65 DRRI - noisy Vibrato... - Telecaster Guitar Forum
Old April 9th, 2010, 03:25 AM   #1 (permalink)
I really love my 65 DRRI - butů
...the Vibrato causes quite a noise, while the Amp with the Vibrato switched of is running really quiet.
Anyone here having the same issues?
Is there any chance to get rid of this noise? If yes, how?
Though i dont use the Vibrato very often, i┤d rather have it quietů
johnnygold is offline   Reply With Quote
Old April 9th, 2010, 03:35 AM   #2 (permalink)
I wish that i could use the vibrato on my DRRI more, but it is making this annoying blaffing noise.
blaffblaffblaffblaffblaff
Depends of how deep i set the vibrato though.
Nilsi_tl is offline   Reply With Quote
Old April 9th, 2010, 04:16 AM   #3 (permalink)
I┤ve seen Jim Campilongo on youtube demonstrating the PRRI where the Vibrato works perfectly. Should be the same system, so i guess there must be a way to make it run properly. Just how...???
Sponsored Links   #
Old April 9th, 2010, 07:15 AM   #4 (permalink)
xjazzy's Avatar
Tubes perhaps.
Mine is doing the same thing.
This was discussed around here before...
Still got the Twang!
https://soundcloud.com/jotacaster
xjazzy is offline   Reply With Quote
Old April 9th, 2010, 12:47 PM   #5 (permalink)
telex76's Avatar
Princeton vibrato is completely different than Drri vibrato. (DRRI uses an opto-coupler and Princeton doesn't) That being said your vibrato should work without being too noisy. If you had a hand wired DR I could offer some trouble tips, but I would not try to work on a PCB amp. Someone might help you but you will probably have to take it to a tech.
telex76 is offline   Reply With Quote
Old April 10th, 2010, 05:53 AM   #6 (permalink)
1955's Avatar
I had this same problem and also with the reverb. It took me weeks to solve/partially solve it. I ended up getting an Ampeg footswitch, and a big shielded cable. That was half of the noise solved. Those Fender footswitches are like antennas, there's hardly any shielding.
Then, I wrapped the whole cable a whole bunch with electrical tape. Helped to have a shorter cable, too. With the reverb, I took the tank out, epoxy'd the leads, then put steel plates on top & bottom, wrapped it in a towell, & taped it up with electrical & duct tape. That was better for a cleaner, longer-dwelling reverb. Also may be some ground wire is loose if I can remember another problem I had. I'm no tech, but I searched forever to solve the problem and that method helped me.
"If opportunity doesn't knock, build a door." Milton Berle
1955 is offline   Reply With Quote
Old March 5th, 2013, 04:42 AM   #7 (permalink)
adnanb's Avatar
I removed the new digital tremolo circuit completely and replaced it with the old school opto coupler. The ticking noise when the tremolo is switched on can be eliminated by gently pushing the green grid wire of pin 2 of V5 away from the other wires.
But the tremolo is very shallow now. The tremolo Intensity pot does nothing until 9. When I set the Intensity pot to 10, I have a very very shallow tremolo.
Any ideas what the reason might be?
adnanb is offline   Reply With Quote
Old March 5th, 2013, 05:08 AM   #8 (permalink)
hiero's Avatar
Simply get a new Tube for the Vibrato...
I had this (not the perennial tick which is inherent) and it sorted it out. Apparently Fender go through vast amounts of Tube matches as the slightest deficiency can cause noise when input into the Vibrato. Keep the tube you have as will probably be good for another application.
__________________________
Upgrades for BOSS Pedals & FX
http://boss-pedals.jimdo.com
hiero is offline   Reply With Quote
Old May 2nd, 2014, 06:06 AM   #9 (permalink)
I have the same issue...replaced the digital pcb and placed the optocoupler but the tremolo intensity isn't much effective until 8 or 9 . Is this normal? Maybe the optocoupler require some mod?
Anyone can help?
Emanuel is offline   Reply With Quote
» Random Photo for Guests
Crafter Active Bass
» Recent ThreadsGuests
Fender Logan Custom Guitars
