Old May 6th, 2010, 05:25 PM   #1 (permalink)
telekaster1999's Avatar
victoria 5112?
Is a 5112 loud enough to play in a band situation with. Anyone with actual experience, please comment. I have an oppurtunity to buy one for around $850.
But I could be wrong. Tony
....play skillfully with a loud voice. Ps.33:3
telekaster1999 is offline   Reply With Quote
Old May 6th, 2010, 08:56 PM   #2 (permalink)
stlthinkin's Avatar
depends on your band. It could probably handle small bars, jams, or practice if you don't need headroom. I use it in a 4 piece and it keeps up for rehearsal (smaller room).
If you have big space to fill or a couple guitars you'll probably need more if you're not using a mic. However, if you always practice with a PA just keep a mic and cable in the back and your set.
After a couple gigs mine became my #1 just because it's so light/small and the tone is so good. Once you plug it through a PA it sounds bigger than most amps, and I love being able to get all my tone in the PA with a low stage volume. Never have to worry about power soaks, noise, or how your rig will sound if you can't crank your amp.
stlthinkin is offline   Reply With Quote
Old May 6th, 2010, 10:08 PM   #3 (permalink)
so it breaks up real early?
