Old September 29th, 2004, 07:48 AM   #1 (permalink)
Hwilliams's Avatar
Class A?
I know that this may be a dumb question but could someone explain to me what class A is? I saw this while I was reading the specs on an amp. It said that it had 30 Class A watts. What's the difference between 30 watts and 30 class A watts?
Thanks
HW
Hwilliams is offline   Reply With Quote
Old September 29th, 2004, 07:53 AM   #2 (permalink)
weelie's Avatar
http://www.pentalaboratories.com/audio_help6.asp
http://www.duncanamps.com/technical/ampclasses.html
<- I don't need smileys, I'm smiling already.
weelie is offline   Reply With Quote
Old September 29th, 2004, 08:11 AM   #3 (permalink)
zook's Avatar
Mostly it's hype
http://www.aikenamps.com/ClassA.htm
Randall dispells all the myths and BS.
Just because an amp is cathode biased does not mean it's class A. In actuality, a class AB amp is more efficient.
Single ended amps e.g. Fender Champ and others with only one output tube are class A since one tube works all the time. A Class A push pull amp would have both tubes working at the same time as opposed a class AB with one pushing while the other is pulling. etc.
Don't be swayed by hype.
Winnie
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser
zook is online now   Reply With Quote
Old September 29th, 2004, 09:55 AM   #4 (permalink)
Mik
Mik's Avatar
Don't be swayed by Class A hype...but don't ignore the amps just cuz of the hype. "Class A" may be misleading, inaccurate, a downright lie-but I've played and owned a few of 'em and I haven't encountered one yet I didn't like. Dr. Z's, the Gibson Goldtones, Vox, even the Pro Jr (Fender to its credit never called the PJ "Class A", I don't think Z calls his amps A either but folks do), I dug em all. I hear "Class A", I just assume it's a "hot" bias, likely cathode bias, EL84 Class AB amp.
I really don't mind a little "Class A" marketing swindle...uh, I mean sizzle.
Mik
a "motor-bike with a touch of blood in it is better than all the riding animals on earth, because of its logical extension of our faculties, and the hint, the provocations, to excess."-T.E. Lawrence
Mik is offline   Reply With Quote
Old September 29th, 2004, 11:44 AM   #5 (permalink)
Tim Swartz's Avatar
Reduced to a mere buzzword...
It is unfortunate, but let's face it, who would buy a Class A/B amp when they can have Class A. It sounds like Class A/B is a compromise... and that is what the marketting liars are capitalizing on. As long as the term sounds better who cares about the electronic definition.
Old September 29th, 2004, 12:38 PM   #6 (permalink)
dhdfoster's Avatar
I read the whole explanation, and the only conclusion I was able to firmly arrive at was that I am obviously an idiot. I know what "tube" and "power section" are, but I get lost after that.
dhdfoster is offline   Reply With Quote
Old September 29th, 2004, 01:00 PM   #7 (permalink)
Re: Reduced to a mere buzzword...
But, with Class A/B, you get two! LOL!
Uh-oh, I just saw the Allen Brown Sugar is class A/B cathode bias, I'm not getting one now.
Seriously, I'm more interested in how the amp sounds than whether it's class A or class Z.
Will V. is offline   Reply With Quote
Old September 29th, 2004, 01:45 PM   #8 (permalink)
Rick S's Avatar
Most others don't understand it either. Bottom line is, if you aren't a designer or tech, operating class is absolutely of no concern to you.
As a musician, learn to trust your ears and choose amps based on performance goals for your style and disregard operating class claims as hype.
As Tim said above, it was a marketing agenda that started this. The hypemeisters found out early on that operating class was easily confused as some sort of grading system and was taken hook line and sinker by the masses.
Rick S
Rick S is offline   Reply With Quote
Old September 29th, 2004, 09:35 PM   #9 (permalink)
guitar_ed's Avatar
A few more words on Class A amps....
