4x10 or 1x15 - what's your opinion?
Do cabs have innate personalities despite what they're loaded with? Does a 1x15 cab have a characteristic sound compared to a 4x10 regardless of what speakers are used or the cab design?
I've always loved the sound of 4x10 cabs and I'm thinking of building one. Actually it may be a 3x10 because I'll probably just make a new baffle for an existing cab I made. I'm also considering a 1x15 as well. Is it possible to make generalizations about each type?
I am the center of the universe and so are you.
#2 (permalink) | |
Now I'm confused. |
Well, I guess there must be a reason, why the 15" speakers did not enforce as guitar speakers. They might be good for bass, but not for guitar. To me they just sound boomy, mid-focused and have no character (like through a telephone, but more bassy).
Listen to this soundclips: - 10": http://eminence.com/guitar_speaker_d...0&SUB_CAT_ID=4 - 15": http://eminence.com/guitar_speaker_d...5&SUB_CAT_ID=4 But in the end maybe itīs just the sound what you want... Daniel |
I personally like 15's and guitar, but I've never tried it side by side with a 410. Plenty of good 4x10 guitar cabs out there for sampling, but guitar 115s are pretty thin on the ground. Just don't try a 115 bass cab and presume that is representative of what a guitar 15 will sound like.
The tricky part is actually getting 15" guitar speakers, not bass speakers. A 410 should move a lot more air (read: a LOT louder) given the same amount of power applied if the speakers are of roughly the same efficiency. Where's Charlie Chitlin?
42 |
4x10 and 1x15 is quite a difference - the 4x10 is going to sound much much fuller just due to the fact there is more than one speaker pushing air.
A better comparison would be 4x10 and 2x15 IMO. I agree with the above comments - had a Fender Tonemaster 2x15 cab and don't really miss it - 2x10 combos (with good speakers) sound much better and have a fuller range to me. Need I also mention that a 2x15 cab weigh a ton and is generally more outrageously dimensional and difficult to move around - and I'm not a slouch.
"Should've taken a left turn at Albuquerque." |
EVM-15L; When SRV got fed up with trashing speakers in the Vibroverb he went ElectroVoice.
Problem solved. Of course You're dealing with Twin/Super weight when You make the change, but it'll keep up to either one of them no problemo.
Somebody Loan Me A Dime |
Über - nice. Funny being was living in Germany at the time. Bought it off Ebay and had it shipped. At the time I didn't think much of it but haven't seen a Tonemaster 2x15 since! Can only guess it must have been a special order?
My main amp that I use right now is a 1x15 combo and it is my third amp or cab with a 15 in it. I've also had a ton of 4x10 combos and cabs. To my earrs the 10s sound almost a little elasticy (Is that a word?), if that makes sense. The 15 to me sounds a little more focused whereas the 10s sound more open. Of course that could be due to the major difference in the amps I was using them with... who knows?
They both sound good it is just which is your cup of tea. The 10's are like a filet mingon and the 15 is more like a giant porterhouse. |
I've played through quite a few 1x15 combos, and although none of them sounded bad, they were never quite right.
I would take a 1x10 over a 1x15 for guitar playing, let alone a 3or4x10. In general, a 10" speaker sounds much better to me and all of the musicians with whom I play. I used to use and Ampeg head with a 4x10 cab that sounded really good. The cab was not very high quality and neither were the speakers, but it sparkled and cut through the mix very well. These are just my humble opinions. Go with what works for you. I think you'll enjoy the 3xor4x10. Good luck.
If they act too hip, you know they can't play ****. Miles Davis |
#12 (permalink) | |
I find a good 10 to be more punchy than a 12 and a good 15 can be brighter than a 12.
Personally I prefer the 12 for guitar but yes, much depends on the cabinet. Perhaps a closed cab for 10 and an open for 15. Heavy are 15s.
#16 (permalink) | ||
Of course! 15's are bigger. 10's are smaller. Was that a trick question?
What that the trick question? Quote:
The most logical approach would be to design the cab around your choice of speakers. However, it sounds like you already have a cab and want to throw some speakers in it. In that case, I'd suggest you start with the 15", because it will be easier, cheaper, and if you don't like it, you only have to get rid of one speaker. If you start with four 10's and you don't like those, you'll have to get rid of all four. But yeah, I'd probably go with three 10's instead of two or four... |
#17 (permalink) |
I like a 3-10"...I have had one for the last couple years..a loaner that turned into a buy..I have yet to open up the closed back, never any need or desire,,,but I like it very much for both guitar and steel, a very immediate sound...before that I had a 15" with a horn,,,but I used that in a different room, so comparisons are moot from my perspective.But I got a good sound out of that(another loaner) , as well ...generally, you are going to adjust the sounds from the amp and guitar according to your desired sound, or work with what you have,,so I would opt for the configuration that is easiest on the back and wallet first, and go from there...as someone on here said, "wherever you go, there you are"
#18 (permalink) |
Not sure the sound your after but I changed from alnico 4x10's to a weber 15a150 and haven't looked back. Its sounds great and I would like another one also. Go with alnico speakers a much better sound in my opinion. Unless you just want to thrath.
#19 (permalink) |
One generalization to me is true on this subject. That is, there is no objective, believable conventional wisdom when it comes to speakers size/format and guitars. Taste is everything. I voted with my dollars, parting ways the with best BF Super Reverb ever to come my way, and trading a Clark Tyger Bandmaster. Multi 10s might be perfect for guitar to many, but not to me. A 15" speaker, that's my preference.
4x10 (to my ears) are typically fast reacting, snappy, with a lots of depth. Even a cavernous sound, as in the BRSR, with good reverb. Solid bass. The 1x15 is slower, not more or less bass, but more of a thump or kick in the bass. A wide, fat kind of sound. IMO, the top end sound with a good 15" is what the fuss is all about. Md |
#20 (permalink) |
Four ten's combined have about 30% more area than one fifteen. You lose about an inch all around for the frame and surround.
Four ten's sharing a baffle couple acousticly to give better bass response than one of those tens could do. Check out an SVT cab. Dispersion is an acoustic advantage with ten's. A speaker will beam any wavelength shorter than its diameter straight down the centerline, so tens will start beaming at a higher frequency than a fifteen would.
Dim lights, thick smoke, and loud, loud music. It's the only kind of life you'll ever understand. Dim lights, thick smoke, and loud, loud music. You'll never make a wife to a home lovin' man. |
