5E5A OR 5F4
I am wondering about any sound and tone differences between a 5E5A and a 5F4 in compairison.
I now have a 5E5A and want a lighter and smaller amp but don't want to sacrifice tone because I am very happy with my 5E5A amp. I also need the small size for transportation purposes. I have been thinking of a deluxe but need clean head room above what a deluxe will give. So I have been wondering about a high output 5E3 (25 watt)on a 15" speaker. Any experience with this combo? Also wondering about weight of a 5F4 compaired to the 5E5A? Thanks Bruce |
#2 (permalink) | ||
A 5F4 really isn't that much smaller than a 5E5A. If you like the 5E5A - and unless you don't like the 5F4 even better Quote:
+1! My 5E3 has nowhere near the clean headroom of my 5E7. A 5E7 is slightly different from a 5E5A of course, but it is still much closer to a 5E5A than to a 5E3. A high power 5E3 on the other hand sounds like a killer idea. As a matter of fact I'm trying to figure out how to justify such a build myself.
We shall not cease from modifying our amps. And the end of all our modifying will be to arrive where we started and know the circuit for the first time. |
Just change the cabinet. The 5E5 / 5F4 chassis is the same. You want smaller? You want a custom cabinet. It can be packaged in a cabinet 1" wider than a tweed Deluxe with either 2x10" or 1x12". If you want big balls go with 2x10".
My 5E7 lost about 9 pounds when I turned it into a 5B5 Pro (which is a lot like a 5E3 with 6L6's). About three pounds was from the speaker change, a smidgeon was from the lighter homemade chassis, the rest was from the smaller transformers. Now its output is somewhere in the 18-20 watt range.
- Scott
Wound thirds are my anti-wank. |
If you get a 15" 5E3 it's not going to be much smaller than a 5E5A. A 5F4 isn't much smaller than a 5E5A as mentioned previously. It's about 3" shorter but the same width approx.
Get a neo speaker for your 5E5A and turn it into a 5E5 which is sort of like a two-channel deluxe with 6L6s. I'm doing that to mine right now. |
I have no intention of getting rid of my 5E5A but rather want something just like it in a smaller package.
muchxs, you say a 5F4 with a pair of ten's will fit in a cab 1 inch larger than a deluxe? That would be great, but will the tone be same in comparison? Or would I be better with a 50 oz. 12" alnico Weber. I had my 5E5A on a 12" and didn't like it as much as the Weber 15a150 Speakers have to be alnico by the way. |