The whole point about Class A amps has to do with the power settings on the power tubes/transistors. (You can have a Class A solid state amp.) The idea is to put the tube/transistor in a state where it generates less noise. But there is a cost. Class A amps use more electricity and generate more heat than other amps. Simply put, your electric bill will be higher and your room warmer. Also, a true Class A amp is harder to design and build, and thus should be more expensive than the alternatives.
As Will V. says: Listen to different amps until you find the one you like. It may be tube , it may be solid state, or a mix. In the final result, your preference is the only thing that matters.
Guitar Ed
If a little knowledge is dangerous, I have little enough to be be deadly.
Piss off a politician, register to vote.
When you complain about the government, remember that you ARE the government.
Voting is the ultimate act of civil dis-obediance.
AIM - guitar_edg
Skype - guitar_edg (had to change on 5/16/06)
guitar_ed is offline   Reply With Quote
Old September 29th, 2004, 11:07 PM   #10 (permalink)
Tremo's Avatar
Re: A few more words on Class A amps....
Huh? Noise has nothing to do with class of operation. Who gave you that misinformation?
Old September 30th, 2004, 01:17 AM   #11 (permalink)
trag-o-caster's Avatar
Eggzackle-lackle-leeeeeee!
Timothy Jon Lamb
trag-o-caster is offline   Reply With Quote
Old September 30th, 2004, 07:17 PM   #12 (permalink)
Mr. Droopy-Drawers's Avatar
I have a hunch guitar_ed condensed a very convoluted train of thought. In some high-end audio circuits, the theory might be that switching transients and noises may be present. Class A would have no such concerns, because the devices are biased in a way that they are always 'on'. This isn't a problem with tube amplifiers anyway, because the OPT has the wonderful 'feature' of common mode rejection.
There's a lot to consider, and a lot to think about. But the scientific theory is waaay beyond me. So I'll just mosey along.
"You can lead a horticulture, but you can't make her think!"
Mr. Droopy-Drawers is offline   Reply With Quote
Old September 30th, 2004, 11:00 PM   #13 (permalink)
Tremo's Avatar
Interesting guess, but a guess none the less. Regardless, it's technically incorrect. Sorry, maybe guitar_ed should answer for himself.
Old October 1st, 2004, 05:40 AM   #14 (permalink)
Rob DiStefano's Avatar
Class A? Class A/B?
Who the heck cares as long as the amp sounds great, is quiet, is reliable.
Amen to all the Class BS.
Old October 1st, 2004, 09:42 PM   #15 (permalink)
your amp runs in class BS? cool! bring it over to the shop...i want to see it on the scope!!
"Progress is not possible without deviation from the norm." Frank Zappa
mark norwine is offline   Reply With Quote
Old October 1st, 2004, 10:18 PM   #16 (permalink)
Tremo's Avatar
I thought only Groove Tubes could be biased into class BS!! Damn, learn something new every day.
Old October 1st, 2004, 11:23 PM   #17 (permalink)
jjmantele's Avatar
Class A
"Class A" in an advertisement means nothing. Kind of like if your amp was "Turbocharged."
The easiest way to understand Class is to think of a lumberjack using one of those giant saws to cut thru a log. Sometimes there's a lumberjack on both ends of a double handled saw. That set-up is "push=pull" for obvious reasons. The key question is, are both lumber jacks pushing and pulling 100% of the time or does each guy take a "rest" during some/all of the pull stroke (for example.)
One guy: Must push and pull all the time >Class A
Two guys: Push and pull 100% of the time >Class A
" : Push but don't pull >Class B
" : Push but pull some of the time >Class AB
Of course it's more "efficient" to have 2 guys since each guy can specialize in just pushing (for example) resulting in more output than compared to having 2 guys pushing and pulling on the same handle. Almost all 2 output tube guitar amps have the 2 tubes in "push pull" Class AB.
JJman
If it says "Vintage" on it -it isn't.
jjmantele is offline   Reply With Quote
Old October 2nd, 2004, 04:40 AM   #18 (permalink)
Heck, if ya think that's cool you oughta see my amp power cord soldering techniques.
vB code is On
Forums Directory
