could peel a tad off the volume on top as well. If you gig/play louder than at-home practice level, then you may want to make sure you've put the V30 through its paces before shelling out for another speaker (sez the frugal Yankee). Good luck!
Its not how long you make it, its how you make it long. |
The amp is a 2006, i feel pretty certain the V30 is opened up/broken in already and sounds better than the ones new at GC.
I think I'm going to hold off on the Jensen Jet. It seems that many here are right, it's a speaker made for loud and agressive and I'm looking for a vintage sound. I've listened to samples on Jensentone.com and the Eminence site. It's just so hard to tell what's going to sound like what really. I trust BillM about tubes not making that much difference tone wise but I would like to try using the JAN Phillips 5751s in input, drive channels to see if I can take a little volume out of the SS. I guess the biggest concern of all is that I would regret not having the SuperSonic if I got rid of it and I can't own yet another amp right now. :(
Thanks, noted! As said in my last post, I guess my main concern is regret. I got the SS for a deal. I may just deal with it. Do little to it as it is, enjoy it and someday in the future pickup a BJ.
Billm,
is it okay to use this 50watt speaker with a 60watt amp?
#13 (permalink) | |
#14 (permalink) |
I like your thinking Ruby!
#16 (permalink) |
I agree with brokenarrow5. You said you want a classic Fender tone. I don't own, nor have I ever played through a BJ but I would much prefer a Deluxe Reverb (silverface or reissue) for the classic Fender tone. I would not dump any money into your superSonic unless you are sure about keeping it. I would not be concerned about enough horsepower for stage volume since most amps are miked anyway. A Deluxe Reverb will put out enough stage volume. In fact, our sound guy keeps telling me mine is too loud and I barely have it set on 4 or 5. I'm going to try an attenuator.
I wouldn't join any forum that would have a guy like me for a member. |
#17 (permalink) |
That's true. A friend plays in country/rock band, uses his DRRI unmic'd and gets almost too much volume! I should have thougth about that too.
I admit, my vanity got in the way of my tone, dammit! I fell for the blonde/oxblood and those sexy kickback legs!! :) I think after all this talk today and good advice all around, that I'm going to keep the SS, put in some new tubes, speaker and leave it for what it is. A great versatile LOUD LOUD LOUD amp. Then later, I'll save up to buy something else as well. Who knows what my future holds and what kind of gigs I may play someday. The attenuator I use is called a powerplug by recycledsound.net It was only $80 and knocks down -12db, still sounds pretty good and allowed me to over triple my volume knob from .75 to over 3 now! The SS really starts "toning" up about 4 tho. When the wife and kids are away, I play there all the time and love this amp! Change the speaker and tubes (the JAN Phillips I hear in drive will smooth it out too!) and bob's your uncle, fanny's your aunt!
#18 (permalink) |
Volume-wise there's at most a 3db difference between the Supersonic 112/V30 and a Blues Jr: although the supersonic puts out about triple the wattage (doubtful, but say +4.5db) its speaker is less sensitive. The BJr has a master volume, but as Billm pointed out a volume box in the effects loop will do the same thing. Going with a lower-efficiency speaker would make the same difference in volume as changing amps, and have the most pronounced effect in shaping the tone.
Tube-wise I'd agree with the opinion that JJ's tubes tend to sound a little more hard-edged modern rock than vintage. That said I still think they're among the best of new tubes. If sticking with the Vibrolux mode I'd only try changing V2 and *maybe* play with V4 and V5. I'm a short-bottle fan so the TAD 6L6WGCs might also find their way in if I had the money to throw around. I'd say stick with the Supersonic. $150 for a speaker, volume box and a couple preamp tubes (with shipping) is a lot cheaper and more reversible than selling/trading for another amp. -Laird |
#19 (permalink) |
Most 6L6 amps are loud and the BJ is fairly quiet for a 15W.
Personally I'd avoid TAD 6L6GC in favour of GE JAN 6L6WGB(5881) or Sovtek 6L6WXT+ The JJ ECC83S (not JJ ECC803S) is a good low noise Telefunken ECC803 clone for V1, as are most but not all Mullard clones for the rest. I recently tested some of these against genuine Mullards and found that with a little tweaking of controls I could get the same sounds. Using a low gain valve can result in a very bland sound. However I think your main problem is the nasty Vintage30, a very harsh speaker, try something less mean. And do put a master volume in the FX loop. It's the only way to achieve parlour level without destroying the tone. The output 6L6 do not clip much so dropping their input level just drops the volume whilst allowing the pre-amp to be up to produce whatever tone you want. An attenuator leaves the output valves running full on, you get that tone and that's it. With a master volume you can run the pre-amp right up at low volume, and get a greater range of sounds.
#20 (permalink) |
buyer's remorse is rough-but don't make it worse
If you really like the variety of sounds you can get out of the amp right now, keep it. Rather than use an attenuator or a volume pedal in the effects loop, another option if you are looking for dirt tones at lower bedroom volumes is to just use a good O/D pedal.
If you are not getting good sounds out of the amp, I would be a bit leery of doing lots of speaker and tube upgrades. What was a really good deal starts to quickly get real expensive and may not work. Rather than risk $$ for an uncertain outcome, you might be better off shopping for a good used amp that you confirm gives you just what you want. Sell the amp you have to get the amp that you are 100% certain will make you happy. I have learned this lesson the hard way after buying different amps and then throwing good money after bad chasing various upgrades but never quite finding what I was looking for. If you are not opposed to using pedals, in my experience it's not so hard to dial in your tone at a variety of volume levels and with a variety of amps with help from a good pedal (like Fulltone OCD, for example). If you are plugging straight into the amp, then it has to be just the right amp if you have any hope of getting the sound you want at the volume level you want-- exactly the right tone stack, and exactly the right power tubes and speaker.
chris m. |
